View Full Version : Parts For Sale
- 66 442 hood
- 67 Trunk Trim
- 70-72 Cutlass jacks
- 1968 Cutlass Horn Button
- 1967 Jetaway 2 spd and posi rear end, carb
- 70 W31 hot air tube
- SSIII 15"x8" wheels for sale 900.00usd
- BPO TH400 Must go!
- Air dam
- 1972 Dash Pad (blue)
- Air cleaners, hot air tubes and v/c vent tubes
- Mickey Thompson & Holley valve covers
- 1966 Cutlass 442 Tri Carb L-69 Intake Manifold Setup
- NOS GM 1971-1972 Cutlass Grille Stone Guard
- Center console (70-72 Cutlass/442)
- Trailing arms (boxed)
- o-axle 4:10 Richmond ring and pinion
- Misc 1970-72 Cutlass part
- ssii for sale or trade
- 65-68 right W exhaust manifold
- 68/69 remote mirror D/side
- New supplier found?
- 70-72 Cutlass 442 Glove Box Door Black
- 71 442 Ralley Pac harnesses & Dash/Misc Stuff
- 1971 NinetyEight Parts For Sale
- 1965-67 NOS Drivers Arm Rest Base
- 4 Speed Non-Tilt Column
- 1968 front bumper and rear
- Carb, intake, air cleaner
- 69 Cutlass Front Bumper
- 1969 w-31 heads
- 1967 Delta 88 misc. parts
- SS 2 Wheels and Tires
- 1972 Cutlass Supreme parts car
- Full in box
- f/s 14" SSII sport wheels with old tires
- 83-84 Hurst Olds Rims
- 400, 425, 455 engine parts for sale
- 68 12 bolt TW code 4:33 rear
- 12 Disc CD Changer FOR SALE
- 67 Cutlass Supreme parting out
- 1964 330 top end parts
- 800 cfm carb core f/s
- Rebuilt Olds 455 w/TH400 for sale
- 77 cutlass sill plates, trunk lid lock emblem, hood ornament
- Oldsmobile parts and illustration manual thru 77
- 71 Olds chassis manual..good used
- 1965 400 b block
- 1970 Non air alternator brackets and pulleys
- 66/67 conv door & 1/4 glass
- 66/67 l&r door latch assys
- 66/67 cutlass/442 1/4 dropoffs & wheel houses
- 68&69 cutlass/442 rear body taillight panels
- 70-72 'S' 442 NOS Trunklid
- 1960s Transparency Light Box
- 84 big car REAR STABILIZER
- For Sale: Mallory Unilite 4763401 Distributor
- A few parts to sale
- 68/69 Non Air Heater control
- Nice driver steering wheel
- Original rallye 2 trim rings
- 69-72 Glass & Mechanics
- Parts
- 7040251 Core
- NOS 1967 Tail light lens Olds Cutlass 442 W-30
- red 1993 Achieva S steering wheel
- 1977 WAGON - Jack, what else?
- 1970 Hood Tooth
- 1968 Cutlass rear floor mats
- 1968 Vista Cruiser Tail light assembly
- FREE: Custom Cruiser parts
- 1970 Parts car (F-85)
- NOS 1969 Olds F-85 W-31 Wiper Switch Delco 1994068
- 1970 Sport Mirror Olds Cutlass 442 W-30 W-31
- 67 Toronado engine brackets
- 7043255 Quadrajet
- 1971 random parts Cheap
- Olds type "O" rear end
- 1970 F-85, Cutlass, "S" W-31 grills Olds
- 1976 Cutlass Dashboard
- NOS Steering Wheel 1968 Hurst Olds 442 W-30
- 70-72 455 machined and ready for assembly
- 69 Delta Sun Visors,Black
- 1961 olds grill
- 67 cutlass supreme convertible for parts
- Gold Seat belts full set
- Front or Rear Floor mat
- 69 Delta parking light lense - LH - nos
- 1968 Vista Cruiser (parting out)
- 6.140 2.200x.990 pin Crower Billet rods
- RARE 66,67 f-85 post coupe window ledge moldings
- Hood latch / release
- AC parts 72 cutlass
- 70-72 Supreme passenger rear window and parts
- 72 Ga W30 heads
- Edelbrock 455 Performer Polished For Sale or Trade
- 1972 cutlass convertible parts
- W30 emblem
- Small parts for 69 Olds
- 68/72 Big Block Hooker Headers
- 71-72 GM Delco 6 x 9 Rear Speaker and Metal Grille
- Misc. parts
- NOS 1970 Delta 88 Left Front Fender mldg
- parts for sale off my omega
- 1970 Cutlass fender
- 1970 Clutch assembly
- Parting out a 72 cutlass supreme convertible
- Stewart Warner 2 1/8" Oil Pressure Gauge
- 1100853 Open Face Alternator
- 70 flattop wagon parts needed
- 71 72 Cutlass 442 Front Bumper Bracket Set
- 70 nos tail light, 4 speed console, + more
- parting 71 toronado
- 66 67 Cutlass heater controls
- Bucket seat floor pan section from 72 Cutlass
- Heater outlet for bucket seat/console cars 70-72
- NOS 70 Olds TCS solenoid Delco 1114428
- 64-74 GM A body front disc brake conversion kit
- 81-88 cutlass reverse light assy
- Parting out 1973 442
- 70 350 block
- 7040251 core
- 68-69 non air heater control unit-refinished
- 1978 cutlass broughram parting out car w/blk int.
- 70 OW transmission
- Restored 72 455 carb 7042251
- 65 Cutlass V8 engine harness M&H, NEW!
- 66, 67 442 cutlass hardtop power windows
- 330 or 350 steel crank
- 64,65,66 tilt column shift
- Grant GT 13" steering wheel
- 71-72 Cutlass Seat Covers New in Box
- 8.2" posi rear 256 gears
- 3.23 gears NEW
- 68-72 Olds 400/455 Valve Covers—real GM
- 68 69 70 71 72 Cutlass 442 non AC under-dash heater core housing
- 68 69 70 71 72 Olds Cutlass and 442 Air Conditioning Compressor Mounting Bracket Set—
- Miscellaneous Parts for Sale
- 1970 98 2 Door Hardtop parts car
- 350-455 p.s. brackets and pulley
- 455 olds CN 4 spd. crank
- Misc Parts. Rockette 8 Air cleaner, F-85 badges and more.
- omega parts
- 49 4 dr rt Gravel Shield used
- NOS 1952 98 4 dr rt Stone Shield
- NOS 1950 88-76 2dr and Conv Gravel Guard
- NOS 49 98 2 dr left gravel guard
- NOS 1949 98 4 dr left Stone Shield
- Polished metal and Mondello valve covers
- 70-72 Supreme left rear molding
- am/fm wonderbar
- used th400
- TriCarb manifold
- 70-72 automatic console,driver quality
- G heads
- 70-72 amber lights and housings
- Arm rest base - the loooong one! Driver side
- 70-72 reverse ligh lenses
- 77 98 Regency hubcaps
- Manual flywheel
- 1968/69 2 and three core radiators
- 1970 rear window defogger
- TH400, Hurst Shifter, & Torque Converter for Sale
- 70 Power Trunk realease
- 1968 Oldsmobile Cutlass & 1973 Cutlass Parts
- Brake Pedal pad
- 68 Olds Rocket 350 V-8 Motor for Rebuild
- 68 Cutlass 442 RH Fender
- entire drivetrain
- 64 or 65 auto console top plate
- 64 or 65 auto console spears
- 4 Aluminum wheels for sale will Be @ Spring Carlisle PA Saturday
- Floor shift tilt from ?
- 66 330 heads, intake, dist,
- Real nice running 455
- 1963 98 NOS Rt Front Fender lower mldg
- 70 Cutlass convertible parts
- 70 Cutlass convertible rear clip
- 1965 olds 330 engine for sale
- 68 69 70 71 72 Cutlass S (Model 87) or 442 2-Door Hardtop Rear 1/ 4 Windows
- 1967 442 frame with factory disc setup
- lighted rearview mirror 68-72 Cutlass
- 69? 70 -72 backdrive linkage - Cutlass
- 68 thru 72 bench seat end trim stainless
- Parts at Carlisle (NA140-141)
- 65 442 scoops
- Holley Finned Aluminum valve covers
- 1966 olds cutlass RARE Parts for Sale
- 70-72 hardtop interior panels window fuzzies
- 70-72 350-455 non 442 air cleaner base
- 1962 olds 88 parts
- 1965 bucket seats
- 215 and hydromatic trans
- OAI for sale on ebay
- copy of the Oldsmobile parts book years 66-69
- 57' Olds 4 Dr. Misc. Trim
- NOS 1971 1972 Stone Shield Olds Cutlass 442 Vista Hurst
- 70-72 Cutlass/442 AC duct parts
- 66 442 Hood
- Nice 66 Hood lip molding
- Complete 66--67 Dash
- 66 "B" Heads
- 1967-1969 Cutlass Automatic Floor Console
- 65 Starfire parts C/L not mine
- 65 Cutlass Hood Trunklid
- Carb core 7028252
- Shipping
- 67 442 4 Speed parts PARTING OUT CAR
- 3 1971 G heads $100 obo
- Olds 350 Short block
- #5 Heads
- Set of 5- 14x7 SS2 rally wheels with bolt on centers
- 1972-74? Nice "Seat belt" housing on dash
- 1969 2 spoke black wheel
- 70 Power steering pump
- 350 and 425 Distributor
- 455 Exhaust Manifold- 398708
- 455 block and rods
- 1970-72 Console + Shifter Cutlass 442 Olds
- Great CO Vendors
- Great CO Vendors
- R&L Ex Manifolds 65-68 A body RT NOS
- 8 Track Door/ Metal Housing
- NOS 81-88 Cutlass license plate delete plate
- 1935729 Radio Condenser Capacitor 57 58 59 60 61 62 63 64 65 66 67
- 1970 W-31 JO trans-SOLD
- 70 bullet mirrors NOS
- 1970 12 bolt SF
- 72 black seat belt & retractor
- 68/69 cutlass/442 convertible quarter moldings
- Nos clock for 68/69
- Wire Spoke Wheel Covers
- .060 over engine
- Muncie M20 and Hurst shifter
- 65-67 400/425 crank
- No Longer For Sale 1968(?)- 1972 convertible top frame parts, chrome plated.
- SOLD Vintage Mallory Dual Point Distributor, 303-324 or 371-394 SOLD
- 1980's vintage dual snorkel air cleaner (H/O?)
- A couple G body vintage items, NOS
- 70 grills?? and headlight housings
- For Sale: Signal-Stat 170 Flasher
- SBO 330 w/C-Heads
- 15x7 SSIII'S
- 71-72 442 rear NOS bumper
- 4 14x7 SS2 rally wheels with bolt on centers
- 1969-72 Oldsmobile Cutlass/442 Lower Dash Cover
- 72 Cutlass rocker moldings
- Cutlass Cruise 1966
- Carb cores - 7041252 and 7042250
- Copy of the Oldsmobile parts book years 66-68
