View Full Version : Parts For Sale
- 1972 350 Engine for Sale
- Olds 403 Engine for Sale
- O-axle 4:33 ring and pinion
- 68 to 72 Cutlass post car B pillar moldings Nice!
- Heavy duty cool
- Petronix Points to Electronic IGNITOR 1181 KIT and Flame Thrower Coil GM DELCO V8
- 1969 F 85 / Supreme tail light lenses and backing plates
- 1969 Cutlass 442 hood latch receiver
- 1970 Cutlass 442 key lock set - original with keys
- Cutlass 442 Rearview Interior Day Night Mirror
- 68 Cutlass 442 Hood Grille Inserts
- 1968 Cutlass 442 Black Floorshift Steering Column --Nice GM
- 350 dx block
- 1968 Cutlass-442 Door Latch
- 68-72 Cutlass 442 Front Armrest Set --Black
- Cutlass parts 67/72
- 69-74 Oil Sending unit / Transducer for Rally Pack Gauges
- 1964 Cutlass Drivers Side Fender $325
- 68 69 70 Cutlass 442 Interior Dome Light-- Nice GM
- NOS 1970 Hurst Dual Gate NSS Olds 442 W-30 Cutlass W-31
- '69 - '70 ORIGINAL hose clamps - double wire bypass hose clamps - may need
- 1969 1970 Olds F-85 W-31 Steering Wheel
- 71-73 delta 88, 98 clocks
- 71-73 full size and Toro AM 8 track radio and amplifier
- 1970 Cutlass/442 headlight grill section mount, left
- Cutlass passenger side interior kick panel
- Delta 88, 98 AC Muffler 1971-72
- 1969 Cutlass 442 Rear Back-Up (Reverse) Lights Set --GM
- Brand new in box CVR 5311 mini starter
- g-body parts
- 70 Cutlass w31 parts / W30
- Parting out 1975 Delta 88 convertible
- Original Brake Parts, '71 Cutlass
- Aftermarket HEI distributor
- Aluminum water pump 381288 from a 1964 330
- 68-72 Cutlass F-85 442 W30 B90 Post Coupe Window Trim
- 1971 Date coded glass
- NOS beautie rings cutlass 442 14 inch # 9796919
- 1966 88/98 left and right bumper ends
- 1964 Olds Starfire Custom Wood Rim Steering Wheel
- 69 Rear Side Marker Light. Cutlass 442
- Big block heads for sale, 1964-76
- 68-72 Cutlass 442 Convertible Visors-- Nice GM
- 1970-1977 Sport Steering Wheel w/Grain Cutlass 442 Hurst Olds
- 1971 442 Bumper jack hook 409290 with rubber pad
- 69-72 Radiator Top Plate 2/3 Core
- PS reinforcement panel.
- 1968 CUTLASS S Glove Box Door Plastic with emblems 68
- 72 Cutlass Intake and Brake parts
- 72 Cutlass 350 Alternator 37 Amps
- 1968 442 Grille
- 1971-72 Cutlass 442 Front Headlight Assemblies
- "LA" Crank Pulley
- 1969 Cutlass 442 Front Headlight Assemblies
- A Body Bell Brake Drums Cutlass 442
- 1968 NOS 442/Cutlass Hold in relay for Air conditioning
- 1970-72 Cutlass Drivers quarter panel for patches
- Full sized Olds, or Toronado, early 1970's (?) Tilt and tilt tele columns
- 1964-66 three on the tree column for parts $20
- 1954-55 bits and pieces for sale
- 75 Delta 88 Convertible part out
- '57-'58 371 Roller Cam/Rollers/Adjustable Rockers/Push Rods
- 1968 Cutlass hood hinges
- Mid 80's 442 Center Caps - Set of 4
- 64-67 OEM 330/425 Flex plate
- It's a shame to toss good stuff...
- "KF" 3 Groove Waterpump Pulley
- 1954-55 Olds rear ends
- 1955 Olds suspension parts
- 1955 Olds 98 sway bars $50 plus shipping
- BB 455 "N" Nodular Crank
- Thornton W Z 455 manifold set (new)
- Edelbrock 2151 big block intake
- Starter Brackets
- NOS Rally II center caps #402926
- 1966 Toronado NOS Tail Pipe Extensions (Two)
- 68-72 Cutlass 442 Convertible Door Wedge set—Complete GM
- 1970 Cutlass 442 Black Seatbelt Set - Real GM--Nice
- 68-72 Olds 350 400 455 Alternator Bracket Set
- 1971 OEM 8 track Face Plate Woodgrain
- 1969 Cutlass 442 Left-Right Headlight Bezel Set- Nice GM
- 72 Cutlass Black Rear Retractable Seat Belts
- 68-72 Olds 350 400 455 Power Steering Bracket Set
- OEM Harmonic Balancer/ Damper
- 1- VxxxxG C head
- 70-72 Chrome Remote Side Mirror
- For Sale, Engle Roller Cam #153
- NOS Engine Rocker Arms 1959 1960 1961 Olds 88 98 Starfire
- 70 71 72 Cutlass 442 Optional T-44 Hood Latch-Lock Setup
- 69 455 88/98/Toro distributor 1111935
- Sport Steering Wheel 1978 1979 Cutlass 442 Hurst Olds Delta 88
- NOS Cassette Tape Player 1971 1972 Cutlass 442 Hurst Olds
- Black Steering Wheel 1970 1971 Olds Cutlass 442 Vista-Cruiser
- 1954-1956 Oldsmobile Rocket 88 324 engine
- 1966 1967 Oldsmobile Toronado Trim Rings and Center Caps Excellent Condition
- 11969 Cutlass 442 Rear Bumper Bracket Set-- Real GM
- 68-72 cutlass convertible pinch weld moldings and A pillar moldings
- 68-72 Cutlass 442 Convertible Upper Rear Interior Panels
- 70-72 Vinyl Top Chrome Corner Caps
- 1968-72 Cutlass 442 5-blade Clutch Fan-- Real GM
- 1961 Olds F 85 Headlight Bezels NOS with original box's and part numbers.
- 1970 A/C control with rear defrost
- Carburetor Choke Unit 1968 1969 Oldsmobile Toronado
- 68-72 Cutlass 442 Convertible Windshield Header Trim--(2 pieces).
- AC CruiseMaster Transducer 1969 Cutlass 442 Hurst Olds
- 1969 Cutlass Grilles-- Nice GM
- 67 68 69 Cutlass 442 Automatic Transmission Console/Shifter Setup-- Nice Complete GM
- 68-72 Cutlass 2dr Roof Side Rails, Can Ship
- OEM "OLDSMOBILE" Cast Iron Intake 350/403
- 66-67 OEM 425 Harmonic Balancer
- new edelbrock olds heads $2000 obo
- Vintage Oldsmobile Accessory Tissue Dispenser 1968 1969 Cutlass 442 Hurst Olds
- GM NOS 1967 Switches Olds Cutlass 442 Conv. Top, Pwr. Antenna
- OEM Big Block Oil Pan
- NOS Sail Panel Courtesy Lens
- Cast Aluminum Valve Covers
- Sport Steering Wheel 1970 1971 1972 Cutlass 442 Hurst Olds New Car Take-Off
- OEM 69' Toronado Battery Tray
- 1969 Sport Steering Wheel BLUE Olds Cutlass 442
- '51-'56 Standard trans conversion items
- BOP 10 bolt 3:08 posi rearend
- 68-72 Cutlass 442 (and others) Door and Window Crank Set-- Nice GM
- Scorpion roller rockers 1.7
- Unknown sill plate, cover the shipping
- NOS 1967 Olds 442 & W-30 Carb Choke Housing RP 33762
- 64-68 Cutlass 442 Bumper Jack Holdown Bracket Set --GM
- 70-72 Cutlass 2dr Hardtop Rear Seat, Can Ship
- 70-72 Cutlass 442 Rear Bumper Brackets
- NOS Oldsmobile 455 Camshaft 1968-1976 GM 400117.
- NOS BB Negative Battery Cable
- GM NOS Oldsmobile Lug Nuts for Aluminum Wheels 1980's - 1990's
- Olds 403 Shaker and Aircleaner
- Heater control valve
- Pair of #5 heads
- 69 70 71 72 Cutlass- 442 Hood Hinges-- Nice GM
- 70-72 floor shift speedo and fuel guage
- 71/72 cutlass/442 NOS stone shield
- 71-72 Front Parking Lamp/ Turn Signal Housings
- 1963 Oldsmobile Seat Belts 88, 98, Starfire, Cutlass, Jetfire
- NOS Neutral Safety Switch 57-60 88/98 - 61-62 Starfire
- 65-70 OEM 4 button Power Window Switch
- 70' OEM Cutlass 442 Front Chrome Fender Moulding
- OEM BB 400/455 Oil Pan
- NOS GM Door Strikers 1967-1987 Olds
- NOS 1967 1968 Turn Signal Switch Cutlass 442 Hurst Olds
- 68-72 OEM Window Regulators
- 78-87 Cutlass 4dr Doors, Glass and Guts
- NOS 1970 1971 1972 Tilt Column T/S Housing Cutlass 442 Hurst Olds
- 1972 Maplight Mirror Cutlass 442 Vista-Cruiser Hurst Olds
- NOS Woody Station Wagon Tail Light GM Oldsmobile 1938-1948 Guide 929205
- 68-72 Cutlass conv RH pillar post molding
- 60's era chrome "Oldsmobile" vanity mirror and frame
- 68-72 Black padded pillar post moldings Cutlass
- Edelbrock Torker 455 Aluminum Intake Manifold--Nice
- 66 67 68 69 70 71 72 Moroso 68300 Chrome Valve Cover set --Nice
- 455 motor parts
- NOS R.H. Parking Light 1968 Cutlass 442 Hurst Olds
- 71 "G"Head and 72 "GA" Head
- 71 "G" Heads
- 4A Heads
- 72' 8 Track Face Plate
- 1970 Vista Cruiser hood for free!!
- Excellent W Z manifolds
- 1953-54 Oldsmobile power steering column 400+ ship
- 69-72 Cutlass 442 OEM Coil Bracket.
- 1964 olds cutlass f85 core support
- Factory Oldsmobile Mini-Console 1971 1972 1973 1974
- 81 Toronado misc.
- 70-72 Cutlass 442 Glove Box Door Hinge
- 1971 - 1972 Cruise Control System
- 71-72 Cutlass 442 Taillight Housing Shields
- NOS Courtesy Lamp Package 1953 Olds, maybe 1954 and 1955
- 1971 1972 Cutlass rear bumper brackets blasted/ powder coated
- 71-72 Pass side Sport mirror
- NOS 1957 Oldsmobile 88 model Tail Light Lenses
- NOS Accessory Trunk Light 1971 1972 Oldsmobile 88, 98, and Toronado
- Crankshafts, 303, 324, 371, 394 $125 ea plus shipping from Oregon
- 68 or 69 cutlass pieces
- T/A alternator brackets
- NOS PVC Valve Cover Grommet
- NOS 65 Full Size 88/98 Neutural Safety Switch
- 1970 Cutlass Grilles
- Back seat for 1970-72 Cutlass Supreme $125 + shipping
- NOS Blower Motor Fan (squirrel cage)
- 72 NOS Deluxe Seatbelt Shoulder Harness Cutlass 442 H/O
- NOS 1963 Oldsmobile Seat Belt 88, 98, Starfire, Cutlass, Jetfire
- QA-1 Front Lower Control Arms 52920
- QA-1 Front Lower Control Arms 52737
- 68-72 Cutlass 442 Reverse Lockout Linkage for TH-350 and TH-400 Trans--
- 75-96 Right Door Handle, Black.
- Factory Wiper Bottle Hoses, Misc Hoses
- #15 cracked exhaust manifold, you cover shipping costs and its yours
- 69 Cutlass Rear Bumper Brackets
- Last set !!! 1957 - 1958 OLDSMOBILE BALL JOINTS Set of Four (4) !!!
- NOS AC Cruise Control Transducer 1970 and Early 1971 Oldsmobile Cutlass 442
- 3 NOS Antenna Masts 1967 1968 1969 Cutlass 442 Hurst Olds
- 74-76 Dash bezels. (Delta 88)
- Big car dash pad, 74-76 88-98, CC, 74-78 Toronado
- Gas Tank from 73 D 88
- Scissortop parts b body conv 71-76
- Big car glass 71-76 Convertible glass. 74-76 Delta 88 coupe glass
- Big car Grilles 71 98 & 73 88 $150 pr set
- 68/69 cutlass/442 vinyl top chrome
- 66 cutlass/442 passenger door and lower 1/4 moldings
- 68-72 Cutlass Orig Rust Free Firewall Sides W/ Door Jamb Mount Panel
- Early 70 Cutlass Date Coded Glass, Nice Drivers
- 70-72 Cutlass 2dr Door Trim, Thin ones
- 70 Vista Cruiser R-L Taillight Housings
- 455 olds intake chrome
- Oil Fill Tube from a 1967 Toronado 425 Engine
- 1970 Steering wheel center pad - Blue
- NOS 1969 Cutlass 442 tail light HOUSING - Left
- NOS oil fill cap - not sure what years
- NOS Matching Chrome Mirrors 1973 1974 1975 1976 1977 Olds Cutlass
- NOS R.H. Chrome Mirror 1976 Olds 88 98 Custom Cruiser 1973 1974 1975
- NOS inside mirror. 1972 Cutlass 442 Vista-Cruiser Hurst Olds
- NOS Remote Control Mirror 1964 1965 Olds Cutlass 442 Vista-Cruiser
- NOS Mirror 1961 1962 Olds 88 98 Starfire 580784
- Hurst Dual-Gate Shifter 1970 1971 1972 Olds Cutlass 442
- 1967 cutlass front bumper.
- 1970-1977 Sport Steering Wheel Cutlass 442 Hurst Olds
- 1968 Dash Maplight Cutlass 442 Hurst Olds
- Door Panel Escutcheon 1970 Sport Mirrors Olds Cutlass 442
- 68-69-70-71-72 Cutlass 442 radio mount brackets
- NOS speaker grille
- 1969 - 75 NOS door amb boots for power windows
- 72 front license plate bracket
- 1968 1969 Oldsmobile 400 Crankshaft from 442 with 400 FOUR Speed will work in a 455
- 63 Rochester 4GC rebuilt carb-DFW area
- 68-71 Original T3 Headlights
- 1967442 air cleaner
- Oldsmobile N31 steering wheels NOS and used
- Nice 1971 8 track player applique
- 68-72 Cutlass 442 Convertible Rear Courtesy Lights Lenses and Bezels--Nice GM
- 68-72 A/C 350/400/455 3-Groove Pulley Set --KK And KC-- Real GM
- 71-72 Sport Mirror inside Door Escutcheon/Bezel
- 1961 1962 1963 Dog Dish Hubcaps Olds F85 Cutlass Jetfire
- 69 442 J intake and 7029253 4 speed carb restored and tested
- 1964-67 Cutlass Wagon & Vista Cruiser power tailgate window regulator $40 + shipping
- 69-71 Cutlass 442 12" Map Light Rearview Mirror-Real GM-Restored
- 70-72 parts and accessories
- 70 Delta 88 NOS cowl seal 406092
- NOS L.H. Mirror 1979-1980-1981-1982-1983-1984-1985 Olds Toronado
- Odds and ends from 1964 Oldsmobile 330
- 1964 Oldsmobile dynamic 88 parts
- '68-'72 Cutlass sound deadener set F/S
- 1969 U21 Rocket Rally Pac - Restored
- 1967 Oldsmobile Cutlass 442 Vista-Cruiser Steering Wheel
