PDA
View Full Version : Parts For Sale
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130
  1. Various Oldsmobile parts on ebay 10/12/15
  2. Two 6" water pumps.
  3. W manifold for A body.
  4. 67 442 headlight bezel.
  5. 75 or 76 455 HEI distributor.
  6. 70-71-72-nos-oldsmobile-cutlass-442-w30-back-up-lenses
  7. A/C NOS spark plugs.
  8. 68 442 exhaust manifolds
  9. 67 Cutlass NOS Backup Lens
  10. 66 big car nos rh headlight bezel
  11. 67 98 nos left grille extension
  12. Cutlass bucket seat head rests black
  13. Seat Foam for gm a-body buckets
  14. 1971 cutlass/442 seat covers Black
  15. NOS Delco Remy coil 1115134 1965 1966 1966 Cutlass or 442
  16. 1971 cutlass/442 tail light assemblies
  17. 70 - 72 Floor shift non tilt steering column - black with ignition and turn signal
  18. 70 - 72 Floor shifter with cables and Walnut Shift knob
  19. a/c delete firewall box with instructions
  20. 70 - 72 Oldsmobile Cutlass Heater Control Panel without A/C with cables and wiring
  21. NOS Delco Remy coil 1965 1966 1966 Cutlass or 442
  22. 65 Cutlass Parts
  23. 67 Cutlass Supreme 4 door doors and parts
  24. 1974- 1976 fullsize dash bezels
  25. Hurst 4 speed shifter 1967-1968-1969 F-85 Cutlass and W-31
  26. 1971 1972 dual snorkel air cleaner breather
  27. X water pump, rebuilt, 326 date
  28. Hvac control unit 1974-1976
  29. 1968 Cutlass convertible doors
  30. Parts for early single- and dual-range Hydramatic transmissions
  31. 1111468 distributor
  32. 1966 Toronado for sale - parts car
  33. 1971 442 air cleaner
  34. 69 70 71 72 442 Fender Emblems—Real GM
  35. 52-55 Carter 4V
  36. 68-72 Cutlass A-Body f-41 4 speed bars..triangulation bars
  37. B.O.P 8.2 Rear End
  38. 68-69 Cutlass 442 Convertible Top Switch
  39. 1971-72 Cutlass 4 door rear defog glass & wiring.
  40. 1993 Cutlass Supreme Parts Lot $15 US
  41. Used 1974-ish Dual Gate Shifter & Console Plate For Sale
  42. Wheel well rock guards
  43. Brand NEW Delco Remy voltage regulator
  44. 1968-72 A body convertible misc. parts
  45. 1985 Oldsmobile Cutlass Calais Indy Pace Car front plate..
  46. NOS/Used G-body Front End Stuff
  47. Qjets
  48. 1949-56 Moon valver covers
  49. 65 Cutlass or 442 Rear 1/4 mldgs
  50. 67 442 Fender Emblems
  51. type o housings and axles
  52. 67 Cutlass Supreme Mouldings
  53. GM 3.73 3.08 2.73 10 bolt 8.5 gm
  54. mini spool 8.5 Motive gear
  55. 56 & 57 J-2 tri-power setup
  56. 62 starfire conv & coupe for parts
  57. 1974 Cutlass 4-Dr Being Parted
  58. 1968 Quadrajet 75-76
  59. Cruise control parts/pieces, late '60s to mid '70's?
  60. FS: ONE Center Cap for 1965 N93 Wheelcover
  61. L-69 Tricarb bare intake, Rebuilt 403 $1200 ea MI
  62. 1967 Olds Cutlass parts.
  63. 71-72 W30 intake 7-71 date code
  64. 1971-1975 DELTA 88 Convertible passenger side 1/4 glass
  65. 1971-1975 DELTA 88 Convertible PASSENGER DOOR GLASS, & passenger 1/4 glass
  66. 12 bolt 'O' posi units back in 3 series Eaton
  67. 350cid 14cc stock pistons
  68. New Offenhauser 360 Dual Quad Intake
  69. (4) SSI wheels 14X7
  70. 83 HO Folder..
  71. Flowtech SBO ceramic coated headers
  72. NOS 84 H/O Front Plate
  73. 442 - factory 307 hyd roller cam
  74. NOS 1960's Olds Engine Equipment Tester Carlisle Pa. swap meet
  75. 403 olds engine w/350 trans
  76. OEM original Temp senders for gauges
  77. Early model carter 4v
  78. 65 olds engine parts
  79. Olds SS-IV wheel 1971-1974 Delta 88 near NOS
  80. pr 1960s Goodyear Power Streak II exc tread
  81. 1968/69 olds 442 factory spoiler for sale
  82. 1971 Cutlass "S"/442 Assembled Door panels front and rear Black
  83. 15 inch olds trim rings for sale
  84. Have a 69 HO? You NEED this!
  85. 72 License plate holder and tail light lenses
  86. 1978-1988 g body factory rallye cluster pack working km/h canadian with small mph
  87. Olds valve covers Carlisle Pa. swap meet
  88. SSII bolt on center caps
  89. "Testing The Waters" 350 Olds and KOOKS 64-67 S BO Headers - Might be FOR SALE -
  90. NOS exhaust manifold lock straps x 4
  91. 1970-72 Cutlass 442 AC plastic manifold
  92. 68 front header panel
  93. 68 metal torque converter cover
  94. 15X7 bolt on center cap SSIII (only one)
  95. 70 442 Hood tongue and heat shield
  96. 4 Spoke Olds rally wheel
  97. Possible '76 Toronado Parts Car
  98. 68-72 A body frame Hickory NC
  99. ~70-72 Tail Panel W/Frame Mounting Brace, Trunk Ledge Too.
  100. 70-72 Cutlass / 442 convertible door fuzzies
  101. 68 Cutlass 442 black glove box door
  102. P/N 413285 1973 88, 98 emblem
  103. Serpentine kit for BBO
  104. 1966 cutlass, 442 front and rear bumpers
  105. 1966 442 distributors
  106. 68-72 vista glass
  107. 2 speed jetaway rebuilt
  108. B heads
  109. 4-Spoke Rally Steering Wheel
  110. Seat belts 71-76 full size
  111. 1970 L intake
  112. Hurst Bench Seat Shifter Handle
  113. Oldsmobile Skyrocket Ultra High Compression Air Cleaner
  114. 15" rims - bolt on centers (2)
  115. Machined 4A 403 heads
  116. 1953 Olds 98 steering wheel emblem
  117. 68 Hurst Olds Emblema
  118. 66 67 Cutlass/442 Boxed Frame
  119. mid 70s Olds 350
  120. 68 Cutlass (442) Front Fenders/Doors--Real GM
  121. 1970 Cutlass Supreme Interior—Dark Green
  122. WTB: NOS Burlwood console ashtray lid- G-body
  123. conv top frame/ scissor top, 1971-75 88'
  124. 1974 Delta 88 concvertible, parting out
  125. 1949 Gas Tank
  126. 1974 supreme grills
  127. used comp cams 1442 roller rocker kit
  128. 1978 chevy qjet
  129. T3 high beams
  130. 7043251 qjet
  131. Custum 442 70-72 Console Shifter For 4 Speed
  132. E Heads Fresh
  133. Olds Motor Works padlock with key.
  134. F/S - Heavy Duty Front Springs
  135. 455 and 425 Engine Parts
  136. F/S - 1970-1977 4 Spoke Wheel - Driver Quality
  137. NOS TIRE 1970-1972 Olds Cutlass W-31 442 W-30
  138. Wilwood Tandem MC - 7/8" bore Black Oxide Finish
  139. 1972 Olds shop manual
  140. Lower Air Dams 1968-1971 Olds Cutlass 442
  141. 1970-1972 Cutlass 442 Hurst Olds Black Dash Pad
  142. 62 F-85 Grille Emblem
  143. 67 442 Grille
  144. AT stuff almost new for sale. converted to a 4 speed.
  145. 70 - 72 headlight bucket/trim
  146. LH Drivers Bullet Mirror
  147. Original Ram-Air air cleaner 1970-1972 Olds 442 W-30
  148. B&M Quicksilver shifter
  149. 1970-72 Olds 442 Ram-Air air cleaner GM restoration parts
  150. NOS 1960's Oldsmobile parking light warning light
  151. 71-72 cutlass trunk lid
  152. 71-72 cutlass 442 core support
  153. 1968 Cutlass 442 Hurst Olds headlight housings and bezels
  154. 70 Black Buckets and Back Seat Combo Ready to Go
  155. 68 Cutlass Headlight Bezel
  156. 68 Full size quarter side markers 88-98
  157. 61-62 F-85 Taillights
  158. Selling my 68 auto console cutlass/ 442
  159. 70 Cutlass Supreme tinted quarter glass
  160. 83-84 H/O 15x7 Chrome Rims
  161. 1985 442 Steering Wheel
  162. 1963 Olds rear bumper nice!
  163. 65 and 67 Wheelcovers
  164. Oldsmobile rally rims/wheels Great shape White 1979
  165. 77 Cutlass Supreme
  166. 77 442
  167. forged steel 455 olds crankshaft
  168. FUEL TANK nos
  169. Misc 4 speed parts, not sure of years or application.
  170. 1963-66 Nice complete working Reverberation unit. Fits all Olds. models.
  171. Badge type SSIII centercaps/stock radio for 72 Cutlass S
  172. parting out 1974 Delta 88 convertible
  173. 1963 Super 88 2dr hdt top for parts
  174. 1965 f-85 2 door coupe.
  175. 1965 f-85 2 door coupe.
  176. Fresh 461 short block
  177. ~68-72 Floor Pan W/Lower Firewall,Cowl,TB
  178. 1972 10 bolt 2.73 posi rear end. $450.00 plus shipping
  179. 1963 Starfire conv frame
  180. 1969-72 Inside rear view mirrors, resilvered, lighted & non lighted
  181. 1974-76 delta 88 glove box
  182. 1975 DELTA 88 tailight bezels
  183. 1974 delta 88 front fillers (grille)
  184. 1974 delta 88 right rear bumper filler
  185. 1971 -73 Delta 88 Dashboard parts
  186. 68 69 Cutlass S (Model 87) or 442 2-door Hardtop Rear 1/ 4 Windows –
  187. 68-72 Cutlass Transmission Cross-members --Hardtop and Convertible --GM Parts
  188. 1968 Cutlass 442 Optional N-95 14” Wire Wheel Hubcaps
  189. 68 Cutlass 442 Air Conditioning Vents—Nice Chrome
  190. 69-72 Cutlass 442 (GM) Convertible Top Frame and Other Convt. Parts
  191. 69 AM-FM 8 Track Stereo all three pieces
  192. g body NOS cutlass 442 hurst olds
  193. 1970-1977 olds 442 4 spoke sport wheel black complete
  194. 1968 muncie m20 rebuilt.
  195. Edelbrock carb
  196. Parting 1966 Toronado
  197. Power trunk release button
  198. 1971 442 front grill set
  199. Hurst/442 Trumpet exhaust tips
  200. '70 - '72 Cutlass inner fender wells, black
  201. '70 - '72 W30 Red Inner fender wells
  202. F/S - Eastwood Premium Spot Weld Cutter
  203. 1970 ONLY Cutlass Fender, No Rott .
  204. NOS 1960's Oldsmobile Accessory Reverberator
  205. lots of olds 455 performance parts,RR heads,Arias pistons, roller cam, engine, etc
  206. 455 '73-74 exhaust manifold driver side
  207. NEW holley valve covers
  208. 68 W30/W31 air cleaner
  209. 65 cutlass/442 grille
  210. 71-76 fullsize coolant overflow & windshield washerreservoirs
  211. 1973 Delta 88 tail lights
  212. 1974 Delta 88 taillight assemblies, left & right
  213. 1984 -87 full size rwd nos impact absorber {bumper shock}
  214. 71-76 full size head rest & armrest {white}
  215. 1975 Delta 88 left side quarter panel extensions
  216. Wilwood D52 calipers, ss lines and EBC red stuff pads
  217. NOS Graphic Equalizer power booster 1978-1988 Cutlass 442 Hurst Olds
  218. Oldsmobile 4 spoke steering wheel, red color, complete
  219. Parting out 1974 Delta88 conv.
  220. 1968 Cutlass Passenger fender
  221. 1966-67 Cutlass 442 98 fan shroud
  222. 20oz Ram Rod 350 Mugs
  223. Dog dish centers
  224. 1981-88 Cutlass amber bumper signals and headlight bezels
  225. Hurst Olds dual gate shifter with brackets and cable
  226. 1968 Cutlass/442 sunvisors
  227. 1968 Cutlass Headlight Bezels NEW
  228. 1968 Door panels
  229. 68 Cutlass Right Tailight
  230. 68 L/F wheel well molding.
  231. 70-72 Gauges, Grills, Sport Wheel / NOS G-Body Lower Door Panels
  232. 455 Block F/S
  233. 1969 Cutlass radio
  234. 1968 Cutlass hood hinges
  235. 7 58 59 J2 Tripower
  236. 1970 am/fm stereo B body maybe?
  237. 8 track player
  238. 1956 OLDSMOBILE 88 2 Door HT for parts
  239. Paint stencil 70 72 cutlass
  240. Few parts for sale (Dallas TX will ship)
  241. 57 olds rochester 4 bbl carb.
  242. Parts that need a home
  243. 15x7 Hurst Olds Chrome Rims
  244. Milodon oil pan
  245. '67 olds 442 -part out- factory 4sp car
  246. 1970 Cutlass Supreme taillights and parking lights - nice
  247. 70-77 Cutlass/442 4-Spoke Steering Wheel
  248. Selling 1961 88 &1962 98 parts
  249. 1969 400 starter 1108348 and original solenoid
  250. 1964 - 1965 Muncie M-20 Transmission
