View Full Version : Parts For Sale
- 1970 8 track face plate Cutlass W-31 442 W-30
- Replacement Fuel Filter 1966 Olds 442 3X2 L-69
- 1970 1971 1972 Cutlass 442 Dash Plastic with wire harness and speedometer
- NOS Delco Jac Pac 175 Air Shock Controller Cutlass 442 Hurst Olds
- 1970 Toronado 8-track housing
- NOS Delco Air Shocks Power Pac 1960's Olds Cutlass 442 Wagons
- 1966 98 grille emblem
- 1971 8 track face plate Near NOS Olds Cutlass 442 W-30
- 70 71 72 8 track rear support brace
- 1970 Gold Seat Belts With Deluxe Nickel Buckles
- Running & driving 455 engine
- Orig. 1969 8 track face plate Cutlass 442 Hurst Olds
- NOS rocket decals 2 1/8 diameter
- 1968-72 black pair OEM armrest bases
- 1969 Convertible Door weather stripping
- 1968 8 track front pad Cutlass 442 Hurst Olds
- 1969-1972 8 track front pad Olds Cutlass 442 H/O
- 1970-1971 1972 8 track parts Olds Cutlass 442
- 1955-1970 Parts
- 1957 Olds Original Gas Tank
- 1970 442 Original Gas Tank
- 71-72 Dual Snorkel Air Cleaner, Complete
- 1987 & 1988 cutlass/442 header panel emblem
- 1970-1972 cutlass/442 - rear side marker lights
- SPEEDOMETER DRIVE HUB - EARLY 60's
- Dual gate shifter ball
- 71/72 cutlass 442 turn signal lenses
- Set of 6 tubular front bumper braces 1971 Cutlass 442 1972
- 70-72 Cutlass 442 reverse lights ( pr ) excellent
- 1969 Cutlass 442 Hood latch ( for core support side )
- Original Ram Air cleaner top
- WANTED: 64 Cutlass blinker lens
- 1969 442 heat/ AC control
- 1970-72 Olds 442 Ram Air Hood parts
- 1970-1971-1972 Olds 442 Ram Air Hood Brackets
- 69 W31 29255 carb
- 7040257 carb
- Rear Bumper Guard 1987 Cutlass Supreme
- 1970-72 Dualgate shifter/console/buckets/column
- 1966 oai shroud air cleaner
- Hood hinges
- ‘70-‘72 console wire harness - rough - free
- 70-72 Truck deck lid | surface pitting @ skin fold
- 70-72 fenders L&R | Needs minor patching
- 68 69 70 71 72 Cutlass 442 Convertible Upper Windshield Trim Pieces Real GM
- 1965 Cutlass carb to auto trans linkage
- Starfire grill
- 1972 Dash Wood Grain Applique
- 68-72 Cutlass Wagon, Rust Free Rear Frame
- several carbs for sale
- 69 seat belts
- 1111042 Delco Distributors 1966 1967 442
- Front Sway Bar, '70-72 Cutlass/442 - For Sale
- 1970 Cutlass W-31 442 W-30 NSS Back-Up Harness
- 1970 Olds Cutlass 442 NSS, Back-up light console switch
- Door panel reflectors 1970-72 cutlass
- 1970 442 1108389 Starter
- 71-72 Cutlass/442 Seat Belts -Fore Sale
- 1967 330 Cast Pistons and Rods
- Lakewood ladder bars for sale
- 1970 442 Cutlass USED hood and fender eyebrow moldings
- 1970 Cutlass 442 headlight surrounds
- 1961 - 1963 Olds Cutlass / F85 N.O.S. U.S.A. Ball Joints Set
- 1964-1965 Cutlass Passenger Rear Quarter Window and Frame
- 1969 dash map / courtesy light
- 69 Cutlass 442 hood latch
- 69-72 Cutlass 442 hood hinges
- 1969-70 - 71-72 6 blade fan
- 70-72 Cutlass/442 A/C ducts and vent hose
- 1968 1968 14" Factory Hubcaps Wheel Covers
- 70-72 Dash
- 1971-72 power trunk option
- Parts found
- Turn signal lens 1971-72 442 original
- 1969 Cutlass E brake pedal asembly
- Nice Original Pr. 1971 1972 Cutlass 442 F85 front turn/park lenses
- Real 65 442 body
- 1969 Cutlass Hood for Sale
- 1966 442 Trunk Molding
- 1956 Olds Rear window tinted
- edelbrock performer
- 1968-1972 442 Boxed Lower Control Arms + Braces
- 1968-72 350 non-A/C new heater hose and clamps
- 70-72 door edge trim - 4 pieces
- 1966 oldsmobile 442 w30 tri carb l69 end carburators !!
- 1969 442 hood and core support
- 71 / 72 w30 nos
- Nos items
- 72 Rocker panel moldings
- 1972 olds cutlass 442 AM/FM radio - mono - works
- 1973 Toronado Parts, transmission
- 1968 350 valve covers
- 455 non A/C alt bracket set
- Near complete 1966 4 speed 442 convertible dash assembly
- 7029254 carb
- 1971-72 # 1112036 W30 4 speed distributor
- 72 side door guard trim
- 72 Vinyl top trim | quarter panel
- 1970 OEM Cutlass “S” grilles
- C 455 heads
- 1970-72 console rear lens OEM
- 1969 Cutlass Front Bumper and Brackets
- Cutlass 12 Bolt, Pit free, Can Part It
- Flex plate cover
- 64 65 HD cooling Fan Shroud
- Olds 9.3 rebuild kit
- 1964 starfire upper balljoints pair
- 65 Cutlass rechromed parts
- 330 engine
- 1968 olds 442 trim
- distributor
- distributor
- distributor
- distributor
- 1971/72 442 distributor
- Turbo 400
- 1969 Cutlass/442 front bumper
- NOS GM Olds Performance Parts Valve Covers
- 66 F85 4 door post parts cars
- 7040255 70 w31
- 71-72 W30 auto dist 1112034
- 66 67 442 fan shroud and radiator
- 71/72 cutlass body
- olds4421st
- 1972 Cutlass floormats
- NOS 1968 1969 Dual Gate Shifter Hurst Olds Yenko
- 1969 455
- Turbo 350 trans
- 1968 Olds Cutlass 442 RH Headlight Bezel Assembly--Nice --All GM
- 88 Olds hood ornament $225
- 53/54 Oldmobile 88 (98?) horn center
- Offenhauser valve overs and unknown aircleaner
- 70-72 bumper guards
- 1970-72 bumper guards
- Hedman Headers 350 olds
- 70-72 New Brake Calipers Inline Tube
- 1970-72 console mint
- 1970 4 barrel intake
- 4 core top plate repop 70-72
- 4 core radiator 1970-72
- 1970 OAI base
- Brackets for most applications
- Fasteners / fittings / straps / clamps
- 1930's Oldsmobile Dealer Accessory Spotlight
- Hood spears ,pinchweld trim ,hockey sticks, latches , hinges & hood extensions
- 1972 cutlass/442 rear seat belt retractors
- Dash center no ac vent unit 1970-72 442/cutlass
- Taillight assemblies 1972 (pair) complete
- Brake master cylinder push rod & everything else brake related
- Parts for 83 Olds 98
- 72 Tail light assemblies complete $600 + shipping
- 71-72 blue armrests and pads
- "4 - Oldsmobile Rocket Round Emblem Decals" - NEW - FOR SALE...
- NOS 3.91 4-Speed Transmission 90 Degree Adapter 395430
- 1970-72 Ventless dashpad
- Decklids
- Carb cores or fuel /air mixture mixers
- RAM AIR hood Glasstek
- Bell housing, fork and clutch rod
- 70-72 seats
- 1969 Cutlass/ 442 automatic center console & shifter
- 1969 Cutlass deck lids (2)
- UMI Rear Adjustable Lower Control Arms 4014 (Fits 1964 - 1972 GM A BODY)
- Early 330 or 1965 A-heads guys, valve train parts available
- 57 olds parts
- Doug Thorley SBO headers
- Defroster adapter #397784
- W27 cover
- '71 442 interior stuff
- 1962 starfire chrome quarter panal bead
- Assorted 62 & 66 Olds parts
- Cruise control items for sale
- Olds 350 engine.
- tail lights and front and rear fender extensions
- Seat belts for various models /colors
- Water pump 404847
- Electric Seat Back Release 1970 1971 1972 Cutlass 442 Hurst Olds
- NOS Turn Signal Switch 1964-1965-1966 Olds Cutlass 442
- reflective glass used to see the person you're racing
- jukeboxs
- 68 -69 cutlass 442 jack
- Dash plastic and console
- 68- 69 -70 -71 alt brackets for AC car 350 400 455
- 68-72? power steering pump to exhaust manifold bracket
- turbo 350 / 400 plastic flywheel cover
- 69 ac 3 groove pulleys
- Alternator Bracket w/AC '69-'71 Cutlass/442 - for sale
- NOS AC Spark Plugs 1960's Cutlass 442 Hurst Olds
- Hood Latch '64-65 Cutlass - For Sale
- Dual Snorkel Air Cleaner - For Sale
- Speedometer Housing TH350 - For Sale
- Defroster Manifold GM#397784 - For Sale
- Distributor Points RFI Shield - For Sale
- 69-72 Cutlass 442 Floorshift Black Steering Column Real GM --Redone
- Consoles for automatics
- 68-72 A&B body A/C COMPONENTS
- distributors various numbers and dates
- 68-72 vists / custom cruiser parts for sale
- 1970 Cutlass S/442 Seat Upholstery
- 1968 Horn Cap
- 1971 cutlass radiator support
- 1968-72 NOS f85 park brake switch
- 64-65-66 NOS sunvisor mirror Oldsmobile frame / glass
- 69-72 Batwing steering wheel horn button only
- 14x7 SSII SSII wheels Total of 4
- oldsmobile 455 c heads
- torker manafold
- Steering wheels / columns for various models
- KA heads W30 replacement
- Crack 455
- 455 valve covers
- 455 oil pan
- 64 cutlass 2 dr. Being parted out
- olds parts
- Nos gm emblems # 231212
- Fuel / Air mixture mixers for sale
- used oem harrison heater core 68 442
- G body rearend
- 1969 W34 Toronado Part Out, Hilliard, OH
- 72 steel hood w/ Louver | original
- 72 Hood Louvers | original
- Sport wheel hub "NEW" Repro, Parts Place
- 69 Cutlass 442 Plastic Bash Bezel Assembly-- Nice GM Part
- 68 Cutlass 442 Radiator Top Plate -Nice GM Part
- 68 Cutlass 442 Rear Tail Light Assemblies-- Excellent GM Parts
- 77-79 88/98 rear bumper
- Passenger side mirror 1967 Olds Cutlass 442 Vista-Cruiser
- 70? - 71 Radiator tag - SB
- 1969 nos center grill support ( piece between grill work )
- 1977-96 B-body wagon rear sway bar on sale
- 1969-72 OEM black bucket seat lower panels
- OEM black seat belts/retractors
- Wheels
- 1965 Cutlass Brake pedal assembly
- Cutlass Supreme B85 moldings
- 58 Oldsmobile Horn Cap
- Ram Air Hood
- NOS 1970 Cutlass W31 442 W30 W-27 Cover
- 1968 Cutlass F85 14" hubcaps and wheels
- 1970 Olds Cutlass 442 8 track tape player case
- Edelbrock Performer 400-455
- 1968 Cutlass hood hinges & ebrake pedal assembly
- Any interest in a 1978 olds 88 am/fm 8 track
- NOS 60/63 Oldsmobile License Lamp Assembly
- 67-68 4 piston disc brake parts lot Cutlass 442
- 1941 model 66 coupe side chrome
- 1969 OEM Black Bucket Seat Headrests $300
- 65 cutlass 442 reverse light plug
- NOS Power Trunk Parts 1971 1972 Cutlass 442 Hurst Olds
