View Full Version : Parts For Sale
- Power Door Lock Solenoids, GM Olds circa 1970
- 1970 F-85 fender emblems
- Standard Hub Caps 1967-1969 Olds Cutlass W-31 442 W-30
- Oldsmobile Performance Chapter JACKET vintage O.C.A.
- SBO exhausts manifolds for FREE
- 69 442 air cleaner
- 68-72 A-Body Convertible Rear Seat—And More
- 68 442/cutlass F&R bumpers
- 65 F85 2 door post just got home
- 1967 Olds 442 aftermarket new parts barkes and P/S
- 73 olds 88 front upper header panel-CARLISLE
- 70-72 supreme parts
- 69-72 Cutlass/442 Ratty bucket seats
- 1970-1972 Deck filler panel for Cutlass Supreme
- Lightning Rods Top Plate
- Holley 600 for sale
- Kelsey Hayes power brake parts from 63 Cutlass
- 1970 Oldsmobile W-30 w30 455 F Heads
- 1969 1970 Oldsmobile Cutlass Hood w/ Trim
- 1966 Cutlass/4-4-2 Grille
- 1967 chassis service manual - free to good home
- 397363 big olds 455 crankshaft
- 72 Olds Cutlass Supreme parting out.
- 68 442 hdtp parting out
- OLDS SS1 14"x 8" Wheels for Sale- Set of 4
- GM Seat Spring by the foot & seat repair parts
- 1964-5 Wagon Jack storage decal
- 1971 nos tail light lenses
- Working 8 eight track player
- 70/71 Toronado 455 4brl intake
- 69 delta 88 nos parts and some used
- 1968 Delmont 88 Convertible, misc. parts
- Misc 63 Starfire Parts for sale
- 455 Engine blocks & parts
- Big Block heads B,C,G,K
- 455 /425/330crank shafts
- NOS delco shock absorbers (not spiral)
- Bumper cores 70-72
- 3.23 and 3.73 gm used gears 10 bolt 8.5
- 1969 Cutlass S windlace
- 3 DOG DISH hubcaps
- 1966 442 bumper parts and lights
- NOS Power Antenna Quad 442 Olds Cutlass Calais 1989-1991
- Non a/c alternator brackets.
- 68 Cutlass Floor Shift Tilt Column,Bucket Seats,More
- 70 Cutlass 2 door post parts car just in.
- Various 68-72 Door Pulls and Window Cranks
- Collection of Oldsmobile Car Brochures 40's t0 80's
- 68-72 White Window Cranks
- NOS door jamb switches
- 1969 442 aircleaner
- 1967 W30 air intakes
- 70-72 cutlass 442 headlight switch, bezel and knob
- Edelbrock intake 3711 $125 OBO
- 69 cutlass/442 conv deck lid
- 69 442/cutlass Hood,Doors and more
- NOS 68-72 bolt on center caps (4)
- 68-69 NOS 14x6 trim rings (2)
- 7040250 Quadrajet
- 1967 Parking Light Lenses Olds Cutlass 442 Vista-Cruiser
- 1967 Olds Cutlass 442 Tail Light Lenses
- 1970 455 W30 aluminum intake
- 70-72 cutlass/442 more stuff
- 81-88 G & B-body power antenna
- SsII bolt on centre caps
- type O rear end
- Bulldog heads
- 1962-1964 Oldsmobile parts collection for sale!
- 69 70 71 72 442 Fender Emblems—Real GM
- 1968 442 TH-400 Short Tail Automatic Transmission—Code OG
- 1968 Cutlass and Fenders 442 Doors In CT
- 68-69 Cutlass 442 Convertible Top Switch and more Convertible parts
- Non a/c alternator bracket set
- 68 Cutlass 442 Front Bumper Bracket Setup
- 68 69 70 71 72 Cutlass 442 H/T transmission Cross Member
- 70-72 vacuum switch
- Set of 4 1972 real GM Inner Taillight Lenses/Reflectors
- 68 69 70 71 72 Real GM Black Interior Headliner Windlace Set
- 68 69 442 Code "J” Big-block Intake Manifold
- 69 Cutlass Grilles Nice GM
- 67 cutlass/442 radiator support
- 68 cutlass/442 a/c compressor switch
- Ready to run 403
- 70-72 442/cutlass and yet another batch
- Set of 4 Bolt-on Center Caps
- Supercharger manifold for small block
- 413307 water pump
- 69 442/cutlass parts another batch
- 68-72 Convertible top frame & parts
- 1966 cutlass bench seat
- 69-70 4 core radiator top plate.
- 66-72 cutlass bucket power seat track
- 4 crank pulleys and 2 water pump pulleys.
- 1971 cutlass supreme halo vinyl top trim for sale.
- 1972 cutlass supreme body side trim for sale
- 14x7 steel wheels for poverty cap or hub caps
- For Sale 1966 67 Toronado Quarter Panels $175 Pass side, $125 Drivers side
- car frames and portions
- 1973 Omega Sport Mirrors
- Rear Disc Conversion Backing Plates
- 68 OAI ducts
- NOS 63 Jetfire gas cap. Premium fuel
- New member Hurst Hatch
- 1968 455 "C" heads with 400943 crank
- 1972 455 shortblock rotating assembly N crankshaft AT not 4 speed
- Delta 88 wheels (Los Angeles)
- 1970 1971 1972 Cutlass Automatic Console & Shifter Assembly
- G-body Stuff
- NOS rear bumpers 50-51 98
- NOS front bumper 53
- 1972 Ga heads W30, manual 442
- 1960- something Shifter and Console
- 455 Venolia Pistons, 850 Demon Carb, Edelbrock 04B
- 1968 floor shift columns
- 1976 4 bbl carb,
- 1970 4bbl carb, 350
- 72 4bbl carb, 455
- 72 4bbl carb, 455
- 73 4bb carb.
- Early C heads with small heat crossover port
- olds 350 parts for sale - pistons, cam, and headers
- 1974 headlight bezels
- Olds v8 accel distributor with tach drive
- 68-72 A-Body Convertible Rear Seat—Nice
- 68-69 Cutlass Emblems
- 68 Passenger Fender Peak Stainless
- 1973-76 Oldsmobile 350
- Harland Sharp Polylocks
- 1966-67 Toro dash/cowl for parts. Nice windshield channel
- NOS GM 1972 DELTA 88 98 front filler
- Nos gm 1973 vista cruiser cutlass? Tail lens
- 68 olds cutlass type O axle light duty in CT
- 70 Cutlass hood tooth and hockey sticks
- correct control arm bolts and nuts
- SS1 wheels to a good home
- Crane hyd roller
- VINTAGE FINNED Olds M/T VALVE COVERS
- 1968-69 cutlass 442 washer jar new
- BBB BBO BBC Big Block steering shaft
- 63 and 65 Cutlass F85 wheels
- 100 amp Polished aluminum 1 wire alternator
- '68 - '72 Olds A/C brackets Cast Iron
- 1968 w-30 engine with D heads
- OEM Hood hinges with springs
- 1968 442 / Cutlass parts
- 68 cutlass/442 4core rad. Suppt
- 69 open face Alt.
- '65 grill
- 70-72 cutlass auto console...very nice
- 1970-71 Pwer trunk release #2
- 1965 Olds 330 intake etc.. for sale
- 1967 98 trunk molding
- MSD ignition system ready to rock.
- NOS B&M shifter handle.
- Jetfire K&N air filters
- 1967 W30 OAI air cleaner housing
- 1967 disc brake steel wheels
- 1971 small valve G heads
- 1971 350 sbo
- 1970 cutlass supreme body and frame $250 OBO
- 1975 cutlass tail lights
- 1975 cutlass header panel
- 63 starfire stainless side trim
- Original rocker arm bridge pivots, pushrods (8.235"), with like-new rocker arms
- 69 70 71 GM Guide 12” Day/Nite Maplight Rearview Mirror –Excellent
- NOS GM 1968 Olds Cutlass 442 H/O Fader
- NOS GM 1974-75 OMEGA Battery clamp
- 1970 Olds 350 CI Engine and TH350 Trans--Available
- 7042250 carb core.
- 7029251 carb core.
- 455 engine parts New
- Pair of 72 grills.
- jetfire parts
- F/S Muncie yoke
- F/S Lakewood scatter shield
- 74 chassis service manual.
- 67 chassis service manual.
- 455 4 Speed Forged Steel Crank Cast #400943
- Machined DX Block/Rods/Crank
- 1969 A-body original two piece rotors
- 63 Jetfire emblems
- 68-72 A Body Covert. Top Frame
- 67 Cutlass tail light lenses.
- 66 Cutlass tail light assemblies.
- 66 Cutlass & 72 lower? (lenses)
- Selling Loads of Parts 2016 OCA Nats-Kingsport Tenn.
- Big block swap kit (455, T350, exhaust)
- 73-75 headlight bezels.
- Hood Hinges & springs 64-67
- Hood Hinges & springs 69-72
- 69 Hurst Olds Ram Air, Air Cleaner "Top Can"
- Parting 68 Ramrod and Cutlass S Barn find
- '69-'72 RH Cutlass hood hinge (Fusick)
- Repop W-30 Intake
- NOS 1969 only 442 H/0 Special Ignition Cylinder
- NOS R-69 battery
- NS 1967 442 Air Cleaner Pie Plate
- NOS 67 442 Valve Cover Decal
- "E" Heads & Ported SBO Edelbrock RPM Intake for BBO Heads
- NOS 70-71 Supreme LH FRT wheel well trim
- NOS sill plates new gm
- W27 Differential cover for type "O" rear end
- OEM Sunvisors for Cutlass convertible. Excellent condition.
- '55 with Factory Air
- 1969 Hurst Distributor
- L69 intake manifold 66 442
- Shoulder belt storage card & quick facts about your new Oldsmobile, info cards
- 1968 400 V-8 Motor (68 442) for Parts or Rebuild in CT
- Small lot of NOS parts
- 455 short blocks and heads
- Nos/nors dole ported vacuum switch 1968-70
- 404847 core water pump
- SS I New center caps and retainers
- 1957 371 J2 tri-power
- 1967 cutlass dash insert and pad
- Rallye 350 quarter decals
- Water Pump 407586 71 or 72 442 w/AC
- NOS in BOX SSII Bolt on center cap
- Sport Mirrors
- 1972 tail light lenses
- 7043250 carb.
- 70 71 72 trunk lid
- 64-66 console top plate with door.
- 404847 X water pump.
- 72 Cutlass 442 Sheetmetal
- Another 1971 Vista Cruiser Parting Out
- 1968 cutlass parts
- 71/72 Bumper Guard And Impact Strip
- 1967cutlass bucket seat backs and skirts
- 1967 cutlass/442 driver fender
- 1966-67 cutlass convertable top frame
- 1964-68 Cutlass 442 H/O OEM jack clamp
- 7028251 68 442 carb auto or manual
- NOS Oldsmobile decals
- NOS trim 40s-70s
- NOS hubcaps
- 1968-72 One-piece Power Trunk release complete
- 1971 Metal Grilles for the Cutlass Supreme
- 1972 dash wood grain for cutlass convertible
- 1971 dash wood grain for cutlass convertible
- '71 cutlass dash bezel w/ woodgrain **BRAND NEW**
- NOS Cruise Control Lever 1971-1974 Cutlass 442 Hurst Olds
- 64 Cutlass Front Bumper
- BUMPER JACK for notched bumper
- 72 delta 88 script
- 1970-1972 Sport Steering Wheel Show Car 442 W-30 Cutlass W-31
- NOS R.H. MIRROR 1967 Olds Cutlass 442
