Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
L69 venturi size?
Old January 19th, 2012, 12:56 PM
66cutlass400's Avatar
L69 venturi size?
I recently purchased an original tri carb intake, and am starting to piece together the carbs/linkages/fuel lines. None of the spec sheets on the carbs list the venturi size for them, does anyone know what the correct size was in '66?
Thank you, Eric Gould
66cutlass400 is offline
Old January 19th, 2012, 01:25 PM
Ben
RAMBOW's Avatar
Call Mike w/ http://www.pontiactripower.com
He was very helpful when i restored & rebuilt the carbs for my buddies L69. He Has done quite a few 66 olds Tri-Carbs as well as the pontiac stuff & knows the guts of the carbs & can help you pick the right parts for your application.
RAMBOW is offline
Old January 19th, 2012, 05:48 PM
Run to Rund's Avatar
center carb (primary) 1-3/16"
end carbs (secondaries) 1-5/16"
On the four barrel scale (1.5" vacuum) they are 249 and 299 cfm or round off to 850 total.
Run to Rund is offline
bocoogto
August 13th, 2020 05:30 PM
pontiactripower.com
August 17th, 2008 12:51 AM
66cv442
August 12th, 2008 03:27 PM
bocoogto
May 20th, 2008 12:30 PM
bocoogto
March 29th, 2008 10:00 AM
Quick Reply: L69 venturi size?
