HELP PLS, CARBERATOR UPGRADE
Old Jul 1, 2008 | 07:06 PM
southcarolina803's Avatar
71'OldsCutty
i am currntly running the factory 2 bbl rochester carb, my friend is sending me a holley 600 4 bbl, the engine is the factory 350 v8 5.7L that came with the car, i know i need an intake manifold but im not sure which one, can any one give me a direct link to one that will b perfect of look on summit for one for me? and also tell me what other parts i need...
Old Jul 1, 2008 | 07:49 PM
marcar1993's Avatar
You need any 4bbl sbo intake. Go to a junk yard and pull one off any sbo except the 307 or a 260. Or, if you want to lose a litlle weight too, you can get a eldelbroc performer intake. It flows as well as a stock intake (maybe a VERY little bit better) but it's a lot lighter(aluminum). Plus you can buy them used for not much more than a cast iron intake. Maybe $50-$100 for an aluminum intake, or $25-$75 for an original cast iron intake.
Old Jul 2, 2008 | 07:14 AM
Actually, the aluminum A4 intake from the early (non-roller) 307s is a nice, inexpensive intake to use. Flows just as well as the iron SBO intakes, but weighs less.
dschallock
May 12, 2011 09:01 AM
sx455raidercelticfan
Oct 8, 2010 03:22 AM
lene
Apr 6, 2010 04:34 PM
Sam Barrett
Nov 4, 2009 06:46 AM
southcarolina803
Jun 30, 2008 07:12 PM
