Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
65 400 rear main seal
Old Mar 28, 2016 | 08:49 AM
Bfg's Avatar
Bfg
Am I correct to replace the rear main seal on my 65 400 motor with the Ford 460 neoprene seal number BS 40032? I see that number is a replacement for 455 but am not sure of the 400 motor. Also mentions about some trimming on other posts.
Old Mar 28, 2016 | 09:08 AM
RAMBOW's Avatar
Ben
I believe its the same on the 400 as the 455, as the crankshaft journal size are the same, but maybe someone else can confirm that.
For trimming, I watched a youtube video made by BTR that showed him doing it, and I did the same steps on mine... was not a big deal- and my 455 went together fine and did not leak. Can't ask for more than that.
Old Mar 28, 2016 | 09:42 AM
Bfg's Avatar
Bfg
I would like to view the video. What is the site I should look for?
Old Mar 28, 2016 | 01:27 PM
All BBOs use the same rear seal.
Old Mar 28, 2016 | 01:32 PM
RAMBOW's Avatar
Ben
This is the video I watched
Old Mar 29, 2016 | 04:39 AM
Bfg's Avatar
Bfg
Ok, but can the ford seal be installed with the crank still installed like the rope seal can?
Old Mar 29, 2016 | 05:50 AM
Probably not. I tried to do this on a 350 Olds (with the AMC 258 seal) and failed.
Old Mar 29, 2016 | 09:15 AM
Bfg's Avatar
Bfg
Well in that case I'll stick to the rope seal then.
Old Mar 30, 2016 | 09:52 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Is the engine out of the car? If not is the trans out? Speedy sleeve the crank if the groove is deep enough to catch your nail on. Theres a right and wrong way to install these sleeves. If you go for it email me for details.
Old Mar 30, 2016 | 10:14 AM
Um...
He's talking about a REAR main, not the front crank seal.
FYI, I always install a sleeve when replacing the front crank. You can buy the kit from FelPro with the front seal and sleeve together.
Old Mar 30, 2016 | 03:03 PM
aaa **** be tough to stretch it over that dam flywheel flange wouldn't it....get out the sneaky-Pete. I just work on way to many different engines, not enough Olds...damper snout sleeve yes. Ya...so bfg dont bother contacting me for that advice as it doesn't exist.
I've not had luck with R&R-ing rope seals and getting them to seal. I've always had to R&R the crank and get it surfaced then install a new seal. Others have had success here not me.
toneypenna
Oct 7, 2010 05:19 PM
Robert Kiedrowski
Oct 19, 2009 07:07 AM
Gbobby
Mar 15, 2009 02:55 PM
65cutty
Sep 23, 2008 10:07 AM
gearheads78
Apr 17, 2008 05:03 PM
