View Full Version : Parts For Sale
- 1968-1972 restored air cleaner and Clock Art
- FS: "one-way" Parts Place 70-72 top switch for repair
- 68 W-30 455 parts including "D" heads
- Flywheel cover
- 70-72 W30 red wells
- 82-88 G-body Parts/Schematic Bible
- Partin out 67 Olds delta 88 custom
- 12 bolt "O" 2.56 posi rear, rebuilt f/s
- NOS Mickey Thompson valve covers
- 1970-72 Olds 442 ram air cleaner Cutlass W-30
- 1965 Delta 88 Sedan in a yard, any interest?
- NOS emblems, waterpumps, etc
- 68 Cutlass RH turn signal lens
- Edelbrock cylinder heads complete pair. Part 60519
- 1970 Rocket 350
- Saganaw 3 speed Transmission
- Edelbrock 60519 brand new set aluminum heads
- 1970 grills Olds Cutlass "S" W-31 Rallye 350
- 68-72 condensor mounting brackets
- Control Arms & 442 Manual Steering Gear Box
- PARTING out ( 4 ) olds cutlass dayton ohio
- Side and rear glass - Cutlass
- FS - carbs, generators, oil bath element, more - 1954 Super 88
- FS: Early Olds, Cadillac, Pontiac dual range flywheels CHEAP
- Msd Blaster 2 coil
- Speedometer ratio adapter .8653
- 70-72 w30 Red wells
- parting 64 cutlass or whole.
- Dallas area SB Olds parts
- 455 parts
- 1969 and 70 hood grills
- 1968 og air cleaner
- Nos gas pedal
- New repro 69-72 Supreme Convert outer window sweepers
- 1968 oldsmobile 98 convertible
- Trunklid stainless trim set - '70-72 Cutlass/442
- 1970-72 442 Cutlass parts @ Quad States sept. 12th
- 1969 Ash Tray
- Looking for 2nd generation T Top 75 H/O -I have a set but 1 T-top has crack in glass
- 394 Engine & trans for sale
- 1968-69 Olds 442 wheel opening moldings
- 69-72 Floor Shift Column NON TILT
- 69 AT shifter & cable
- PARTING OUT 3 1970 -72 cutlass dayton ohio
- 1968 Cutlass quarters and wheelhouses
- 1964 -69 manual console bases and top plates
- 1968 and 69 possible other years antenna mast
- 1971 nos "s" emblem
- 355 short block w/ probe pistons
- Amoco LDO oil 10-30 or 10-40 Case $28
- Kp 8005 pioneer
- For Sale: 70-72 Post Coupe Window Fuzzies
- Parting out 1964 Cutlass convertible
- Cutlass rear ends
- Full Size Drum Brake Spindles. LH has speedo cable hole
- Oldsmobile dealer eigth tracks
- 1971 Engine (Rocket 350)
- 425/455 LH exhaust manifold
- 1969 Cutlass Front bumper
- Rally-Pac 1975-1977 Olds Cutlass 442
- Notched valve covers 1968-72 Olds 442
- Tilt Steering Column 1969-1972 Olds Cutlass 442 V/C
- Brake booster for Disc brakes/replated
- 1965-66 Speed Warning Olds 88 98 Starfire
- 15" olds ss3 rallye wheels full set
- 71 72 cutlass and 442 distributor
- 1971 442 455 Large Valve Heads Fresh
- Mint 8 track face plate 1972 Cutlass 442 Hurst Olds
- 1968-1972 8 track front pad Olds Cutlass 442
- 1968-1972 8 track housing Olds Cutlass 442
- Very Good Condition 350 and TH350
- 66 442 steel wheels for poverty caps.
- 64 cutlass waterpump & radiator.
- 64 cutlass fender drivers side left solid
- 72 supreme $1800
- Chassis manuals
- hoods
- 68 69 70 71 72 Cutlass 442 Convertible Bright Stainless Trim—Excellent Real GM parts
- 68 Cutlass 442 Chrome Air Conditioning Vents—Nice
- Dual carter 450cfm carbs and mallory compact distributor
- 1977 Fisher Body Service Manual
- Boxed Rear Control Arms- Illinois
- 1967-1969 automatic console chrome top plate
- 1969 W30 carburetor
- Custom fabricated American made valve covers
- 77 cutlass sending units
- NOS cutlass cruise control cable
- 70-72 cutlass speedminder
- WANTED: 71/72 OEM 442 OAI hood
- 1967 W30 OAI Track Pack Repro. air filter housing, hoses, duct work, NOS Air filter
- 1968 W30 TM code posi rear, cleaned, missing 31 spline axles but otherwise nice.
- 68 69 Cutlass 442 Glove Compartment Lock w/ Matching Key—GM
- FS - 70's Cragar SS wheels & Other Parts
- New/Restored Parts
- rally pac , nos sender
- Mickey Thompson valve covers, knockouts intact
- Edelbrock Aluminum valve covers Polished
- 1973 interior door panels
- 65 cutlass pass fender
- 1970 cutlass only sport mirrors
- (2) SSIII 14x7 wheels and tires
- 455 flex plate
- 68 Cutlass front fender trim.
- 68,69 Cutlass parts for sale
- 12 Bolt 0-type rearend
- Water pump A-1 Cardone Part# 58294
- ForSale: Rear sway bar
- 7042250 Quadrajet Carb
- 1977-79 Olds Delta 88 /98 parts
- 1970 4 door hardtop door panels. Gold cloth, PW PDL
- 1976 Omega Interior Parts
- 1971 Olds 455 carb 7041252
- 1969 oldsmobile 350 clean rebuilt ... Sold car
- 1970 442 W30 NOS GM Lifters
- 1970 NOS GM PCV Hose
- NOS 1970 Headlight Housings R&L
- 72 Cutlass Convertible Frame
- 407895 2 fan shroud.
- 69 large snorkel breather.
- 71-72 Cutlass/442/Vista front fender.
- cast iron Battens with Victor intake
- More NOS stuff
- 70-72 Tan Dash pad
- 72? 442/Cutlass rear bench seat.
- 1970-1977 Olds Cutlass 442 sport steering wheel
- 68 442 4-speed distributor 1111287
- Two New Moog 1344 Super U-joints 235
- Carter Muscle Car Fuel Pump M6109
- New Comp Guideplates & Polylocks
- 64-72 heater box seal set
- 1980 Steering wheel-black
- '80 442 Tan & 85-88 Claret 442 Steering Wheels
- Complete 350 ci and turbo 350 for sale
- NOS Carter Competition Series 750
- Edelbrock 065 Dual Quad Manifold
- Brand new Electronic ignition conversion $140 shipped
- 66 442 R code steel wheels
- 1969-1972 window cranks
- new battery tray and rear license plate
- 70 71 72 Cutlass Supreme Hardtop Glass GM Soft-Ray
- 1972 cutlass 10 bolt
- 68 to 72 nos sill pi lates
- 70 455 long block.
- 8 New 425 .030 SP pistons & Childs & Albert zero gap ring set
- 425 engine parts for sale
- 70-72 convertible trunk lid
- 1976 running 260 v8 2brl 70,000 miles 350.00
- W37
- NOS 70-71 72 73 74 Glove box lamp reading/map light
- Oldsmobile Parts on ebay this week Updated 03/22
- 68-69 G block 400
- Seat Belts (Cutlass)
- 65 442 400
- Cutlass sheet metal
- 1973 Cutlass S interior door panels
- 4 15x7 SSII bolt on cap wheels caps & rings
- New 68-69 console mounting brackets
- New gm parts
- 71-72 NOS Cutlass Parking Light Lens (AMBER)
- 1965 F85 Right Front Fender $250
- 60/40 power drivers seat parts 1976 Cutlass 1979 Delta 88
- 4.11 Ring and Pinion for 10-Bolt Corporate Rear End
- 70 - 72 F-85 Fender Emblem
- Head liner Bows NON STAINLESS
- 1970 Cutlass Supreme Hardtop and Convertible New & Used Interior Parts
- 1970 Olds 98
- 66 442/Cutlass belt trim moldings.
- 67 lower tail light lens
- 70-72 8 track and original console in great shape
- Sharp valve cover pattern
- Single groove steering pump pulley
- LPW aluminum rear diff cover
- Windage tray & Valve Springs
- restored '70-'72 speedos & fuel gauges.
- Parting out 71 olds cutlass 4 door/ 2 door parts dayton ohio
- Numbered Correct ALTS, RADS, Master Cylinders Etc.
- Parts to build 455
- edelbrock 455 Alu intake
- holley 750
- 70-72 Courtesy Light Harness
- F heads, manifold, etc w30
- 68-72 Convertible Only Rear Seat Upper and Lower
- 70 Cutlass Supreme Convertible New Seat Covers and Door Panels— Green
- 67-69 auto shifter 3 speed
- E-400 engine, 7a-409147 heads, HEI, 6" WP
- 1976 oldsmobile cutlass salon 5 spd manual parting out
- Parting 75 98 2 door
- Nos sill plates
- 1969 w-30 and 31 re-pop air cleaner
- 455 blocks
- 47 olds sedan for parts or restore
- Performer olds 455 intake manifold
- 68-72 Vista side glass
- 1966 Toronado dash
- 47 Olds Sedan parts car or for restore
- 63' Full size drums
- 1968 and 69 air condition side vents
- License plate holder
- 1968 and 1969 a body inner fender braces
- 1968/69 side marker lights
- 1971-72 Cruise control
- Parting out 1972 Cutlass Supreme
- 1971-72 4-core radiator top plate 442 W30 Hurst/Olds
- 4-core radiator top plate 69-70 442 W30 Hurst/Olds
- 69 Cutlass/442 headlight housing.
- 1965 Jet Star 1 for parts
- !964 Jet Star 1 For Parts
- For Sale: NOS 70 Cutlass Tail Lamp Housing - with Chip
- 1964 cutlass fenders
- 68 toro bumper NOT MINE
- Original 0 mile 1972 442 350 Engine
- f/s at Lansing yard 71 350 eng
- Mondello Block letter valve covers
- Rare custom Chevy 12 bolt setup for 73-77 with 4.56 Eaton posi
- NOS 1972 Hurst Olds/Supreme grills l&r in GM boxes
- NOS 1970 Supreme grills L&R in GM boxes
- 1970-72 am-fm
- *FREE* Jetaway transmission
- 1970-72 Dash Pad
- 1971 Cutlass 442 tail lights
- 425 engine hardware
- Non-AC brackets
- 1972 GM Saginaw Steering Box --Low Miles
- Delco-Remy Voltage Regulator Nice Unrestored GM Part—
- Need 1966 dynamic parts
- 1966, 1967 "A" Body Door Ventilator Frame
- Big body posi rear end and parts
- olds 350
- 70 Cutlass Supreme grille - RH - nos
- 67 cutlass...headlamp mounting panel
- kb olds 403 pistons and main girdle
- 1969 Olds 350 Cast 4 bbl intake manifold
- 1968-72 convertible padded pillars
- 1969 A body two spoke steering wheel
- "KM" pulley
- W27 for sale on Hemmings
- 1968-72 Cutlass S 442 Post doors
- 1968 Cutlass S 442 W30 Vista F eighty five complete jack assy.
- 1968-69 Cutlass S 442 driver front wheel well molding
- 1967-68 Nice bucket seat cores
- Is this ring gear still usable? 3.31 Chevy ring & pinion.
- HEI Distributor $30
- 1964-1965 Rear defogger switch and vent
- rear defogger
- 1967 blue carriage style seat belts
- 1964-65 A-body horn relays
- Switch pitch trans kickdown switches
