Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Whats the trim-TR977 and the date-12A for this 72?
Old Apr 15, 2012 | 10:39 AM
Seriousfun's Avatar
*ssholes Garage
Need help on decoding this cowl tag.
ST72
34267
LAN
310361
TR977
36A
12A
A65
Thanks, Chris
Old Apr 15, 2012 | 05:28 PM
rcorrigan5's Avatar
Randy C.
ST 72 = style/model year = 1972
34267:
3 = GM division = Oldsmobile
42 = body type = Cutlass Supreme
67 = body style = convertible
LAN = assembly plant = Lansing MI
310361 BDY = body number (has nothing to do with the VIN)
TR 977 = trim/interior color = white
36 A PNT = lower and upper exterior body colors = radiant green (36) with a white convertible top (A)
12A = time build code = December (12), first week of that month (A), 1971
A65 = option code = custom sport front seat, including center armrest and bright moldings
Hope this helps!
Randy C.
Old Apr 20, 2012 | 08:17 PM
Seriousfun's Avatar
*ssholes Garage
34267:
Hope this helps!
Randy C.
It did help.
Thank You Randy! Chris
p.s. Cant believe I found a build sheet in the car two days ago. Very hard to read it though, faded like.
Old Apr 20, 2012 | 08:31 PM
Post a picture of the 'build sheet'. If you found one, that's the first one we will have ever seen.
Do you know what the difference between a build sheet and a broadcast card is?
Old Apr 20, 2012 | 09:22 PM
Seriousfun's Avatar
*ssholes Garage
probably not, this is what i found, pic flipped sideways on me, ill get a better pic tomorrow of the whole thing
i understand its the broadcast card i found, thanks allen for educating me
Last edited by Seriousfun; Apr 20, 2012 at 09:38 PM. Reason: i understand its the broadcast card i found
Old Apr 20, 2012 | 10:22 PM
Although it's a little worse for wear, that is indeed a broadcast sheet. Lansing was about the only factory that you'll not see build sheets from. Kind of strange they would allow the broadcast cards to remain stuffed into the cars, but not build sheets.
Boiler_81
Sep 22, 2020 02:05 AM
GEARMAN69
May 22, 2015 10:58 AM
gmsteve455
Mar 25, 2014 07:02 PM
1320dragmonza
Tech Editor's Desk
Aug 17, 2013 04:44 PM
MN71W30
Oct 17, 2011 09:03 AM
