View Full Version : Parts For Sale
- 68-72 rear window defrost $75
- Cutlass 64-69 console new emblems,69 new ashtray
- Alternator 1100767 37 AMP
- 71 442 W30 block + matching OW trans
- 1970-1972 4 speed tunnel hump Olds Cutlass 442
- 15x7 SSIII wheels
- 70/72 cutlass/442 NOS 1/4
- Holley 800 cfm spread bore
- Nos 68 cutlass/Hurst/442 R/quarter
- 69 cutlass taillight assys
- 1967 Oldsmobile 442 Cutlass Driver Side Fender Extension
- 1969 cutlass driver fender
- Oldsmobile Parts Various
- 1965 442 Cutlass bumpers
- 1976 455 block from Delta 88
- 442 W30 1111880 alternator
- 71/72 NOS stone shield + grills ?
- 71/72 OAI hood
- 1970 442 auto carb 7040257
- 70-72 NOS tail pipes w/ trumpets
- 70 442 W30 4 speed carb 7040256
- 71 442 W30 *H* heads
- Flywheel Magnesium NOS 303 324
- Olds parts
- 1969 Cutlass 442 shifter, harness and console. $225.00 + ride
- 68 69 rally pack gauge tach & clock parts, super nice original stuff
- F/S 1969 Cutlass Posi Rear 3.08
- 200-4R transmission case
- 1966 Post Door
- 1966 4-4-2
- Real W27 rear cover
- 324 flywheel automatic 1956
- 324 4bbl and intake manifold
- 71/72 442 Inner Grill & Hood Moldings
- 455 intakes, cam lifters and pushrod etc
- 1968 misc parts
- Set of 4 USED factory 14" wire spoked hubcaps for 1982-88 Oldsmobile cutlass
- DMR Windage Tray w/ BB stud kit
- Big block Holley street dominator intake manifold.
- Original GM 2 speed wiper swtich for 67-Cutlass
- 215 aluminum v8 engines,parts incl turbo
- 1971 Cutlass tail light lens
- BNIB ARP Rod Studs
- 71 442 nos l&r grilles
- 1971 Cutlass/442 tail lamp lenses
- 1973 Oldsmobile Omega parts
- 1964-67 cutlass ac vents
- 73-77 Floor Shift Non-Tilt column for sale
- 68 442 RH exhaust manifold 398706 Y
- NOS GM 68 69 Cutlass/442 front marker lights 916581
- 68-70 thermostatic vacuum advance switch / TVS #1230500 & 413473
- 68 442 & Hurst/Olds warm-up heat shroud assembly, complete!
- 1968 442 Complete Floor Section
- 1964 1965 air cleaner top
- 1964 1965 wagon tailgate window motor
- '57 Olds trim & mechanical parts - cheap!
- 1968 Olds 98 engine parts
- 66/67 Automatic Throtte Pedal Assembly Complete
- Wheels
- 70-72 cutlass convertible top wiring harness
- 303 4 bbl intake
- 1969 only 14x6 ssii wheels
- Aggressive 403 Cam-Brand New Custom Grind
- Delco Remy D-1007 - Cutlass
- New in box - TRW/Speed Pro L2323F- +.040
- 71 Cutlass Supreme grilles
- 70 71 72 4 speed shifter 7169 handle for console
- 1967 442 'E' Block Stick Complete Engine
- 1967 442 W30 Shroud Air Cleaner Fiberglass Reproduction
- 70-72 4 door parts
- 4 speed battery tubes
- 68 Cutlass Parking Light Set
- 1967 Oldsmobile Cutlass 442 Grille Bar Trim Moulding
- 68-72 Cutlass Full Firewall W/Side Cowls,T Boxes
- 71-72 Cutlass 2dr Orig Full Floor Pan W/Braces,68-70?
- 1967 oldsmobile 442 convertible and parts inventory
- Oldsmobile Automatic Car-Watch '49-51
- 1964 F-85 Front Body Parts
- 68-72 8 Track complete
- NOS Engine Block BBO DRCE
- 1971 350 #7 Heads Casting 409 147 CFD
- 10 bolt 8.5 gears gm for sale
- NOS mirror gaskets
- NOS g body parts
- 1967 cutlass /442 4 speed tunnel and hump
- '66 Olds "B" body Nameplate
- 71-72 Cutlass Door Panels
- Late model ride height adjusters
- Tornado taillight assembly
- 455 Mallory dual point dist YC501HP
- 72 Cutlass Supreme used windshield.
- Factory front disc brakes, 72 Cutlass
- 1957 371 J2 with six pack and TH400
- 14 X 7 SS II wheels
- 7028251 quadrajet body
- 1411 edelbrock carb w / elect choke
- 4 speed parts
- 1965 olds 442 only carburator
- 1964-65 Trunk lid Clean Rust free
- 1964 Cutlass front drives fender
- 1964 cutlass 442 rear bumber rechromed
- SS-IV's.
- Exhaust Manifolds for sale
- 1956 NOS Ignition Switch
- NOS lenses
- 65 Power seat A body
- NOS 67-71 guidematic dimmer
- NOS rear wheel bearing
- NOS rear front seal
- NOS rear axle seal
- NOS AC control switch f85
- NOS 1972 luggage lock
- NOS rear diff pinion spacer
- Foxcraft Cruiser Skirts Oldsmobile 1954 1955 1956 1957 1959
- 1968 442 Front Bumper Bracket Set
- 70 Cutlass 442 Tail Lamp Lens / Light Housing /wiring
- RARE Delco Remy D308 cap in the can
- 1972 SBO exhaust manifolds
- Oldsmobile engine, parts, wheels, headers, etc. single lot
- 68-69 door and windows
- Dist. cap in can NOS
- Nos 68 lenses
- olds 455 valve covers
- Bbo edelbrock top end
- Regular 1971 455 valve covers
- 67 442/cutlass dash pad and cluster complete
- 1971 Quadrajet - rebuilt
- 1973 B-body electric trunk lock assembly
- GM full-size B-body passenger side door hinges
- GM full-size B-body tilt steering column
- NOS f85 rear axle seal
- NOS f85 rear bearing
- NOS AC switch f85
- NOS PO1 wheel disc emblems
- NOS spark control switch
- 1968 442 interior parts
- NOS AC switch f85
- NOS fuel filter kit
- NOS hood latch
- NOS ts switch
- NOS ts switch f85
- good working sears timing light w manual
- 1964 F85 / Vista Cruiser rear bumper core
- 1977 442 bucket seats & seat belt assembly.
- 1977 442 hood
- NOS 65 left hand parking lamp
- 68-72 8 track complete
- 73-75 cutlass 442 hurst hood
- Down Pipes
- various new parts - robbmc pump, radiator hoses
- NOS 1966 442 front marker light
- NOS 1965 reverse lens
- 1975 Cutlass Gas Tank, Tail Lights, Windows
- 1970-1972 Olds Sport Steering Wheel with grain Cutlass 442
- ARP 300-8246 7/16" 12pt Poly locks
- 303 intake
- 394 intake
- 14X6 Wheels FREE-O
- 70-72 sport steering wheel hub
- 1-big valve C head
- 69 442 400 .030 short block assembly
- rebuilt 350
- Offenhauser valve cover breather 30 degree angle
- MICKEY THOMPSON VINTAGE OLDSMOBILE LOGO VALVE COVERS with Breathers
- 1970 442 / Cutlass Blue Upholstery Material
- 68-72 Cutlass Fuel Tank braces - NEW
- 1966 "B" Heads
- Freedom and Freedom II Battery Toppers
- Trunk Floor Braces - New
- 70-72 Convertible Rear Dome light Cover NOS
- 71-72 Inner Front Bumper Brace
- 1 15x6 GM Standard Steel Wheel
- 2 15x7 Standard Steel Wheels
- 1973 - 1977 Olds Cutlass Console and Shifter
- 1974-75 Hurst Olds rims 15.0"
- 1957 58 Oldsmobile J-2 Tri-Power water neck outlet thermostat housing. $10
- GM Olds 350 small block Intake Manifold $50 411990 iron 1973 442 4bbl
- 71 350 4brl 4 speed
- Manual trans
- '69 98 parts
- flywheel
- 1965 Cutlass/442 Rechromed Tail Lights Tail Panel
- Parting out 1978 Toronado
- Parting out 1970 Delta 88 four door hardtop
- Parting out 1954 Olds 88 2 door hardtop
- Lunati solid roller forged pistons comp lifters
- 67 Cutlass Parts
- parts for sale
- 66-7 442 parts
- Clutch z bar
- 70 455 thermostat housing 404632
- Small Block Aluminum Intake
- Parts for sale in AZ.
- 1966-67 cutlass /442 post doors
- Wanted AC for 65 olds 442
- Original '70 Supreme Grills - fully restored
- '70 - '72 floor shift auto console -restored - black
- 72 442 Rebuilt Turbo 400 Trans Code OD
- 1968-1972 Notched valve covers Cutlass 442 V-C Hurst Olds
- SS II/III Wheel Bezels
- 70 - 72 Cutlass Center Dash AC Vent
- 1971 1972 442 grilles
- SR code 1971 1972 442 3.23 OPEN axle
- Toro 455 parts
- 69 Hurst Olds Valve Covers - $200
- AC DELCO PF24. (6 available)
- 14x6 SSIII with bolt on cap
- 15x7 SSIII with bolt on caps
- TRW 455 .030 pistons on factory rods
- vacuum tank on firewall
- 71-72 driver side fender filler
- chrome oil dipstick and tube
- accel cable bracket
- 455 block heads crank and intake
- 8 track tape player housing 1968-1972 Cutlass 442 Hurst Olds
- NOS Delco CD ignition system 1966-1972 442 W-30 Hurst Olds
- 1971 442 grills and stoneshield
- Bell housing 4 speed shifter and clutch fork
- 67 Cutlass Headlight Assemblies
- Sport wheel horn cap
- 15" x 7" Bolt on Center Cap Wheel
- 1979 Optional Aluminum Wheels Hurst Olds
- 1968 442 or Hurst Olds Wheel
- 1968 '251 carb core
- 455 quadrajet
- 1967 Olds 442 parts for sale
- 2 Wix 42081 Air Filters new in box $20 for both
- 3.42 TM 31 spline fresh rebuild posi axle 4 oldsmobile 442 cutlass
- 1968 aircleaner
- w-30 Olds w 455 intake
- very low mi 403 + 400THM for sale, can hear run & drive!
- 1957 1958 Complete Power Steering parts to add PS to your car
- NEW 1957 & 1958 Olds Dash pad, best quality from Sweden, US location - SAVE
- 1964 98 rear bumper and fender skirts
- 68/69 Cutlass/442 front fender patch panels
- Few Odds & Ends from my 66 442 Project
- 68 to 72 manual and power draw a master cylinder original
- 68 front A arm bars
- 69 F-85 at Grand Strand Pick N Pull, SC
- Used 1971 Cutlass Cast Metal Grille Set
- 1111982 olds OEM Oldsmobile distributor with electronic conversion kit
- NOS Delco R46S Plugs/Rotor
- 67 rearend
- 1972 Rear glass with defrost
- 1968 S Post Shell
- 3.73 full size 1971-1976 car 88 98 olds posi rebuilt ready to run
- 1953 - Wire Wheel Covers for sale
- 69 a/m f/m wonderbar radio.
