PDA
View Full Version : Parts For Sale
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130
  1. Th 400
  2. 330 Stroker crank
  3. MSD Billet distributor
  4. Olds 80's B body aluminum hood and hinges
  5. '72 Cutlass Supreme part out
  6. X water pump
  7. 69-70 Delta 88 98 front disc brakes
  8. 68 w-30 o type 4.33
  9. 1970 Olds W-31 intake manifold
  10. Offenhauser 2X4 intake, small block Olds
  11. 1970 Sport Mirrors
  12. Nice sport wheel
  13. 66 Olds parts catalog
  14. Supercharger Kit for Olds
  15. NOS 1960 Front Lower Seat Trim Right Side
  16. 70 Cutlass Convertible Frame
  17. code "R" 14 x 6 wheel for swap.
  18. Rear lower boxed control arms
  19. 1969 ram rod w31 350 motor for sale
  20. 66-67 442 Lower Radiator Seal
  21. 71-72 OAI Hood Fiberglass portion
  22. ART DECO OLDSMOBILE dash emblem..40s? late 30s?
  23. 70-72 Parts
  24. 350 Rocket and TH350 for sale
  25. Reproduction Side Mirrors
  26. 14" 1969 442 Factory wheels
  27. Type O factory 672 posi and 4.66 gears
  28. Damaged Euro header panel pieces
  29. Off a 72 CS
  30. Any interest in 57,000 mile OEM parts?
  31. oem w exhaust manifold
  32. 70 - 72 Cutlass 442 W30 Parts
  33. 1972 Cutlass Steering Wheel & Column (Non-Tilt) with Key
  34. Dual Gate Shifter
  35. Hurst Olds Wheels?....
  36. ~1968-72 Original Trunk Pan,Rust Free.
  37. NOS 71/72 Air Dam
  38. 71-72 Rocker Moldings
  39. Rochester 2 barrell - free plus shipping
  40. NOS steering wheel 1977 Olds Cutlass 442
  41. Cutlass Rocker Trim (stainless steel)
  42. Egg crate Cutlass grille
  43. Steering Column
  44. 70 & 72 S grills
  45. Passenger side exhaust manifold for 350 olds
  46. Service manuals
  47. 68 sport wheel hub and horn cap
  48. 70-72 dual gate set up
  49. It's gonna become a Boat anchor if not sold
  50. 1969 w-30;w-31 re-pop air cleaner
  51. 68 69 4 speed console top plates
  52. ~68-72 A/C Boxes, Cheap $40-$100.00
  53. delta 88
  54. 1969 am/fm radio and parts radio
  55. new cragar wheels & tires
  56. 1970-72 vinyl bucket seat covers, Power Track and seatbacks
  57. SSI Wheels
  58. 1064 - 1965 f85/ cutlass misc parts lot
  59. 1964 = 1965 cutlass or f85 left manual window regulator
  60. 65 425 engine for sale
  61. 68 speedminder speedometer
  62. 1971 Cutlass Power steering pump and brackets $15
  63. 70 OG 442 trans
  64. NOS pair Olds Rocket Racing valve covers
  65. 442 Cutlass 8 Track Face
  66. 1968-70 Ramrod/W31 NOS Heater Hose
  67. 68/69 parts
  68. 15 inch spoked hubcaps 1973
  69. Rev Wheel (Keystone look alikes)
  70. '69-72 convert interior A-pillar trim pieces
  71. 69-72 Bucket Seat Lower Plastic Side Skirts
  72. 71/2 Cutlass/442 hdlght bezels, turn signal lenses, etc
  73. 69 olds cutlass parts for sale
  74. 62?63?64?65?66?67? Big ole chrome air cleaner single snorkle points to drivers side
  75. New flex plate
  76. $99 Fabbed Aluminum Valve Covers
  77. Aluminum cylinder heads
  78. Repro 1970 442 rear bumper NIB
  79. Left front fender patch panel for 70-72
  80. 1970-1972 factory tinted window
  81. Steel Rally Wheels
  82. NOS 1970-72 AM-FM Stereo fader knob Olds Cutlass 442
  83. ~68-72 Original Misc Metal Left Overs
  84. Parting out 1970 350 Rocket and accessories
  85. 70 w30 4 speed carb
  86. Pioneer two shaft stereo used $20
  87. Hurst 4-speed Shifter w/rods for BENCH SEAT
  88. 7040253 (1970 4-speed) Carburetor-- Replated and Rebuilt
  89. full line 1970 Dealership brochure...escape machines
  90. 62-69 Cutlass 442 TIC-TOC-TAC used orig GM
  91. 1969 442 Dash Harness
  92. 70-72 NOS sheetmetal and other parts
  93. Factory 350 hi/comp pistons
  94. 2 '70 Fenders, beat up but savable
  95. NOS 1970 gold steering wheel
  96. 72 Spare steel wheel and G78 X 14 tire
  97. 70-72 SS1 wheels, caps and rings x 4
  98. 1973-77 Cutlass Dual Exhaust Trans Crossmember
  99. 1969-72 Cutlass,442 clutch and brake pedal
  100. PS, Alternator brackets, Pulleys $50
  101. 1972 cutlass/442 front hood molding
  102. 66 jetstar 88 parts
  103. Small block main cap girdle
  104. Ground 403 350 307 260 small block crank
  105. 68 & 69 4 speed floor hump and boot
  106. 68-72 Door Handles, Nice Pit Free Drivers
  107. 69 H/O & 442 Master Cylinder "EA"
  108. 76 Cutlass power window regulators
  109. 76 Cutlass Jack
  110. parting '67 Cutlass Supreme
  111. EDELBROCK 1407 CARB and Accessories
  112. Olds..60lb oil pressure transducer/sender #6462142 66-67 F-85 442 ralley pack
  113. Holley Wrinkle painted Valve Covers
  114. Mickey Thompson "Old School" look valve covers
  115. NOS 800 cfm carb
  116. NOS 4.33 gearset O 12 bolt Original Box!
  117. 68/69 455 exhaust manifolds 88,98
  118. Edelbrock Torker
  119. Custom fabricated valve covers
  120. "72 cutlass left-overs
  121. Olds Hei distributor
  122. various 70-72 Cutlass 442 glass for sale
  123. 3.42 12 bolt OLDS gears FOR SALE NEW
  124. 67 original rim and tire
  125. hubcaps - free -just pay shipping
  126. brackets...ac to water pump, and ps to block
  127. 70-72 Cutlass 442 rear bumper brackets
  128. For Sale NOS 15 inch chrome spoked hubcaps
  129. Large box full of 30s t0 50s trans and engine gskts
  130. NOS 61 62 63 64 Oldsmobile Pontiac Hydramatic rear extension to case gasket
  131. 3 Intakes (2 Torkers and a 0L4b) - Buffalo, NY
  132. 1968 and 1969 Cutlass 442 Rear Armrest set—Black --GM
  133. 1970 Olds Cutlass 442 LH Fender—Real GM
  134. 68-72 Cutlass Transmission Cross-members --Hardtop and Convertible --GM Parts
  135. Olds 68-72 Cutlass 442 Air Conditioning Fan, A/C Pulleys and Brackets
  136. 68-72 Olds 400/455 Notched Valve Covers— GM
  137. 1968 Olds Cutlass Passenger Fender— GM
  138. 68 Olds Rocket 350 in CT--$350
  139. 70 w30 intake
  140. Lunati cams
  141. 15x7 ss2's cheap
  142. 455 for sale
  143. Real and very nice M22 Muncie 4 Speed Transmission
  144. ~70 Cutlass Trunk Pan W/Inners,BS Divider,More Metal
  145. 68-72 Convertible A-body rolling chassis
  146. Holley Finned Aluminum valve covers
  147. 68-72 cutlass 2 door frame ( PARTS)
  148. C heads
  149. 69 Hurst 4 Speed Linkage (Muncie)
  150. 1971 - 1972 Olds Cutlass 442 Parts
  151. BBO- C heads & SBO #5 heads
  152. Rallye 350 tail light lenses
  153. Holley NOS valve covers W/original box
  154. BPO th350 and olds ss3 rallye wheels 15" for sale
  155. Holley valve covers
  156. Parting 1987 1988 olds cutlass euro header panel
  157. 1978 1979 cutlass trim parts grille head light trim tail lights
  158. 70 bullet mirrors original paint excellent
  159. 455 windage trays
  160. 1970 455 block for sale
  161. Various Cutlass Grilles - NOS/Used
  162. Rare 68-69 W30 W31 "KA"-"KB' Pulleys
  163. Street strip cylinder heads
  164. 1971 455 4speed shortblock
  165. 70-72 parts for sale
  166. NEW 70 Supreme or 442 convertible interior kit
  167. Forsale two blacl sail panels head liner pieces 70 olds
  168. (5) 15x7 SSII or SSIII Wheels PowderCoated
  169. 65 cutlass headlight rings
  170. 65 330 4bbl carb
  171. Comp Cams 1.6 Roller Rockers
  172. 3-speed Lightning Rods Shifter and accessories
  173. 2 W exh and 1 A exhaust and full size orig disc brakes
  174. Edelbrock Aluminum valve covers painted Olds blue
  175. Bucket seat conversion kit
  176. 69 cutlass hood
  177. 81-83 cutlass reverse light assy.
  178. 1974 Hurst Olds parts
  179. 1974 cutlass salon wheel discs-$25
  180. 2 1969 400 G engine blocks
  181. Oldsmobile Cutlass 70-72 large parts
  182. custom oldsmobile roller camshaft
  183. 1966 delta 88
  184. 1965 oldsmobile starfire for parts
  185. lots if 74 cutlass parts
  186. 69-72 tilt column w/key.
  187. 1963 F85 4-Door Parts
  188. Cutlass Park Lights
  189. Cutlass Tail Lights
  190. 1971-72 Cutlass hood louvers
  191. Cutlass Mirror
  192. Bucket Seats
  193. Super Stock I NOS Oldsmobile center cap
  194. Nos ssi center caps
  195. 69-72 Cutlass/442 hood hinges.
  196. 68 69 70 71 72 Cutlass S (Model 87) or 442 2-door hardtop rear 1/ 4 windows
  197. 69-72 Cutlass 442 Chrome Armrest Backing Plates—Nice GM
  198. '71 CS 350 parts for sale
  199. inside ac/heater box 68-72
  200. 68-69 Cutlass 442 ac nos dash vent
  201. olds #5 heads with harland sharp full roller rockers
  202. 70-72 Cutlass 442 courtesy lite harness
  203. 70-72 marker light set 442 Cutlass S
  204. 70-72 console extension harness
  205. 69-72 cutlass 442 4 core radiator top plate
  206. 70-72 Cutlass 442 black ash tray door
  207. 70 Cutlass 442 hood extension
  208. NIB TIMKEN Bearings and Seals for 28\30 spline axles
  209. 7 Blade Clutch Fan & Clutch
  210. 1968 and 1972 Cutlass Wiring Harnesses—GM --Complete -Good Shape
  211. Very Nice 78-88 Cutlass Console
  212. 56 Olds 88 Right front fender trim needed
  213. Parts to Sell At Homecoming
  214. 72 442 steering wheel $125 shipped
  215. Vintage 455 Torker intake used..decent.
  216. Cutlass 442 Hurst shifter handle 7169...70-72.Console shifter
  217. 70 - 72 Cutlass Tilt Column shift Steering Column
  218. 6 NOS body mounts 70-72 Part# 242761
  219. 1964 - 1965 Cutlass/ F85 Rear defogger switch
  220. Doors, 1964-72 Cutlass/442, Vista Cruiser, Toro & 1955 88
  221. E Heads Rebuilt
  222. 1971 Vista Cruiser tailgate moldings
  223. 1971 Vista Cruiser tail gate opening moldings
  224. Back up lights/ housings 1971 Vista Cruiser
  225. 1971 Olds 350 pulleys for a/c car
  226. 1971 Vista Cruiser Drip rail moldings
  227. 1970 A/T floor shifter
  228. 1970 post dash pad no no vents
  229. 1970 rust free stock hood
  230. 1970 350
  231. 71 NOS w30 waterpump 408329 X
  232. 1966 - 70 19 in cooling fans with new clutch
  233. 1964 - 1965 F-85 / Cutlass post car/ all pieces of side Glass $100
  234. 1971 A-body upper and lower control arms $50
  235. 1964- 1965 A-body (cutlass) bucket seats
  236. 68-72 nos delco shocks
  237. 12 bolt w27 cover
  238. 71-72 GM nos dash woodgrain
  239. 70 dated ss1's w/ new Firestone wide ovals
  240. 1970 442 NOS hood and fender moldings
  241. 70-72 black 4 speed console
  242. 70 442 grills repros $175 + original driver
  243. 70 w30 intake "olds 455"
  244. 70-72 dog dish caps
  245. 71 w30 H heads
  246. 70 442 dist 1111982 $150
  247. 70's NOS ALPINE cassette *green lights*
  248. rally pac oil sender 6462137 used + nos
  249. 70-72 OAI set up
  250. 69 7049253 4 speed carb
