PDA
View Full Version : Parts For Sale
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130
  1. 1964-66 GM tilt steering directional cancel pin and horn contact.
  2. 71-72 442 air cleaner
  3. 1100777 Alternator
  4. Rebuilt 400269 water pump
  5. NOS Medium Gold rear floor mats
  6. 1971 original 4 core ZK code Radiator
  7. 1972 ZN rad tag code 4 core radiator
  8. 1972 original OC rad code Radiator
  9. 1971 original SS rad code Radiator
  10. 68-72 Convertible Pillar Post Moldings Chrome
  11. 70' Water Pumps 404847 "X"
  12. 1966-67 FS rad code Radiator
  13. Radio from 72 Cutlass
  14. 1972 Cutlass 442 Cruise Control Servo and Bracket
  15. 69 442/cutlass core support
  16. 1968 Olds full sized radiator shroud $100
  17. 70' Oldsmobile 14" hubcaps
  18. 1954-55 Speedometer head assembly $135
  19. 1969 Blue Sport Wheel
  20. NOS Chrome Sport Mirrors Cutlass 442 Hurst Olds 1973 1974 1975 1976 1977
  21. 1967 Front Bumper Brackets
  22. 1968 1969 Olds Cutlass 442 Vista-Cruiser Remote Mirror
  23. 68 69 442/Cutlass manual antenna base & lead
  24. 1971 442 black legendary seat covers new never installed
  25. 70-72 442/Cutlass heater floor duct for cars w/ console #406731
  26. NOS 66-67 Oil Breather Non-PCV FB-55
  27. 1981 to 1986 Cutlass Calais 442 Center Dash Vent Panel 557237 81 to 86
  28. NOS 68-72 Cutlass other GM A-body Rocker panels
  29. NOS 68-72 A-body door hinges - 3 NOS
  30. Oldsmobile vanity mirror...
  31. 83 H/O Computer....
  32. New Emergency Lamp Kits
  33. 70 71 72 C utlass 442 Glove Box Lock Cylinder, Latch and Key-- Real GM
  34. 1969 70 GM Cutlass 442 Delta 88 etc. Real GM Ignition lock and Key
  35. Freeze Plugs Core Expansion Plug Assortment
  36. REMFG 1112085 DATE 1 K 7 REBUILT with NEW and NOS GM PARTS
  37. 1111982 Points Distributor has MS 408 24 Vacuum Advance DATE Code 1 J 10
  38. 66-67 radio bezel...
  39. 1970 1971 1972 Dash Ash Tray Door and Springs
  40. 1968 Vista Cruiser for parts
  41. 1968 455 engine
  42. Olds main bearings
  43. 68 hood hinges....
  44. 1971 1972 Cutlass Hood Latch assembly with rod and pivot + spring for front o' hood
  45. NOS 3 Groove Pulley 72 Cutlass 442 A/C
  46. 1964 Oldsmobile Dynamic 88 Hood
  47. 1971 1972 A-Body Rear Black Seatbelts
  48. Custom 66-67 Cutlass Gauge Bezels
  49. 12 bolt Chevy 3 series posi.
  50. original GM parts...
  51. Hurst 4 Speed Shifter Mechanism
  52. 66-69 Factory 4 Speed Shifter Bracket
  53. Starter
  54. 1962 Olds Full Sized Tail Lights
  55. 455 OLDS 1970 Distributor with broken aluminum housing has MS 427 16 advance
  56. Misc hardware, fasteners, Free for the shipping
  57. T400 deep aluminum pan.
  58. 70-77 Ralley Steering wheel....SOLD
  59. 1970-72 wheel well trim
  60. 68-72 hood hinges
  61. 1969 455 intake - 398662
  62. M/T 455 valve covers
  63. 1970 auto floor shifter
  64. 1969 H/O 455 alternator - 1100852 55A
  65. 1970-72 tilt column
  66. 68-69 C heads
  67. 70-72 Cutlass Supreme rear quarter ext.
  68. 1970 442 tailights - original patina
  69. 70 455 Delco Coil + Bracket w/ Resistor and Original Battery Cable Tube 1970
  70. 1970 442 rear bumper
  71. Cutlass/442 head pipes
  72. 1970 Cutlass 442 Talight Lens--New and Nice
  73. 70-76 Cutlass 442 AC Delco NOS Fuel Pump #40712
  74. NOS Walker 35614 Trumpet Tip
  75. 1970 455 Preheat Pipe
  76. 1965 Cutlass 442 Convertible Window Weatherstrip Kit.
  77. 69 Lansing bare block for sale
  78. NOS Oil Pressure Sender for real gauges
  79. Vapor Canister 1970 1971 1972 Olds Cutlass 442
  80. Emblems Cutlass 442 f-85
  81. 68-69 Water Pump 400269
  82. 68-72 Cutlass 442 OEM Clutch and Brake Pedal set
  83. OEM Tail Light Lens 1971 and 1972 Taillight Lenses
  84. Valve Covers With Factory Paint and OK Timing Ink Stamp From Assembly Line
  85. 1968 - 1972 Cutlass TH350/TH400 Stainless steel transmission to radiator lines
  86. NOS 1966-7 Odometer
  87. NOS 1950's Odometer
  88. NOS 1965-70 Starter Field Coils
  89. Polished Holley valve cover
  90. Tilt steering column 69-73
  91. 1969 Black Sport Steering Wheel Cutlass 442 Hurst Olds
  92. SSI wheels & tires
  93. Oldsmobile Radio Knobs
  94. 1967 442 4 speed pedals
  95. Hurst Dual Gate 2 Shifter 4 speed Auto/ O.D
  96. NOS Front Floor Mats 1960's Olds Cutlass 442 88 98 Starfire
  97. 455 partial short block
  98. 1972 Supreme headlight bezels F/S
  99. 405233 69 hurst olds intake
  100. NOS Cruise Control Servo NEW GM
  101. Rebuilt 1965 442 400 engine for sale
  102. Oldsmobile Maar Clock STEERING WHEEL 1949 1950 1951 1952
  103. Reproduction price increases due to inflation
  104. 1970 Olds Cutlass 442 VAPOR CANISTER NA9 California
  105. 1968 / 1970 Olds Cutlass 442 Sport Steering Wheel HORN BUTTON
  106. Steering Wheel HUB 1968 Olds Wood Grain Wheel
  107. 1968 Wood Grain Steering Wheel Cutlass 442 Hurst Olds
  108. 7042953 carburetor
  109. Edelbrock Performer 2151
  110. Cooling System Parts
  111. 350 455 OLDS Starter Water Pump Alternator Caliper Cores
  112. 8.5" Corporate GM 10-bolt Posi Rear End and TH400 Driveshaft
  113. GM shift cable
  114. 1968 442 walnut wood steering wheel
  115. 1970-72 dash pad with vents - no AC, dyed black
  116. 15x7 Rally Wheels w/Bolt on Centers
  117. NOS Outside Thermometer 1970's Oldsmobile Style Cutlass 442 Hurst 88 98 Toronado
  118. RobbMC 550HP Fuel Pump (old style)
  119. Mini Starter BBO
  120. Longtube Headers BBO
  121. OEM Hose Clamp Kit
  122. Seatbelt Set
  123. MISC. BBO gaskets
  124. 1965 98 88 Starfire Jetfire R/F NOS Bumper Bracket
  125. 72-76 350 #8 Heads TH350
  126. Hedman shorty headers - Summit McDonough scratch and dent shelves
  127. 1971 72 Dual Snorkel Air Cleaner
  128. For Sale: NOS '69 '70 442 Hood Extension Emblems
  129. NOS gm waterpump 6 inch shaft olds V8
  130. G heads for 403 rebuilt
  131. NOS Olds Back-Up Lamp Pkg. 982124 1963 F-85 Cutlass
  132. Mondello Pulleys/Brackets
  133. 1969 LY Code Wheels Cutlass W-31 442 W-30 W-32
  134. NOS 78-79 Cutlass Grill Plate Emblem "Oldsmobile"
  135. NOS EES Vapor Cannister 1970 Olds 442 W-30 NA9
  136. N.O.S.COURTESY LIGHT LENS 74-76 DELTA 88 $30 + the ride
  137. 65 cutlass F-85 parts car
  138. 1966 1967 Olds Cutlass 442 Dash Switch Bezels
  139. 1970 olds cutlass rear speaker 7300614
  140. Accessory Rear Speaker 1968 1969 1970 1971 1972 Olds Vista-Cruiser
  141. NOS 74-76 BB Dipstick Tubes
  142. 1966 Oldsmobile 88 and 98 manual antenna parts
  143. 1972 Cutlass hood trim F/S
  144. 1969 Cutlass seat belt retractors
  145. 1964-69 4 sp. console top plate
  146. 1960 Olds reverse lights
  147. 2 587793 LH manifolds Olds dual exhaust
  148. Rebuilt 404847 water pump
  149. 1970 oldsmobile script
  150. 1970 -72 cutlass floor shifter
  151. 65 Cutlass/442/F85 Tail Panel Nice Shape
  152. Omega header panel emblems
  153. 14 x 6 SSIII Rims, Trim Rings, Snap-On Caps - Set of 4
  154. 1970 N30 Steering Wheel Olds 442 W-30 Show Quality
  155. 1972 Floor shift tilt column - Cutlass 442 69-70-71 72-73 also
  156. 1969 Cutlass 442 V-C dash wood grain 3 pcs
  157. 1970 Oldsmobile Night Watch components..
  158. Oldsmobile camshaft 400-425-455 engle JM18-20
  159. 2-nice 1968 deluxe black seat belt retractors
  160. Used T-3 Headlights
  161. Flywheel
  162. Nos oldsmobile gold and cloisonne promotional ring pristine #g313
  163. 68-69 trunk lite Cutlass 442 others
  164. 1955 Oldsmobile complete power steering set-up
  165. NOS 69-72 Cutlass 442 BB Battery Trays
  166. NOS 66-67 Cutlass 442 V8 Breather Caps
  167. 1973 -77 ? power trunk releases
  168. NOS w31 grills
  169. 1966 L69 tri carb parts lots ( 3 )
  170. 1963 Starfire tachometer $85 plus shipping
  171. cutlass emblems
  172. 1973-4 Embossed 350/455 valve covers for sale/trade
  173. NOS Delco Thermal Limiter fuses 6551258
  174. NEW GM Cruise control brackets 1970's 1980's
  175. Trunk light
  176. Seat belt console side anchor bolt covers
  177. Deluxe small buckle green females
  178. Hamill green deluxe rear seat belts exc set of 3
  179. Deluxe Green rear seat 3 belts
  180. 5 painted black 15x7 Wheels 5 NOS BOLT ON Center Caps 5 NOS TRIM Rings
  181. 1978 Cutlass Supreme rockers
  182. 1978 Cutlass rear trunk filler
  183. 1978 Cutlass Supreme column
  184. NOS Turn Signal Lever for Cruise Control Cars
  185. 1978 Cutlass t top glass
  186. 1978 Cutlass cable
  187. 1978 trim rings
  188. New in GM box door locks with used key to match fits both
  189. 1978 Cutlass Supreme window glass
  190. 1970? through 1972? Power trunk release
  191. 1964 starfire vacuum trunk release
  192. PYPES 2.5" cut outs
  193. 1970-1972 Heater Control Panel
  194. 1970-1972 Cutlass/442 Guage Set
  195. Rochester 750cfm $300
  196. 1970 442 Cutlass Black Seat Covers Full Set
  197. NOS 68-72 Cutlass 442 Blower Motor Switch
  198. NOS Convertible Rear Speaker Pkg. 1971 1972 Cutlass 442 Hurst Olds
  199. NOS 72 Cutlass Supreme R.H. Grill
  200. 12 Bolt Olds 2 series posi #673
  201. 1972 Cutlass Supreme OEM hood trim F/S
  202. Tachometer 1964, 65, 66 GM 6411793
  203. 1965 Cutlass/442 Side Moldings New Chrome
  204. Carbs
  205. NOS 78-88 Cutlass 442 Shifter handle rebuild kit
  206. 1920' 1930's Headlight Bulbs Cars Trucks Harleys
  207. BB Oil Dipsticks Early style part # 400714
  208. 72 Cutlass 442 H/O OEM Deluxe Seatbelt Shoulder Harness
  209. NOS 1970's AC Radiator Caps GM cars.
  210. 70 442 carburetor 7040257 UJ 3169
  211. Complete running drivetrain for sale
  212. 1965 442 Cooling Fan
  213. Rally gauges 68 - 69
  214. Rally-Pac Gauge 1975 1976 1977 Cutlass 442 Hurst Olds
  215. 72 Olds 350 4 barrel intake manifold.
  216. 1955 Olds 98 dash support
  217. 68 sport wheel hub
  218. Pf30 oil filter and gm air cleaner wing nut
  219. 1970 gm parts division license plate frame nos
  220. NOS AC 45S Spark Plugs Oldsmobile Buick Pontiac Chevy
  221. NOS Olds Remote Control Mirror 1970 1971 1972 Cutlass 442 Vista-Cruiser
  222. olds meziere electric water pump
  223. SBO Holley street dominator intake manifold
  224. NOS 67-69 Cutlass 442 GM Fuel Pump
  225. 1966 Olds F-85 Post Coupe TRUNK SCRIPT 442 W-30
  226. NOS 90-92 Tornado Trofeo Wheel Well Moldings
  227. Top of a 1073 OLDS $455 J heads Rockers and All
  228. night watch complete
  229. Cruise control parts lot 1970's and 1980's stuff NOS NEW GM
  230. OEM J2 valve covers, never used
  231. 1968-1972 Glove Box Light
  232. NOS 68-72 Radiator Hose To Shroud Clamp
  233. 1960 Hood Ornament Emblem Part Nbr 579742
  234. Show Car Quality 1968 Woodgrain Steering Wheel Cutlass 442 Hurst Olds
  235. 1968 1969 Cutlass 442 Hardtop Black Sunvisor Set--Excellent Original GM
  236. 1968 Cutlass Glovebox Door
  237. Parking brake pedal assembly
  238. 66-69 non console shift boot and ring
  239. New Lakewood SFI Bellhousing Part 15100 for 64-77 Olds 330 to 455
  240. NOS 1966 1967 "Cutlass" trunk lid emblem Oldsmobile
  241. NOS C-S Roof Emblems 1970 1971 1972 Olds Cutlass Supreme
  242. Remote Control Mirror 1966 Olds Cutlass 442 Vista-Cruiser
  243. Sale-68-72- Smaller Parts
  244. NOS 1960 Parking Light Lenses LH/RH
  245. Turbo 400 Dip Stick and Tube
  246. 71/72 air cleaner
  247. Some 1972 Cutlass Supreme parts Mirror/lens/window cranks
  248. Miscellaneous Parts
  249. 1970 (71) flat ridge PS fender
  250. 1952 0lds instrument cluster.
