Whats the trim-TR977 and the date-12A for this 72?
ST 72 = style/model year = 1972
34267:
3 = GM division = Oldsmobile
42 = body type = Cutlass Supreme
67 = body style = convertible
LAN = assembly plant = Lansing MI
310361 BDY = body number (has nothing to do with the VIN)
TR 977 = trim/interior color = white
36 A PNT = lower and upper exterior body colors = radiant green (36) with a white convertible top (A)
12A = time build code = December (12), first week of that month (A), 1971
A65 = option code = custom sport front seat, including center armrest and bright moldings
Hope this helps!
Randy C.
34267:
Hope this helps!
Randy C.
34267:
Hope this helps!
Randy C.
34267:
Hope this helps!
Randy C.
Thank You Randy! Chris
p.s. Cant believe I found a build sheet in the car two days ago. Very hard to read it though, faded like.
Do you know what the difference between a build sheet and a broadcast card is?
i understand its the broadcast card i found, thanks allen for educating me
Last edited by Seriousfun; Apr 20, 2012 at 09:38 PM. Reason: i understand its the broadcast card i found
Although it's a little worse for wear, that is indeed a broadcast sheet. Lansing was about the only factory that you'll not see build sheets from. Kind of strange they would allow the broadcast cards to remain stuffed into the cars, but not build sheets.
1320dragmonza
Tech Editor's Desk
Aug 17, 2013 04:44 PM
