View Full Version : Parts For Sale
- 1970-72 4 barrel air cleaner base
- Rockers and Pushrods
- 1970-'72 Nice power trunk assembly, '70 button.
- 1970 442 Super Stock II (SSII) Wheels + Tires for sale
- 1970 442 Front Bucket Seats for sale
- 12bolt rearend
- 1970 442 Convertible Suspension Parts for sale
- Edelbrock 1413 Performer Series Carb
- tons of parts cutlass 88 98 Toro
- 68/69 small block heat shroud
- 69 reverse lights
- 69 tail light housings
- clutch and brake pedals
- Thornton reproduction 350 exhaust manifolds
- 1970 442 automatic backdrive linkage
- WTS: NOS 1959-60 Steering Column Bearing (pic) (pics)
- 1970 442 Convertible Trunk Lid for sale
- 1968 Cutlass 442 NOS under dash lamp
- 1970-72 Cutlass 442 automatic backdrive linkage
- Olds parts can deliver between OKC and atlanta
- 1970 Parts
- Rocket Emblem Tissue Dispenser
- Need parts 64 Jetstar 88
- Black 70-72 Console Restored
- NOS GM 71-72 Cutlass Headlight Surrounds
- 1975 delta 88 quarter extensions
- 1968 1972 8 track tape player pad Cutlass 442 Hurst Olds
- 1968-1972 8 track tape player case Cutlass 442 Hurst Olds
- Steering wheel center
- Horne button
- 7 blade & 6 blade fan
- 1968 Woodgrain steering wheel Cutlass 442 Hurst Olds Show Car Quality
- 8 track faceplate 1968 Cutlass 442 Hurst Olds
- NOS RED Distributor Cap 1967 1968 1969 442 W-30 Hurst Olds
- 1969 Olds Cutlass 442 TRIM RINGS SS II wheels
- Toronado Oil Pan
- 1968-1972 8 track tape player Cutlass 442 Hurst Olds
- NOS 1964 V8 emblems Olds Cutlass 442
- NOS GM Driver and Passenger Sides '70-'72 Hardtop "S" Partial Quarter Panels
- NOS GM Drivers Side '70-'72 Hardtop "S" Full Quarter Panel
- 1970 Indy Pace Car Goodyear Speedway Tires - Set of 5
- 1963 and 1964 Starfire, and 88 parts
- Rolling and bare frames for sale
- F/S OEM Hurst shifter and back-drive linkage
- Steel Rally Wheels
- Quadrajet Four barrel
- ignition switch bezel
- power tail gate window.
- Interior door and 1/4 trim 69 Cutlass/442 hdtp
- Rear Axle Bearing 1967-1969 Delta/Delmont
- 1971-76 fullsize white arm rest, and head rests (pair)
- n.o.s. 1985 olds delta 88 front bumper shock
- 1973 oldsmobile delta 88 taillights
- 1975 oldsmobile delta 88 l/s taillight assembly
- 1974 oldsmobile delta 88 conv., parting out
- 68-72 Olds A body part for sale
- AC Performance Spark Plugs lighted sign
- 7042251 RE 2461 Carb for sale
- 72 Cutlass AM/FM stereo
- 7029253 0444 Carb
- NOS Lightning Rods
- A-body bucket lower seat frame and track
- 442 Manual Shifters
- 69 251 carb
- 68/69 j code intake
- Rebuilt Olds 350 Heads
- SSIII Rally Wheels & Tires (set of four)
- New Modine 2057 Radiator $65 obo
- Used Cyclone headers 1965 A body big block $60 obo
- 15" x 7" SSII JJ Wheels Bolt on Center Caps
- 73-77 Cutlass dash inserts
- 1966 olds toronado parts
- 56 Olds
- All $10 1972 Cutlass Parts!!!!
- '83 Hurst Olds Cassette Tape
- NOS 81-88 Cutlass Power Antenna
- 400ci G Block
- 1968-70 SBO 350 2bbl intake
- R12 freon 3 14oz cans $105 shipped
- 455 engine blocks to the nationals $130 ea
- 68 Cutlass (442) Front Fenders--Real GM
- 68 Cutlass 442 Air Conditioning Vents—Nice Chrome
- 1968 Cutlass 442 Optional N-95 14” Wire Wheel Hubcaps
- 68-72 Cutlass Transmission Cross-members --Hardtop and Convertible --GM Parts
- 68-69 Cutlass 442 Convertible Top Switch and more Convertible Parts
- 68 69 Cutlass S (Model 87) or 442 2-door Hardtop Rear 1/ 4 Windows –
- Running 1966 425 Oldsmobile Big Block & TH400 Transmission
- 1968 Oldsmobile 3:42 12 bolt
- Parting out a V6 65 F85
- '75 Delta 88 Nose
- 1970 442 W30 Aluminum intake manifold
- olds 461
- Olds O-type 2.78 posi set
- Cutlass parts
- 1970-1972 Sport Steering Wheel W-31 442 W-30 NOS or very close
- rubber floor mat/floor liner from 66 f85
- Cutlass 442 455 Engine frame mounts and rubber mounts
- NOS oil pressure sender 1969-1974 Cutlass 442 Hurst Olds
- Extremely nice blue 1972 dash plastic parts
- factory Bumper Guards 1971 1972 Cutlass 442 Hurst Olds
- 1966 Starfire Trim
- AIR CLEANER HOUSING 65 Cutlass
- Mounting Hub, Sport Steering Wheel 1970-77 Olds Cutlass 442
- 1963 Cutlass/Jetfire/F85 Head Light Doors
- 70 72 72 Cutlass 442 Amber Front RH Marker Light—Real GM
- 1967 442/Cutlass/F85 Bumper Filler
- 69 Cutlass 442 LH Driver’s Side Front Parking Light Assembly—
- 1967 442/Cutlass NOS Fender Extensions
- 69 70 71 72 442 Fender Emblems—Real GM
- 73 & 74 delta 88 tailights
- 1975 delta 88 taillight
- armrest, headrests, white, 71-6 fullsize
- nos front bumpershock, fullsize 80-85
- 1970-1977 Olds Cutlass 442 sport steering wheel
- Glass for sale - Cutlass Supreme
- Free 1966 1967 6cyl exhaust system.
- 1972 Cutlass 350 engine and trans.
- 1972 Cutlass core support
- Mint used 70 Cutlass S grilles
- Door peak trim
- 1968 and 1972 Cutlass Wiring Harnesses—Good Used GM --
- 1970 Cutlass Supreme Hardtop Interior—GM Door Panels-Armrests
- 1973 Delta 88 un cut radio bezel
- rear chrome bumper shell
- RAREST ever 1968 442 option on epay
- More used parts
- '69 Cutlass A/C Dash Pad
- Additional parts
- 1970 oem ram air hood,OAI,w30 hood,$2000obo
- Parts for sale
- '66 Cutlass Tailight '66
- Olds 455 Engine for sale - $550
- 1966-67 Olds Toronado Sheet Metal & more
- 1950s - early 1960s (?) Olds Vanity Mirror
- 69 OLDS 98 parting out
- 78-87 Cutlass aluminum hood 250
- 15" wheel covers
- Holley intake manifold
- Type "o" differential assembly
- Really nice 72 Cutlass hub caps
- Blowing out my last few 442 custom shirts
- Various parts for sale
- 64 thru 67 Cutlass/442 NOS GM body mounts
- NOS tire, possibly correct for the 1973 Hurst Olds
- Real nice "Z" manifold 1969-1972 442 Hurst Olds
- For Sale: 64'-66' Spoke Hubcaps Spinner Two Prong Knockoffs
- Top Cylinder and Hose Kit-71 Olds
- OLDS 12 Bolt 3.91 Ring and Pinion "O" Type
- NOS GM parts
- 70-72 Cutlass Core Support
- FS: Parting out 1980-1985 Oldsmobile Delta 88 Royale Brougham Coupe
- Early Olds Flywheel
- 1966 425 engine parts
- 67 parts car
- 66 Starfire moldings.
- Selling Olds parts ,Edelbrock heads intake and more.., going a different direction..
- 1974 delta 88 conv. parting out
- 70 fender trim
- 72 Cutlass Carpet
- 64-66 Console Vacuum Gauge
- Strato buckets 1970
- 68-69 442 398662 D-1 S intake: Bolt-n-go.
- Parting '82 Cutlass w/ 46k miles
- Lots of parts
- 68-69 Cutlass 442 AC under dash duct work
- 7041251 q jet nice original
- parting '68 Vista
- Olds th350 ready to go
- Mostly 68-72 Cutlass items ...
- Found in my garage.
- Free parts - clearing out space
- 1940 olds 90 horn button needed
- 65-67 BB AC Brackets
- 5.00 rear gears
- 71 OW Transmission
- 1970 to 1972 Cutlass 442 dash Fuel gauge
- 1970 to 72 Cutlass 442 Clock
- 1970 Hood Lock T-44 Option
- NOS "OS" Fan Clutch
- F-heads
- 72 toronado tilt column
- NOS Power Trunk Switch 1971-1974 Cutlass 442 Hurst Olds
- NOS Horn Button 1969 1970 Olds F-85 W-31
- Hess Brothers Auto Wrecking in Northern California
- New SBO G-body Hooker Super Comp Headers
- Olds Parts for sale
- 69 442 Shell only
- 68 Cutlass S some parts for sale
- 68 442 for parts
- 69 442 mostly complete for parts
- 1966 reclining passenger bucket seat
- Ebay listing few misc parts from my 1970 442
- 68/69 parts to Carlisle
- 350 Olds short block
- 1967 olds parts for sale
- 66 cutlass parts
- 1967 Cutlass kick panels
- Mirror (1967 F-85 / Cutlass)
- 1967 Cutlass Bumper Brackets
- 1967 Cutlass Air Breather
- 1970-72 Cutlass Dash Pad
- 1967 Cutlass Trunk Wiring Harness
- 1967 Cutlass Seat Belts
- 1970 Cutlass Grille (Pair
- 1967 Emergency Brake pedal and cable
- 1967 Cutlass Head Light Assembly
- Center "Boxed" convertible frame sections
- 68-72 Cutlass convertible transmission cross member
- Vista Cruiser Bumper Jack
- 468 Engine
- 68-69 Cutlass 442 Convertible Top Switch and more Convertible parts
- 70-72 A/C under dash defroster/ heater duct parts
- 70-72 marker light housings front / rear
- TCI Turbo 350 alum deep trans pan
- Restored '68, '69, '70-'72, & mid '70s speedos & fuel gauges.
- 70-72 cutlass parts
- 78-88 Gray Console
- 1971-1978 toronado fwd 15" rims - two
- Original Oldsmobile Rocket dealership lighted double sided sign!
- NOS Choke Stove Tube
- New Hurst 3 Speed Shifter
- 1970-72 Cutlass AM Radio
- NOS '83 H/O Cassette Tape
- 1968 442 W-30 Hurst Olds Carb Choke Coil Housing 7028093
- bumper shock n.o.s. 85' 88
- 1967 Olds 442 W-30 carb Choke Coil Housing 7027094
- 75' 88 driver side taillight assembleis
- Oldsmobile f-heads
- 71 442 4 speed intake R 407567
- 71 442 G heads for sale
- Vintage Hurst Dual Gate Shifter Assembly
- 80's Hurst Olds Car for parts
- 68-72 Original Floors,Top Cowl and Firewalls
- 1967 Olds Cutlass 442 AM-FM radio
- 1969 AM-FM Stereo Radio Cutlass 442 Hurst Olds
- 1969 Cutlass 442 courtesy lamp
- 68-69 non ac heater unit - restored
- NOS 1974-1975 Cutlass 442 Hurst Olds license plate bracket
- 1965 Olds 442 Carbs and more
- 76/77 Supreme interior parts for sale BLACK
- 69 3.42 posi O-Axle for sale
- 1959 88 2door hardtop
- 70 dual gate console and shifter
- 68-70 "bell" style brake drums
