View Full Version : Parts For Sale
- 1966 7026250 Quadrajet
- NOS 1970 Olds 442 Grilles
- 1970-1972 Rallye Pac Gauges
- NOS 70 to 72 Cutlass / 442 Console parts
- BBO IR manifold ( Quad IDA, ER-13909)
- 70-72 Cutlass front dash speaker
- 70-72 Cutlass factory 350 factory a/c brackets
- 72 Cutlass factory AC switch assembly
- Brand New Legendary Seat Cover For 1970 Black Front Bench Seat
- 1970-1972 Cutlass/442 Eight Track Player
- 1970-1972 Cutlass/442 AM Radio
- 1971/1972 Cutlass/442 AM FM Stereo
- 1972 Olds 442 Grilles
- 1971-1972 Cutlass/442 Sport Mirrors
- NOS 1972 Cutlass Supreme Grilles
- F/S Richmond 4+1 street 5-speed
- 52? Engine and Trans
- 70-72 Cutlass/442 Spoiler Brand New
- TRW #82261 Motor mounts
- GM 70-72 Cutlass 442 Convertible Deck Lid in CT
- 67 convertible top frame
- 1111975 W-31 distributor
- 1965 Spinner Hubcap for N93 Optional Wheels
- Floor shift TILT column
- 1964 330/310
- 64-65-66 rear console lens (auto)
- 1970 OAI Hood
- '70-2 Cutlass/442 Factory Jack Assembly - nice restored
- 1961 394 Head Bolts
- 69-72 cutlass/ 442 right kick panel
- Non a.c. Alt brkts
- 455 N crank
- 69 442/cutlass hood
- '70 Only 442 Power Trunk Release Button
- 1970 442 Convertible Frame
- 68-72 Cutlass Floorpan Rust Free
- 70-72 Cutlass Fenders & 71-72 Hoods
- BBO Offenhauser 360 Dual Quad Intake
- 3.90 Posi 10 bolt rear end
- T400 kick down switch
- 64 F-85 only year drivers side exit 330 water pump
- 1964 Olds Slow Idle Switch
- 71 Cutlass Supreme Interior-White
- 1108348 starter for sale
- Q-jet cores for sale
- 70-72 NOS sheetmetal...
- NOS Cutlass/ 442 Tic Tach Tach Rallye Pack Tach
- 324 rocket and auto transmission for sale
- 68 to 72 tape player $350 plus shipping. It works. Ready to install.
- 70-72 NOS Cutlass / 442 fenders
- 70 to 77 Sport Steering wheel hub
- 70 to 72 Cutlass 442 console door
- 70 to 77 Cutlass/442 Sport Steering Wheel Complete
- 71/72 NOS Drivers Fender
- 1965 442
- K&N 62-63 Jetfire air filters for turbo air cleaner
- 57 58 new Fusick Fuel Lines 371 4 bbl engine
- 1970 1100890 open face alternator
- 68-72 442/cutlass package tray
- 1979 403 Bare Block and 2 complete heads
- 1970 dash pad
- 455 Nodular crankshaft
- 1969 Cutlass Convertible Parting
- '71 442 Distributor - Restored
- '67 W30 Distributor - Restored
- 4 spd parts
- SBO adapter Plates for seprentine belt set up with mechanical fuel pump
- BBO adapter plates for serpentine set up
- 1969 power window harness
- 1968 and 1969 Cutlass convertible quarter mouldings.
- 71-72 rear bumpers
- 442 rear bumper cores
- 68 442 front & rear bumper brkts
- 71/72 Cutlass/442 NOS Bumper Guard Set Complete
- 1970 to 1977 Sport Steering Wheel
- Manual Steering $125
- 80s/90s OCA license plate frame
- 1971 G heads
- 68 69 Cutlass 442 Assorted Body Moldings Excellent GM
- '61-2 Fenders
- 1969-72 Hurst Olds, W30,W31,442 OEM Spoiler
- 1962 Olds Starfire parts
- 1971 Sienna Brown NON AIR dash with fiewall and wire harness
- FRONT DISC BRAKE ASSEMBLY off of a 71 vista inclueds A-arms
- 1965 400 cid - B block and crank
- 70 to 72 Cutlass 442Dual shifter/ console parts
- 7027157 1967 BBO Quadrajet
- 307 intake manifold
- Trofeo Tailight
- Rebuilt 330 for Sale
- 1972 LH original 442 grille
- 1968/69 Olds 88/98 wheel covers, hood hinges
- Nos gm 1968- 87 interior lenses
- 70,s vintage oldsmobile collared golf shirt
- Nos gm 1964-65 floor shift boot 3842926
- Nos gm 1981-87 front bumper cover emblem
- Nos gm 1983-87 442 h/o park lamp 22511038
- Nos gm v8 rocker pivot set 22527956
- Nos gm 1974-76 455 oil dip stick tube 417091
- Nos gm 1971-72 vista cruiser fender molding
- Nos gm 1969-72 a/t bracket 402990
- 455 original gm oil pan
- 1970-72 Cutlass 442 Dash Air-Conditioning Controls and Wiring
- 1970 to 1972 Convertible Boot
- 1108389 Delco starter
- N nodular crankshaft
- 1968 442 quadrajet carb 7028251 - $300 (erlanger) Kentucky
- Black bucket seat back and aprons for one seat New with scratches on each of the 3 pi
- 68/69 vacuum door locks
- 1953 olds super 88 rear windshield
- 1953 olds super 88 re-chromed fromt bumper
- 68-72 GM Saginaw Quick Ratio Power Steering Box Cutlass 442 Vista Cruiser
- 66 442 hood
- Door Molding For 1972 Cutlass Surpreme
- NOS SSIII snap on center caps
- M/T Valve Covers
- 1966 Olds Full Size Parts
- Thornton Dual Exhaust Manifold for Full Size
- valve covers, bellhousing, intake, flywheel, clutch/pressure plate,
- Heads B,C,G
- W&Z reproduction manifolds
- 17056257 carb.
- 1964 330/310 complete
- 70-72 Cutlass Rally PAC + Floor shift speedometer
- 1971/1972 GM Ram Air Hood
- 7029253 69 442 4 speed carb
- Cutlass / 442 8 Track Player
- 425 short bock , crank #5 heads, 68 350
- 1970 to 1977 cutlass 442 sport steering wheels
- 76 gauges
- 65 Full size disc conversion
- 71 w30 waterpump
- miscellaneous 74 -76 delta 88 parts
- 1965 Cutlass 442 red interior (new PUI)
- oldsmobile 8 track player
- 1965 Engines 400 and 425
- Edelbrock torquer intake and valve covers
- NOS 1970 Cutlass S and Rallye 350 Grills
- 1966 1967 Sports Coupe (post conversion)
- 56 Oldsmobile hood hinges
- 1970-72 vista cruiser roof skin CHEAP
- Misc. NOS parts
- 1956 Oldsmobile hood hinges
- 68 to 72 Oldsmobile cutlass am/fm stereos
- Cutlass 442 rear boxed lower control arm
- 70 72 cutlass 442 console door
- 1969 speedo
- Bare "C" heads for sale
- x waterpump for sale
- 68 Olds 88/98
- 70 to 72 Hurst Dual Gate shifter
- Rear frame braces 1970 1971 Olds 442
- 1962 Starfire / 88 junk / parts - Toronto ON
- Non ac pulleys 1968-69 442
- Cutlass S Grilles
- 15 x 8 SSI Wheel - Brand New
- Original 1971 442 grilles
- Steering wheel hub
- 404632 aluminum water neck
- 73 Full Size Convertible Top Mechanism
- 67 442 dash emblem.
- 72 442 emissions canisters
- 350 4 barrel cast iron intakes
- SS III with trim rings 14x6
- 1973 & 76/77 Oldsmobile cutlass front bumper rechrome
- 7040256 carb NOS
- Olds 425 39 degree Toro block,crank, and rods
- 70-72 Cutlass/442 black lower dash section ***Update now includes a lot more parts***
- Trumpet tips - used
- 1970-1972 Cutlass Supreme Rear seat brace and package tray
- 70-72 Cutlass Rear floor section
- 70 4 speed carb 7040253
- 70 w30 parts
- Left 1972 442 grille with emblems OEM factory drivers side
- 1972 442 grills NEW
- 1969 cutlass front grilles
- 1969 442 grilles
- 1969 cutlass/442 floor shift speedo
- 1971-72 Cutlass rear bumper (NOS?)
- Floor shift steering column NON TILT
- 1968-1971 Cutlass Seat Foam Custom-molded Split bench (complete without arm rest)
- 1970-72 vista cruiser roof sheetmetal
- 1970-72 vista cruiser doors with glass and panels
- 1970 CS Air Cleaner/Snorkel Assembly
- Radiators - For Sale
- 68 Cutlass and Convertible Parts
- 66 442 rear bumper mounts and braces.
- Ehaust manifolds
- 70-72 Cutlass 'S'/442 Rear window trim
- 4 speed bell housing
- 69 4 speed 1111932 distributor
- W & Z manifolds
- 7029251 carb
- 1970 Olds 442 W-30 W-31 X Water pump 404847
- '66 and '67 Seats
- Bumpers
- 7042251 carb
- 7041250 qjet core
- 1970 1971 1972 manual transmission console
- Rochester quadrajet carb for parts
- 6 Blade Fan & Clutch - Very Nice Condition
- SS1 15x7
- Drop base factory air cleaner for use with OAI
- 71/72 parts for sale
- NOS shifter handle 78 to 87 Cutlass 442
- NOS wheel center cap 85/ 87 442
- NOSR W-27 cover
- 68/69 Cutlass 442 Z Bar
- 66 705 alternator
- tri carb intake
- finned aluminum
- Rechromed 1966 cutlass 442 rear bumper
- Brakes
- Need dash pot and mount
- 1968 and 1969 H/O Trans ID Tag Decal
- 1972 H/O Trans ID Tag Decal
- HEI Distributor w/ MSD 8.5 Wires
- MSD 8529 Ready to Run Pro-Billet Dist Used
- 70 71 72 rear quarter panel
- 71 olds cutlass s hood
- 71 72 olds cutlass front fender
- 70 front fender
- 1965 Cutlass Door Panels Black in Color
- 1971 Cutlass 4 door frame
- NOS 1969 Hurst Olds Wing Raw and never painted
- 1955 Olds Rocket 324 For sale
- olds 455 performer edelbrock intake
- Torker intake
- 15x7 SSIIs with bolt on center caps
- Billet Aluminuminum Mallory Unilite
- 68/69 4-speed parts
- GA Heads
- 68-69 Vinyl top part
- 8-track & AM/FM radio
- KA heads
- NOS 1951 tail light assemblies
- '71/2 Pass. Side Sport Mirror Body and Pedestal
- oldsmobile script vave covers chrome plated
- 58 Parts Book, assorted '57/58 parts
- 68-69 442 Sedan parts wanted and for sale
- Set of 5 1970 SSI Wheels Olds Cutlass 442
- Olds 307
- 1970-77 Olds Hurst Dual Gate Shifter
- Re-chromed 1966 cutlass 442 rear bumper
- 70-72 wheel wells Black
- New Performance Parts
- Dash glove box door lock assembly
