Which Coolant w/Factory Aluminum Intake?
Old Mar 12, 2022 | 06:57 AM
Sugar Bear's Avatar
Looking for coolant recommendations please. FWIW, Valvoline's site suggests Zerex Original Green.
Non-Olds '69 iron block and heads with a factory aluminum intake. This intake is rare, the goal is to protect it as the car is completely original with 39k miles.
The radiator is out for a re-core, any thoughts on adding a sacrificial anode to the system in the radiator? Any other ideas?
Thanks in advance!
Old Mar 12, 2022 | 10:12 AM
Any ethyl glycol coolant will work. I've personally have never used an anode.
Old Mar 12, 2022 | 11:02 AM
If you're using Zerex Original Green it's doubtful you will gain much w/ the sacrificial anode. There's one nifty little ingredient in Zerex Original Green (and, most likely others of similar quality) and that's Disodium Tetraborate (think Borax) - that's right Twenty Mule Team Borax. Disodium Tetraborate is a unique borate acid which easily dissociates in solution to reduce corrosion by acting as a pH buffer; albeit, thereby reducing the metal etching and rendering salts (ions) into the coolant system - in a nutshell, Borax (in the correct titration i.e. amount) will reduce corrosion of the coolant system. Of course, the most important factor of any coolant system is to employ distilled water (preferably de-ionized water). The fewer the ions, the less corrosion. I use Zerex Orginal Green in my '71 CS.
Old Mar 12, 2022 | 11:41 AM
I agree with the above. Ethylene glycol coolant with regular replacement intervals and no issues with aluminum intakes on a iron block for over 25 years now.
Old Mar 12, 2022 | 11:44 AM
VC455's Avatar
Barely Registered
Norm gave a good summary of the corrosion protection details for conventional, premium antifreeze. As he said, it gives great protection for all metals in the system.
Here's more of what you need to know:
  • CO2 from the air dissolves in the anti-freeze and depletes the action of the borax. Therefore, effective antifreeze life is limited and you must replace it periodically.
  • An anode will only start working when the anti-freeze is depleted. It's of no use unless you fail to maintain the antifreeze.
  • You can extend the antifreeze life by switching to a closed system where there is no air space under the radiator cap.
  • You can extend the antifreeze life indefinitely by adding a coolant filter with an anti-corrosion pellet. However, you must continue to change the filter on a schedule.
  • In all cases, you can monitor the antifreeze condition with pH paper from the drug store. As long as pH is above about 7.5 there is some life left.
Old Mar 12, 2022 | 01:18 PM
Sugar Bear's Avatar
Awesome info, thanks to everyone. Was hesitant to ask but glad I did, learned plenty.
Old Mar 12, 2022 | 03:07 PM
scrappie's Avatar
Question while I have you brainiacs attention: Is the water you empty from a dehumidifier considered distilled water?
Old Mar 12, 2022 | 03:08 PM
No
Old Mar 12, 2022 | 03:16 PM
Water distillation is the process of producing a distilled end-product which has evolved over a minimum of one, generally more, boiling>condensation processes. A true distillation begins with the boiling of the water, in which a water vapor is produced (some heavy contaminants remain) from boiling, the water vapor rises and is condensed (cooled) to reform more liquid water. After yet another (and more) boiling>condensation processes, more & more contaminants are left behind until a final (end resultant) distillation process produces the required distilled water.
What's important to understand is (1) Boiling of the liquid water achieves (2) Water vapor (gas phase) (3) Condensation (Cooling of the vapor phase) with a resultant less contaminated (distilled) liquid water. Each distillation phase will produce a better distilled end product of distilled water.
Old Mar 12, 2022 | 03:26 PM
VC455's Avatar
Barely Registered
There is no ionic material in it. So, from that standpoint, it is equivalent to distilled water. However it does have a lot of dust in it, so it fails the purity test in that regard.
Old Mar 12, 2022 | 03:46 PM
That isn't necessarily true. Distilled water contains ions, deionized water is depleted of ions. Deinoized water will not conduct electricity and must go through an ion exchange resin to yield deionized water. Distilled water contains ions - it will conduct electricity.
Old Mar 12, 2022 | 04:11 PM
Consider water to exist in the normal three phases: solid, liquid & gas. Each phase can contain ions (positively charged cations [+] & negatively charged anions [-]). The process of distillation removes impurities/contaminants - it's often the end-user who elects what level of impurities/contaminants remain to accept the distilled water end-product for its applicable use. The process of distillation CAN remove SOME ions but it will NOT remove most ions. Ions exist in water (in any phase) as things known as Sulfate, Sulfite, Phosphate, Sodium, Potassium, Manganese, Magnesium, Iron, Chlorine, - e.g. primarily Earthen salts. They exist in these phases as ions Fe++, Fe+++, K+, Mg++, Cl-, etc., etc. Ions dissolved in any solution conduct electricity - distillation does not remove ions from any phase during phase separation (e.g. liquid>gas>solid>liquid>gas, etc.). It renders the end product as distilled - having removed impurities which settle from the gas phase as impurities. An ion exchange resin is charged with ions of the opposite charge state to remove select ions from water. The beginning point of an ion exchange resin process is the employment of distilled water (water free from impurities/contaminants - we're not talking about sludge here, we're talking about impurities of the atomic weight scale - e.g. molarity/modality of water). So, we begin w/ distilled water (which is charged with ions (cations & anions). The ion exchange resin (several types are used) are charged with very heavily saturated cations and/or anions. As the distilled water passes through the ion exchange resin, the cations and anions contained w/in the distilled water are removed and remain stuck to the ion exchange resin - rendering a DI (deionized water) depleted of all ions and incapable of conducting electricity.
Old Mar 16, 2022 | 07:57 AM
Sugar Bear's Avatar
Thanks to everyone for the education!!!
cdrod
Jun 8, 2021 04:00 PM
whiskey runner
Mar 21, 2014 01:24 PM
my442conv
Aug 22, 2011 12:34 AM
southcarolina803
Jul 2, 2008 07:14 AM
77omega
May 10, 2008 09:47 AM
