View Full Version : Parts For Sale
- 1969 a body hood moldings
- 1969 442 black interior pieces
- 66 67 Factory Track pack for sale
- 1967 98 Parts Car
- Engine block heater and cord. NOS
- Horn cap 562846 NOS for 1953-54 Deluxe steering wheel
- Olds Cutlass plastic air ducts, two piece unit
- Rebuilt front speaker
- possible f/s 65 Cutlass front parts
- FS: aftermarket 4 speed boot
- 7040253 70 4 speed carb
- FS: 1972 front stone shield rocket emblem
- 1970-72 console front mounting bracket
- FS: 1972 rallye pack sender (used aftermarket)
- 65 cutlass dash chrome
- 65 cutlass bucket seat trim
- 65 cutlass trunk light and horn button
- Olds AM FM 8 track 73 and up
- olds 8 track with cover
- parting 85 delta 2 door
- Rochester 850 CFM Carb
- Olds Driver Side Mirror
- Hughes Converter
- NOS GM Oldsmobile splash guards
- 1970 Cutlass 442 Floor Shift Speedometer Olds
- What's it worth? Mint 72 deluxe black steering wheel
- RARE 1966 cutlass vacuum gauge console ( dayton ohio
- Rally Pac Gauge 1974 Cutlass 442 Hurst Olds
- 70 71 72 trim what are you looking for dayton oh
- 70-72 lower dash parts dayton ohio
- 1969 ? Clock and am fm radio make offer
- 15" Oldsmobile Hubcaps
- 1960-1963 Full-size parts!
- Wiper motor part # decals
- NOS Cutlass 442 THROTTLE CABLE BUSHING AND SLEEVE
- Black rubber Oldsmobile floor mats
- 1970 Cutlass Supreme seat belts
- Bumper Jack Base
- 8-Track tape
- what are these parts worth?
- RARE NOS 1983 H/O Sand Gray Interior Materials
- 4 core radiator
- 67 cutlass/442 bumper brkts
- 1973 front bumper and rear impact strip
- Parting 71 Cutlass - 4 door
- More Olds parts just in.
- Misc Cutlass parts
- 7040250 restored.. what's it worth ?
- 70 nos bullet mirror
- Fresh Rebui,t 468 Oldsmobile Engine 482HP 507TQ
- 1968 Ram Air scoops - need work
- 1967 Hardtop rear seat cover Lt Blue
- Mint 70 rally pac
- "Oldsmobile" [Grille?] Script EMBLEMS f/s
- 1966 Cutlass Front Drum Assemblies
- 455 Oil Pan and Valve covers
- Nice 69 Convertible Deck Lid
- 1966-72 Bucket seat tracks, driver outer & 3 inners.
- 3.91 Gearset for Type O 12 bolt
- 67 rally gauges
- 67 442 core supports (2)
- 67 442 taillight assys all 4 with lenses
- 66-67 cutlass 442 door hinges
- 67 442 conv stainless (POLISHED)
- 67 cutlass/442 jack and jack bag
- Found a 1973 Cultass Supreme 4 door in a yard.
- $2500 oai air cleaner on ebay ! wow
- oldsmobile trunk rubber floor mat
- B heads
- 1965 cutlass buckets/ tracks
- NOS window fuzzies
- TH350 transmission, rebuilt with torque converter
- 1963 olds 215 and hydromatic trans
- Set of 71-72 Cutlass Hood louvers For Sale
- ARP main bolts
- 70 Cutlass/442 gas tank
- 69-72 bucket seat upper frames & springs
- 14x7 steel wheel with 245/60
- 65 330 motor and 2 spd trans
- 1970 Olds Cutlass 442 Speed Warning Speedometer
- 1968 Wood Grain Steering Wheel Cutlass 442 Hurst Olds
- 1970 Olds Cutlass 442 N42 option Steering Wheel
- 1969-1970 F-85 W-31 Steering Wheel
- 1965 PIM [aka assembly manual]
- Top Show Quality 1970-1971 Olds 442 W-30 Cutlass W-31 Steering Wheel
- Show Quality 1969 N34 Steering Wheel 442 Hurst Olds
- NOS 1964-1966 Olds Cutlass 442 Glare Proof mirror
- 64 oldsmobile-4 core radiator, front bumper, fuel tank
- Main bearing cap straps.
- Holley Valve Covers
- Dipsticks
- Radatior
- Modified Torker Intake (not finished)
- 1970 442/cutlass 'sh' code 3.42 posi rear axle
- Free 1969 455 2bbl intake
- 1970 dark saddle 4-spd console
- 70 Cutlass 'S' Cutting Up
- Cloyed double roller timing set
- 65 400 & 4 speed Boise ID
- NOS 66-67 Ignition switch Cutlass 442 Toro 88 98
- M4ME Carburetor for Sale
- 1971 w30 posi rear
- '79 Toronado Parts
- 1970 cutlass part wanted
- 75-77 cutlass hurst hatch
- 69 Cutlass/442 N34 Steering Wheel and Center Cap
- Stock rocker arms, Sealed Power replacements
- 1939 - 1952 olds winter special!!!!
- Hurst 4 speed shifter non-console
- Fusick dog dish 64-69 xcellent $175
- 1964 65 cutlass dash cluster excellent shape
- 1969 400 Pistons & Rods
- 67 442 conv new Wire harness
- 4 core Radiator from 67 442
- 750 holley vacuum secondaries 80508-1
- Aftermarket rear controle arms upper& lower
- Aftermarket Front & rear swaybars 66/67 442
- 66-69 4sp console
- 67 442 hood (cheap)
- 63-64 Fullsize Olds Speedo Cable NOS
- 1969 442 radiator support top plate
- Real nice black '68-'72 8 track player.
- [opk[p
- 1972 442 grilles
- 68-72 Cutlass 442 Convertible Rear Chrome Pinchweld Molding Pair-- Real GM
- 1971 cutlass engine and tranny..also have power disc brakes
- Hurst Dual Gate Shifter
- Covertible top frame 66-67 Cutlass
- 1970-72 nos trunk lid hurst/olds
- Junk for sale
- 1964-67 power steering pump
- 1970 olds cutlass PARTS CAR JUNK YARD ASAP ohio
- 70' original "KM" water pump pulley
- 1971 442 repro grilles new in boxes
- Edelbrock finned alumnum valve covers and o4bH intake..
- 70-72 Supreme deck lid
- 70 OAI hood
- Original 68 Walnut Sport Steering wheel
- NOS Throttle cable bushing and sleeve
- 1964-1969 Olds Cutlass 442 Vacuum Power Trunk
- 70-72 442 rust free decklid
- 70-72 NOS wing ! $850
- NOS 1966 Cutlass & F85 Tail Lamp Assemblies
- 1970 NOS rally350 or W31 grill $400
- Four core radiator
- NOS Dark blue rear floor mats - 66? - 72
- Valve covers - small block - plain
- Fully built, 850hp 455 with 0 miles
- 1970 Cutlass/442 Assembly Manual and GM Service Manual
- Cutlass 442 Front Bumper Bracket Set
- NOS w31 / ralley 350 grill
- 71-72 sport mirrors
- 1967 442 motor,trans, and console
- Offy #5589 2x4 bbo intake
- 66-67 400e
- Non AC heater box cover
- NOS 1971-72 Olds Power trunk opener
- ( 2 pair of 70 cutlass fenders ) ohio from $100 each
- thinking about parting 67 442 4sp conv
- 1970 power trunk button
- Set of four 14x7 SS2 rims w trim rings
- 4 way power seat
- 1965 Cutlass f-85 Rear Bumper Brackets
- Misc 70-72 parts some NOS.
- 1969 power disc set-up
- 1968-72 convertible interior side panels
- 1968 thru 72 convertible header panel moldings
- Intake Manifold
- 70 cutlass parts car dayton ohio
- 70-72 lower dash cutlass ohio
- 70-72 olds cutlass dash
- 70 - 72 Parts/Pics/Prices
- 68-71 GM Guide T-3 Original Headlight Set-- Tested and Working
- 68 Peak moulding Parts on Ebay
- Hallmark Toronado Ornament
- Rhode Isalnd 66 Toro ENGINE epay $100 start
- Passenger side alternator bracket
- Lots of stuff cleaning out Dads shop
- 1970 455 E heads
- 1970 w30 carb 7040258 restored..
- 68/69 W30 original red fenderwells
- 15 x 7 trim rings...not show, but still nice
- 70-72 rear bumper brackets - no pits
- 67 Toronado just in very complete
- 70 71 72 Rally Pak Tach & Guages
- '70 Olds 442 Am Radio's
- '67 442 parts
- Vacuum Trunk Release
- 68-72 AC firewall box...sell whole or parts
- 1970 442 cutlass headlight trims
- mid-MI $50 #8 headed 350 seized
- mid-MI fresh 455 short block for cheap
- 70 Toronado - Parting Out in N FL
- 1968 posi unit 31 spline
- Mint NOS Oldsmobile tissue dispenser Dealer Accessory
- Edelbrock 065, 750 Carters, M/T Valve Covers
- 1969 A body heater control and bezels
- 1971and or 72
- Olds big block and small block heads
- Olds 15x7 SS1 Rims and SSII 14x6 rims for sale
- Large list of misc Oldsmobile Literature
- 1970 OLDS CUTLASS SUPREME PARTS CAR dayton ohio
- 1969 Cutlass S parts car, nice trim, red interior, dash pad, pass. door, more.
- 69 black interior
- 68 and 69 wheel well moldings full set
- 68 a/c and or 69 dash pad
- 72 ?? Rar view lighted mirror
- 69 hard top trunk
- 1971-72 Park light lenses
- Under hood light
- Floor Shifter
- Wiper arms ($20.00 pair)
- Vintage Olds Eight Track
- 1971 Cutlass owners manual
- SSII/SSIII Trim pieces
- SSII Center Caps
- Beauty Rings (SSII / SSIII)
- I am looking for a 1967 cutlass parking brake assembly.
- 1967 E Block 400 Manifold and 2BBL Carb For Sale
- 68-69 455 accessory brackets, pulleys, etc
- F/S: Sport Wheel spare holder nut
- 71 G-heads,$75.00/pr.
- 12-bolt Chevy rear,build to suit
- 12-bolt O-axle 3:23 Posi rear,SF-code
- 14 by 7 trim rings for ss ii rims
- 1968 clutch and brake pedals
- 1969 442 parts car
- 70-72 Supreme Moldings...driver quality
- 1970 442 Glove box door - black
- 1968 cutlass s glove box door - black
- For Sale: 1963 Cutlass, F85, Jetfrie Parts
- 455ci with TH400 combo deal 2000obo
- Posi rear off of 1965 olds delta 88 - $900.00
- Bargain Basement
- 1969 black manual console
- 68/69 carbs and dist
- 1969 Cutlass 442 Owners Manual pkg + window sticker
- SLIM JIM transmission complete... needs rebuilding
- 1967 Sun Visor
- 1971-72 Hood trim
- 1969 Cutlass Grille
- 1967 Cutlass wheel well trim
- 1967 Licence Plate Bracket
- Mickey Tompson Valve Covers
- 1972 8 track face plate Cutlass 442 Hurst Olds
- 1967 Cutlass Sun Visors
- M-20 4 speed on ebay, from 1972 so it has the M-22 style shafts
- 70 cutlass hood trim
- 69 cutlass headlight bezel and trim pass side
