View Full Version : Other
- Fuel Tank Swap
- Need advice: Rev limiter or ignition system combo kit
- 1940 olds series 90 fuel tank questions
- 1972 Cutlass fuel filter
- 1993 Olds Ciera 3.3L + Heat/AC Control Help
- 455 V8s from GM’s Buick, Oldsmobile, and Pontiac
- prices of certain parts
- Protecto plate help
- Which Coolant w/Factory Aluminum Intake?
- 69 442 convertible
- 404847 water pump?
- Starter does not engage flex plate
- Not sure where to post this simple question
- BARN FIND RESCUE! 1968 Hurst/Olds rescued
- A6 coil: Looking for original part numbet
- Confused to the Max
- A6 pulley: looking for original part number
- 91 Toronado Digital Odometer Wrong
- Joe Spagnoli at Mecum 2022
- 1968 Oldsmobile Olds Ram Rod 350 Cutlass S W31
- Remote mirror disassembly
- Taking Rust off Protect-o-plate?
- Replacing Power Steering Pump
- Brief video of 1966 Hurst Hairy Olds!
- What do these symbols mean
- '70 olds 442 "escape machine" stock eliminator runs 11.26@117.61
- 1966 Olds F-85 Trunk Torsion Rods Installation
- AC Muffler???
- 1970 to 1972 Cutlass 455 torque box to fender brace pictures
- I didn't know these existed...
- How much Freon
- Rally Gauge Speedometer Issues
- What is this bracket for?
- Lost a friend: KPL where are you ?
- Twin Cats
- A/C blower wheels and "spacers"?
- 1969 Trumpet Style Tips - Pypes Exhaust
- Tool J-22647
- AC O-Rings Question
- Adding 2nd rear deck speaker 1970 cutlass Supreme
- Heater core replacement help!
- 88 Cutlass Supreme Classic Gas Tank Lines???
- Does Anyone Make An Header Back Exhaust Kit That Fits?
- Evaporator Coil Replacement
- Dimensions for 65 cutlass column shift lever?
- Need Info For Heavy Duty 4 Core Radiator Lower Core to Fan Shroud Mounting
- fuel tank sending unit suspect
- A/C question about dryer and expansion valve
- Anyone in the Calgary, Alberta area?
- Fan Clutch - solved an old issue
- 68 442 A/C Components
- Convertible Top Install Question
- 1986 oldsmobile cutlass problem
- Quarter window chrome reveal attachment
- Underhood cleanup
- Hood issue
- Concourse USA 630 radio
- 88 Cadillac Brougham FITECH EFI
- A/c compressor rebuild
- A/C vent issue....
- 1959 Chevrolet Bel Air vs. 2009 Chevrolet Malibu IIHS crash test
- Canadian Part Source?
- ISO 1969 cutlass radiator core support
- Air Conditioning Hoses 71 442
- Hanging exhaust system
- Power steering pump problem
- Window Track Roller ?
- Looking for a Key Holder
- Window Track - Felt Washer
- Vacuum lines
- Black plastic 'push-pins' for roof rail weatherstipping
- Interior trem
- 1977 Cutlass low volume of air out of dash vents.
- Teaching (not my) mom how to do a burnout in her 442
- 73 Cutlass VIR A.C. system compressor seized- which way to go
- BPOCGMC car show
- Hand Porting Cylinder Heads on an Olds 455 Big Block with Legendary Joe Mondello
- Conv top lift cylinder leaking
- Youtube described as "An Angry Oldsmobile"
- Best way to ship headers
- Olds Limo 8 Door 28' 185" Wheelbase Dually
- 1948 Power Steering '98
- Sanden-style compressor belt
- 70 W30 Triple Black Vert 4 Speed
- Annoying sound
- Eastwood Almost Chrome spray paint?
- 1965 Air Conditioning Help
- 1984 olds 98 a/c compressor won’t kick on R134a
- Radiator fluid coming from under dash
- Manual Window not Going All The Way To The Top
- Bumper jack shaft restoration
- Oldsmobile Futuramic Commercials (1948) - COLORIZED/RESTORED
- Seat Belt Retractor Tension Levers Don't Seem Right
- Gen light staying on
- 1969 Hurst / Olds Convertible Show Car
- Window noise question 🤔
- 1968 Hurst Olds - vintage road test
- Filler neck screen?
- Dragway Olds Videos ...
- 89 custom cruiser acquired. New to olds
- Mysterious Molding
- Olds, Alberta, Canada has an annual Olds Car Show
- 1972 Oldsmobile Delta 88 and 98 Commercials and Crash Test
- A/C refill procedure when it had leaked out R134 converted
- 73 Delta 88 quarter window roller replacement
- Correct fuel cap
- Okay I'm stumped
- TV Ad - 1962 Oldsmobile Starfire Featuring Florence Henderson
- 1971 Olds 442 W-30 4-speed Convertible - vintage road test
- Die hard olds video #2 oldsmobile drag racing excitment!
- 1970 Cutlass S vinyl top trim.
- 1971 Oldsmobile Cutlass Commercials
- Steering column
- Treasure trove😀😀😀
- rad support bushings
- need help
- 2001 Mondello Olds Powered Drags Finals - Byron Dragway
- 2 hoses from charcoal canister.....what do they do?
- Added 2 70 442 to my stable
- 1969 Hurst Olds vs 1965 Buick Gran Sport - STOCK DRAG RACE
- Byron Buick Olds Pontiac Quater Mile Runs
- 1970 Sport Mirror replacement glass
- 1980 442 Power Window Issues
- Ignition key same as door key??
- Oldsmobile 442 Commercial (1966)
- New AC compressor w clutch
- UNC Set
- Evans Antifreeze and bad heater valves
- Most Innovative Car Of The 1960s: 1966-1970 Oldsmobile Toronado
- Picture of Olds Rally (?)
- F85 wiper motor
- Lego 442's
- Car & Track TV 1968 HO Road Test
- Glove Box Lock
- Broken A/C hose Repairable?
- More AC woes:(
- American Made Cars Timeline - Olds #1
- Decal placement help
- Dorman fuel tank sender
- Rear Window Trim
- Vintage air w/OE fan?
- 1965 oldsmobile commercials - 442 cutlass 98 delta 88 vista cruiser
- Installing AC parts and the stuff just won’t fit right
- 68 cutlass kick panel
- Vent window internal crank
- A/C not cooling well - ideas?
- AC question and Intermittent noise coming from air vents
- 1966 Cutlass Supreme A/C Compressor??
- 67 442 Speedometer Cable Length?
- Door Weatherstrip
- Rear seat speakers
- Steering box
- 67 Post 442 Chrome on Quarter Windows?
- Looking for water hoses F-85
- ISO gaskets screws
- Radio and 8 track player removal
- What are they worth?
- RapidAir MaxLine compressed air lines
- Oldsmobile Vista Cruiser Youtube (Many Still Pictures)
- Starter question
- 1984 Delta 88 coupe windows are crooked - help
- 1973 350 rocket rods install
- FE 1/4 Mile Drag Racing (Car Wheelies)
- Comparing radiator fans
- Oldsmobile Rocket Engine Plant
- Body By Fisher 1955 (Promotional Film)
- Global Warming and California Drought
- convertible top frame removal
- Trumpet exhaust tips
- Firewall Grommet for A/C Vacuum Lines
- Pontiac 455 casting and machining & assembly for original production in 1970.
- 1966 442 mirrors
- 1970 gm fisher body assembly line production
- 72 Cutlass - window "wobble"
- Exhaust size
- Ram air hood
- "Keep Your GM Car All GM" Air Cleaner Sticker
- 1966 98 Steering Repair
- Dealer showroom light boxes
- Newbie Help needed 98 interior water leak
- 70 Cutlass W-31
- Heater core oddity
- What to use on faded vinyl top?
- B body rear doors
- DIY A/C System Flush
- Noise from lifters
- Members use Eddie Motorsports Billet Aluminum Hood Hinges for 1969-72 Olds Cutlass?
- Manual operation of convertible top
- job you hate most on these cars
- 1996 Olds 98 trunk mat
- Bad vibration - ideas welcome
- Rubber bumpers install
- Need Help With 1968 Power Antenna installation
- 1970 Cutlass w31 hood latch/louver stuck
- IDENTIFY hot air tube, single exhaust?
- IDENTIFY hot air tube to air cleaner
- ISO Floorboard Clips??? Not sure what they would be called.
- 1968 No A/C with 35A91 Vacuum Trunk Release Need Help
- 68 442 convertible top - plastic or glass?" __________________
- 1972 442-Pictures or layout for mounting holes for front bumper guards?
- Muffler recommendation, Dynomax?
- 67 Cutlass Supreme Heater Control Head with AC
- Firewall Grommet
- D88 fuel economy gauge
- Weather stripping clips
- 1969 radiator support
- 1970's GM column ignition switch security?
- Best car cover
- exhaust manifold heat shroud
- Suspension
- A little promotion
- 71 Vista Cruiser dual exhaust
- Rear window glass
- Should I straight pipe it?
- 231 to 307 swap questions
- help, cannnot get 455 into my cutlass
- Help ! Car goes into full acceleration with no gas’
- Question for headers
- 72 455 not starting after tach hookup attempt
- How do I make my car road trip reliable?
- Pro6ten Install
- Power antenna cable 77 ninety eight
- Is this a vented gas cap?
- Need Pic of 1968 Radiator Support 4 Core Lower Shroud Mounting Area
- Help Neded: Questions on changing my 1968 to a 4 core radiator
- Transport Buckets from Charleston WV to Carlisle Anyone?
- Convertible top “pauses”
- Convertible top pump fluid question
- Heavy Duty Radiator Upgrade Be Cool US Radiator
- 72 cutlass 442 w/350 convertible questions
- 1975 Olds Antenna
- 72 442 Air Conditioning
- 1971 Cutlass / 442 heater box cable adjustment
- I know, I know...not period correct ..but still vintage...
- Quadrajet Carb Question
- 95 olds cutless AC question, no pusher fan, cluch dont turn
- What do you keep in your trunk?
- A/C Brackets- Need Help
- Exhaust Opinions
- Delmont has gauge
- Timing light recommendations
- Heater Control Valve
- Heater core and blower motor
- Bucket seat extensions
- heat shroud
- AC bracket questions...
- "Grill Badges"...
- engine ground strap
- Radiator, thermostat or water pump
- Ram air scoop placement
