View Full Version : Parts For Sale
- Gas Tank
- Oldsmobile floor mats (black)
- Toro Oil pan & Pickup
- Rebuilt 455 stock rods
- .060 455 pistons new in box
- 1970 speedo
- 1967 Bumper jack
- 1970 Cutlass Supreme Hood Spear
- 1967 Cutlass Kick Panels
- Rear side panels (black)
- 68 Cutlass/442 Convertible sheet metal
- 400 V-8 Frame Mounts--68 442
- 1968-72 Cutlass S Nice Whiteish rear seat plastic armrests
- Bumper jack
- '70 parts
- New dana 60 strange engineering posi 4.10 rear end a body
- 1970 power trunk release
- 1970-72 Supreme coupe nice used rear panels, blue, white, pearl, green
- 1970-72 Oldsmobile Washer Nozzles
- 1967 442 heater hose 393530 NOS
- NOS inside mirror 1973-75 Cutlass 442 Hurst Olds 911620
- Olds 455 with TH400 combo for sale
- Olds455 with TH400 with full exhaust FOR SALE
- Intake for early Olds
- '68 Distributor
- '68-72 Power Steering Pump
- '68-72 Olds floor mats
- Olds 330 Accessories
- 68-9 Cutlass 442 Rally Pac Gauges
- 1970 350 bare block
- Need trans linkage parts
- Edelbrock O4B 400, 425, 455 Qjet intake
- 69 dog dish caps - fusick xcellent $175
- New pass side lower door skin 70-72 ohio more parts
- 68-72 olds cutlass air cleaner 2 / 4 bbl ( ohio ) ex parts
- 7028251 Carb
- 442 W30 parts
- 64 65 kick panels
- Aluminum Water pump
- Small block Aluminum intake
- 1969 Olds 350 Block and engine parts
- 1968-72 Drip rail corner pieces, $13.00 pair shipped.
- 73 Olds valve covers ( Oldsmobile printed on it)
- 3/8" Oil Gallery Plug with 0.0400 hole & 29/32" freeze plug
- 68-72 rolling A-BODY FRAME ( OHIO ) $800
- Olds 215 V8 for parts
- TH-400 TCI Performance Transmission Package
- Bolt On Center Caps
- 64 442 4 speed shifter base
- Lakewood 4 speed skattershield
- 68-69 radio delete plate
- New Comp cams roller rocker kit
- Hurst Hatch T-tops complete 76-77
- 1970 442 original passenger side grille
- 68 floor shift speedo
- 1971-72 Olds Cutlass 442 POWER WINDOW SWITCHES
- 77 Toronado Crank Triggered Ignition
- 1971-72 Olds Cutlass 442 POWER LOCK SWITCHES
- 1964-1970 Olds Cutlass 442 Power Window Switches
- 1964-1966 Tach housing Olds Cutlass 442
- 70-72 Supreme moldings
- 394 engine and transmission for sale
- NOS 1968-72 Underhood Lamp Olds Cutlass 442
- FREE Floor Panel Patch
- 76-77 cutlass hurst hatch complete
- 86-88 Cutlass Tail Light Lenses
- 442 shifter w base
- glove box doors, emblems, and ash tray doors 70-72
- NOS and used 442 emblems 70-72
- 68 442 air cleaner
- 71-72 Parking lamps
- 1970-72 Rochester Gas Vapor Canister
- 72 Red quarter lights 80 Bucks
- 1970-77 Olds Cutlass 442 Sport Steering Wheel
- 71 Cutlass Supreme Grilles
- Lo miles original 1970-72 442 W-30 Sport Steering Wheel
- 1970-1972 442 and W-30 Olds emblems
- 1968 Wood Grain Steering Wheel Cutlass 442 Hurst
- 1971 Cutlass 442 bumper jack...
- 1968 Cutlass 442 Hurst Olds HUB 3923697 for wood grain wheel
- 68-69 Cutlass/442 Sports Coupe/Hardtop/Conv parts
- SSII 14x7 wheels - set of 5
- 10 bolt 4:10 posi rearend
- OLDS ROCKET 350 V-8 Motor #5 Heads in CT
- 68/69 W30 original red fenderwells
- '68-72 Power Seat Assembly
- '69-72 4 Core Radiator Cover
- 1970 olds cutlass core support sand blasted ready for paint ( $ 250 ohio
- Parting out 71 Cutlass Supreme
- 85-87 442 Center Caps - PHOTOS
- parting out 1972 cutlass
- 70 Delta 88
- 1970 Olds Dealer Floor Mat Reproduction
- 70-72 console
- 65 F-85, Cutlass, 442 P/S fender
- 68 442 Glove box door black
- 1969 Cutlass hubcaps
- 1969 Cutlass trunk bar - real nice driver quality 85 plus shipping
- 1970-72 Cutlass, 442, Rallye trunk harness cheap.
- 1970-72 restored fuel gauge, cleaned, painted, new lens.
- 69 70 71 72 2 bbl 4 bbl air cleaner red black
- 70-72 pass side lower door skin new
- Arp head bolts $50 + ship
- 91-92 OCC parts
- 1967 330 engine/parts
- 70 nos hood moldings, rally pac
- ePay distributor 1111151 6B1
- CL find Mid-MI 403 core $150
- 2.5 New Pypes Dual Exhaust 78-88 Cutlass
- Wheel opening Mouldings 68/69
- Holley 800 cfm carburetor
- 70-72 bench shifter / rods
- Street strip ported c heads
- 71/72 core support - $100
- Fiberglass front fenders and hood from glasstek
- 1970 fiberglass ram air hood
- 1968 og air cleaner
- 330 engine for sale
- 1949-1965 Olds Illustrated parts books Cutlass 442 88 98 Starfire
- Nos delco 68/9 choke assembly
- 200-4R Transmission
- Moser axles cutlass g-body 78-88 28 spline
- NEW 7.5 10 bolt gears 4.10 4.56 3.42
- NOS Mirror
- Aftermarket W30 red inner fenders for 70-71
- Nos water inlet set up complete kit
- open face alternator
- 1970-72 parts
- A few parts from my 72 Cutlass
- Nos sun visor receptacles
- 1949 Olds Hood
- 69 cutlass trunk molding
- 68/69 rally pac
- '37 Olds Seat Covers For Sale
- 70-72 Passenger Fender 442
- 68-72 4 speed manual steering column clutch pedals
- 65 bucket seat
- 11" clutch plate
- 1967 olds cutlass stock 330 turn key eng and trans..$1500
- 75 cutlass gauges
- 72 cutlass gauges
- Rare find NOS 68-69 GM passenger full quarter
- 74 88 tail lights
- Sharp Valve Covers.... BRAND NEW
- 70-72 plastic dash panel for Vista or convertible
- not mine nos 70 cutlass fenders
- 69-70 NOS defrost switch for 88 and 98
- 1971 Cutlass S door panels
- 73-77 Cutlass/442/Hurst NOS Dash Trim and Motor Minder!
- 75 H/O T-tops
- 72 455 625 hp for sale
- Recommended Seller - "GM parts guy"
- Exiter Polycast rims, NOS set of 5 complete $750
- 68 AND 69 A-Body parts
- 1967 radiator lower support
- 1967 Radiator Shrould
- 1967 Bumper Brackets
- Trans for sale
- 1967 442 Owners Step In
- not mine.. ebay 70 w30 engine
- 1966 cutlass insturment panel
- 1973 delco remy altenator for sale on ebay
- 70-72 ac/heater parts + ex dayton ohio
- 70-72 CUTLASS DRIVER SIDE DOORS $100 AND UP dayton ohio
- 1970 cutlass driverside fender needs work $100 dayton ohio
- Emblems
- 1970 88/98 PIM [assembly manual]
- 71-72 Cutlass 442 Front Bumper Guards -Nice GM
- 1970 cutlass pass fender / 70-72 parts dayton ohio
- '67 Cutlass - parting out in Huntsville, AL
- Gauges
- Hidden Wiper Arms
- 1978-79 olds cutlass supreme brougham header panel & frt bumper Ontario Canada
- 1971-72 "Cutlass" Script Trunk Emblem
- Dash Parts and Rally Pack Harnesses
- 1970-72 Restored floor shift speedo, gas gauges, more.
- For Sale.....1971-76 Complete Olds GM Convertible Top Motor and accesories
- For Sale.....A Rare1973 Olds Delta 88 Door Mounted Tempeture Gauge.
- 1968 - 69 Cutlass Speedometer with Speed Minder
- F/S 1968 Olds wire wheel covers
- No reserve bullet mirrrors / make fair offer on 70-72 parts and its yours will ship
- 70 71 Cutlass SX/Supreme moldings/repo 442 hood
- 64 65 66 67 cutlass a/c and convertible various parts blow out ,cheap
- W30 Intake - EXCELLENT CONDITION - PICS INSIDE
- 1969 cutlass 442 f85 non vented dash pad
- Goodyear Polysteel Radial LR-78
- 71 72 headlight housings
- 66 Toronado parts
- 4 ssIV wheels/built th400
- NOS coil bracket
- New 1972 350 rocket turn key ex parts trans 442 exhaust msd
- 1970 w30 water pump
- heres whats left of my 68 stuff
- new 3.90 Type O Richmond gear set
- NEW OLDS NASCAR electronic Distributor
- OEM Polyglass G70X14 Raised white letter
- Experimental 350 Siamese block
- 68/69 400 intake
- 68/69 400 choke pull off
- Be Cool O.E series radiator
- 1967 Cutlass Radio
- 1969 cutlass grills
- Early 60s windshield washer reservoir
- needle pilot bearing
- Need 66 442 Hood
- 1969 Oldsmobile 442 400 Engine&M20 4Speed - $3500 (Grand Ledge)
- 70-72 Cutlass S/442 Package Tray - Black
- Original OLDS 3.42 Ring and Pinion
- 69 SS1s With new G70 14 redlines
- 1970-72 Olds Cutlass Cigarette Lighter/Housing
- Convertible Top Hooks
- Fuel Door Bumpers
- 1971-72 Wiper Switch/Escutcheon
- 75 hurst stainless targa trim and misc .
- 75 hurst hood
- bucket swivel base
- 75-76-77 supreme misc wiring
- Listed more Cruise parts
- Stainless steel door trim plate
- 76-77 supreme opera window trim
- 1970-1972 Olds Cutlass 442 clock Vista Cruiser
- 1973 SSIII Wheels 14x7
- For Sale.....1970 Oldsmobile Power Trunk Release
- 1968 cutlass sunvisors
- Oldsmobile Rally Wheels
- FS: Brand New Hooker Headers 3902
- 1966 cutlass front hood chrome
- Newly Rebuilt Alternators---All Years
- Steering Column
- 70 NOS hockey stick single (driver) $150
- not mine 7a's forsale
- 70-72 cutlass parts DOORS FENDERS TRIM AC & MORE DAYTON OHIO
- 69 Cutlass Convertible Parts
- How much is a 70 442 bumper worth
- Original W Z exhaust manifolds
- 1967 Seat Belts
- 1967 Cutlass Opera Lights
- idle control unit
- 71-72 rear bumper
- 70 w30 distributor 1111979, shifter, intake $750 + more
- 1970 442 Hood Extension
- 70-72 auto console and shifter
- 1965-1969 4 Speed Console Top Plates & Parts
- 1968-72 Cutlass S rear window lower channel, trunk upper weatherstrip channel
- 65 P/S pump & Brackets
- New 71 center stone shield rocket
- 7036254 Carburetor
- Pair of '70-'72 W/Z exhaust manifolds for sale
- Clearing out some 72 Cutlass parts, dash, buckets, etc
- 330 Jetfire engine
