View Full Version : Parts For Sale
- 70 442 heads Coded " E " 3 sets
- 1962,1963 cutlass f85 stainless,grilles,dash parts,tailites,etc
- 68-69 Voltage Regulator 8F
- big Thumpr cam for oldsmobile hydraulic roller for sale
- 1968 and or 69 w-30 and hurst olds w a/c water pump
- MSD Pro Bullet Distributor MSD 6AL and MSD blaster 2 coil
- dog dish hubcaps
- 1970 w30 waterpumps
- Muncie M20 - Looks New
- 62 Starfire Trunk Lid
- 71 Supreme halo top trim
- NOS 80# oil pressure sender
- 12-bolt chevy posi rear,show quality,$1700.00
- 70 and 71-72 Cutlass/442 fenders
- 71 455 G-heads
- 69 NOS F85 rt door interior trim BLUE
- UMI Rear suspension braces
- 71-72 Cutlass sport mirrors
- For Sale: Deluxe Seat Belt Retractor Covers
- 70-72 standard DS/LH outside mirror
- 68-72 w/ A/C radiator seals
- 1948 motor & auto trans
- Olds 350 Exhaust Manifolds and Heatshields
- 69/70-71/72 eyebrow brackets
- 71-72 Cast Metal Grilles
- 70-72 Rim Blow Wheel
- For Sale: Power Door Lock Switches - '71-'77
- 70 toro low rise iron intake
- 70 toronado exhaust manifolds
- 1970 455 engine for sale local sale in texas
- 1959 1960 NOS Silvolite pistons +.030
- radiator overflow
- 1969 Hurst Olds trans ID tag decal repro
- 1968 Hurst Olds trans ID tag decal repro
- 1968 W-30 T-400 trans ID tag decal repro
- 1967 W-30 T-400 trans tag decal repro
- stewart warner gauges sun
- Quadrajet Carb for 1967 442
- 1969 Toronado 455 q-jet carburetor
- '70-'72 455 exhaust manifold heat stove
- nice used '72 Supreme / Vista grilles
- For Sale: 1965 Starfire / Jetstar I hood spear / gunsite
- 67-66 Cutlass
- 1964-69 4 speed console top plate Cutlass 442 Olds
- Th400 switch pitch transmission
- 1968 q-jet carb #7028248
- 1971 q-jet carb #7041540 800cfm
- 70-72 cutlass speedometer& fuel gauge
- 1970 Cutlass 442 spare tire and rim
- 350 Diesel Starter
- 1967 442 cutlass bucket seats for sale in texas
- 1972 455 block for sale in texas
- Nos Ka heads in the olds gm boxes
- 81 -87 cutlass aluminum hood for sale texas
- 1968 Toronado Parting Out Soon
- $795 air filter :-O really ???
- Bunch of 68-72' Cutlass parts blasted and Powdered coated
- Notched valve covers & 4 core top plates
- 1970 1971 1972 Cutlass 442: Console, Shifter, Floor Shift Steering Column and Speedo
- 1970 442 1111982 distributor 9-j-15 date code
- Power drum brake assembly
- 1959 Olds metal fender skirts
- NOS cutlass & 442
- New carpet never used
- 71-72 supreme black windlace
- z man i fold
- 1971 1972 bumper brackets
- NOS Delco R43S spark plugs
- 1968 four core top plate
- Nos gm water goose neck kit
- 71-72 cutlass front bumper brackets
- open face alternator
- flywheel 350 455 manual trans man
- Super T-10 trans, flywheel, cluth, shifter
- for sale.. intakes, carbs..
- Super Stock Chrome mags
- 64' - 72' Cutlass OEM Front Control arms- blasted\ powdered
- Olds 350-403 Parts (Aftermarket & Factory)
- Nos gm sun visor mirror
- Nos gm sun visor supports
- Gm nos power beam headlights still in boxes
- Nos gm 1968/69 side marker lights
- Nos gm dimmer headlight switch
- Nos delco t-3 headlight with bucket
- Delco nos solenoid
- Nos delco fuel pumps
- 1968 and 1969 Speedo warning guage
- Nos 1971-72 water pump
- Nos 69-73 442 emblems for both fenders and trunk
- 1972 muncie
- Olds stuff for sale
- 1987 Olds Custom Cruiser Interior
- 1970 Cutlass Parts FS
- Steering column out of a 71 cutlass
- 10 bolt rear end
- 10 bolts posi
- For Sale: 68-72 Olds 12 bolt posi 3:91 Rear
- 62 olds manuals, hoses other parts
- 67, 68 69 trunklids, fender & core supports for sale sale
- 70-77 Sport Steering Wheel - Complete
- 70 Olds 88 Convertible for Parts in FL
- '72 455 air cleaner and heat pipe and shield
- 71-72 Cutlass hood for sale
- 88-90 Toro Trofeo
- 469 cid oldsmobile street/race engine and other misc 425/455 engine parts forsale
- NOS GM "Cutlass" Mudflaps
- Vintage Stewart Warner Temperature Gauge
- '55-''56 front drums
- 68-72 cutlass rear sway bar
- 69-70 bell style brake drums on ebay
- CARTER AFB #4762s CARBURETOR
- Old's turbo fluid and jug's
- Hurst & W30 Parts
- 67 Cutlass/442 hood latch assembly
- 1951 Oldsmobile 88 2 door sedan parts car
- NOS 1969 Olds Cutlass 442 TRIM RINGS SSII Wheels
- 1968 Cutlass 442 Hurst Olds TRIM RINGS SSII Wheels
- 68 Olds Cutlass Body Parts—Convertible and Hardtop—Real GM
- 69-72 Black Deluxe Seatbelt - full set
- 68 69 Rally Pack tach & guges
- 68-69 Rear 1/4 Convertible Peak Molding
- Set - Dog Dish Caps & Shfter Handle
- Cutlass mirrors.
- Parting out a 1970 Olds 98
- 1968 Olds 455 Heads, intake, carb, etc
- 67 Cutlass parts
- 1978 442 Interior
- 1970 -1972 original oai set-up 442 / w-30
- 68 Rocket 350 Motor -Complete--#5 heads
- Black 70-72 Cutlass Console
- '72 455 factory 4bbl intake manifold in IL
- Parts to Norwalk
- 1959 flattop 98 parts car with drivetrain
- 69 350 engine and 350 transmission
- Edelbrock 1411 750 cfm carburetor w/ elec. choke
- 6 blade steel fan with spacer
- fresh c heads and torker intake
- Rally Rims
- 1970-1970 driver side door
- steering box
- Hi comp stock 350
- 68 69 cutlass lower dash, electric antenna pieces, switch and 4 speed dash harness..
- Misc. Olds and non Olds parts for sale
- 67 A-Body convertable frame
- Carcraft Tan Flannel Car Cover C68TF
- trunk edge trim
- 8.2" BOP 10-bolt posi unit and 3:90 gears
- 403 +.030 Pistons For Sale...
- Alero size car cover
- 72 cutlass s dash pad
- 76 Olds 455 engine
- 1968 Cutlass 442 Hurst Olds HUB for wood wheel
- NOS 1970 442 W-30 8 track tape Olds
- Parting out a 1965 Starfire
- 4 barrel air cleaner
- 68 convertible lower dash plus rear antenna parts
- 71-72 front marker light
- 70-72 interior pieces
- 68 lower dash
- 69 air cleaner
- 672 O-axle posi
- 63 Olds starfire/dynamic 88 fender
- 1961 Starfire Convertible Rear Interior Panels
- Set of (4) 14" Trim Rings
- 1964 Oldsmobile Starfire Seats /Carpet (Red) & Console
- 1965 442 Engine
- 66-67 Cutlass, 442 misc parts
- Olds parts
- 1968 and 1973 Oldsmobile Cutlass Parts
- 1973 Hurst Olds original spare tire
- 1967 or earlier 400 425 Flywheel 4 speed
- 1968 bucket seat cages rusty $50.
- 1970 Vista Cruiser Tail lamps
- 1968 Olds 98 NOS frt bumper
- 350 Block and...
- Ultmate Custom Wheel fitment tool for your Olds
- 68-79 Cutlass & 442 Parts / Gauge Pack + More
- F-85 lighted sign
- 1968 Cutlass 442 Front Lower Air Dam Assembly
- 1970 14x7 SS1 rims
- 70-72 442 rear wing
- 4 spoke steering wheel
- 14x7 JJ SS2 rims
- 71-72 442/Cutlass 8-track player
- 71-72 442/cutlass tilt column
- 1970 442 OAI hood + wing
- 67 442 Cutlass Supreme inside door handle
- 1970 OAI air cleaner assembly
- 1972 Cutlass Supreme trunk lid
- 1970 442 Conv. trunk lid
- 54 55 Olds 3.42 thord member drop out rear end
- 1968-69 Toronado knuckle bearing seal
- '87 Cutlass Roller
- 2 NOS 71-72 stone shields at the nationals
- 1970 442 steel hood
- 71-72 442/Cutlass trunk lid
- pair of NOS 70 F-85/Cutlass S grills
- 1964-1972 Rear Window Defroster
- 1967 Cutlass Head Light Bezels - Nice
- 1964 - 1972 Vacuum Power Trunk Release
- 1967-68 Cutlass/442 Steering Wheel
- 1964 1965 1966 Oldsmobile Cutlass 442 Vacuum Gauge
- 1968 TO 391 rear
- Free!!! Cutlass Parts. Free!!!
- 1968 Cutlass parts; fenders, doors, hood.
- 70-72 Cutlass Rear Hood Trim
- HEI Distributor
- Complete set of SSll wheels and Trim
- New W-31 and Ralley 350 Air Cleaner Filter
- 70-72 Cultass Air Cleaner
- 70 Olds Type-O 12 Bolt Rearend Cover
- 70-72 Dog Dish Hubcaps
- 425 Olds Starfire Engine - $450 ( Not Mine)
- 71 455 N Crank $50
- Lakewood Bell Hsg. and Block Plate - Used
- Edelbrock 7111 Intake- Used
- Rear Seat speaker cover
- 70's polycast SS-IV wheels
- 66 67 air conditioning dash vent
- 68-69 plulley set
- 70-72 console rear light lens
- 68 442 Cutlass ciggy lighter
- 70 442 Cutlass TCS switch
- 87-88 Cutlass Headlight Assemblies
- Early Olds hydro flywheels
- '67 400 E block (442)... 40 bucks
- Jet-Fire Turbo Fluid Jug's
- 1970 olds 350 4bbl complete w/ th-350 trans
- NOS 68 442 numerals
- 273 ring and pinion gears oem
- Hitch
- Parts for sale (shifter, carb, shocks, intake)
- 62-67 Oldsmobile Sail Panel Light Housings
- 14x6 JK disc and drum brake wheels for sale/
- 1970-1972 Olds Cutlass 442 AM-FM radio
- 1970 442 w-30 auto 979 distributor
- 455 quadrajet in IL
- 1968 cutlass, hood, fenders, doors
- Various Parts for sale...455 350
- Mondello/Engle JM14 100 hydraulic cam
- Comp Cams Push Rods
- Bucket seat headrests and trim panels
- 1978 Rochester Q Jet for sale.
- 1953 Oldsmobile 303 V8/Transmission
- 64 Oldsmobile 330 cubic inch small block
- ss11 bolt on caps
- Posi unit for 12-bolt O-axle
- 1969 Cutlass Supreme 4 door, parting out
- 68 cutlass s parts
- 70 Cutlass Tail lights
