View Full Version : Parts For Sale
- 1964 Dog Dish Hubcaps
- 1955 to 1957 HURST Four Speed Shifter NOS TRI5 OLDS
- 65 442 Cutlass Homecoming
- NOS Gas Cap 1971 1972 Oldsmobile Cutlass 442 Hurst Olds
- 1965-1966 F85 standard steering wheel
- 1966 F85 bench seat side trim
- 1956 Fender skirts
- 1966 Cutlass bumper cores
- 1970 am/fm stereo radio repaired
- 1970 #5 Thermostat Housing Olds Cutlass 442
- 403 Pull Out Engine Assembly
- 1977 Cutlass Sport Steering Wheel
- NOS 1985-1988 Grey Sport Steering Wheel For Cutlass and 442
- W and Z Exhaust Manifolds
- Walker Tailpipes
- Used Headlight Housings
- 1970’s Red Starfire Sport Steering Wheel
- 1970-1971 Green Deluxe Steering Wheel
- NOS Speed Alert Speedometer BUZZER 1959-1970 Oldsmobile
- 1958 Oldsmobile Master Power Window Switch
- 1969 speedminder/speed sentinel
- Pair (2) NOS 70-75 poverty caps
- 1965 Starfire convertible one of 12 4 speed car
- SSI Wheel Vintiques Center Caps (5 total)
- 1954 1955 Oldsmobile 4 Way Power Seat Switch
- 68 Cutlass S Hood / front bench seat
- 1969 cutlass 442 calif rust free hardtop trunk lid
- 67-70 nos automatic wooden shifter ball
- NOS chrome oil filler cap 3851735
- Ported vacuum switch
- 1970-72 hood latch
- 1968 nos cigarette lighter
- NOS Engine Temp Sender 1968-1972 Cutlass 442 Hurst Olds
- NOS 1970-72 442 Sheetmetal Package Deal
- For Sale: NOS Front Shock Absorber J-Nuts
- Gm front floor mats black
- Edelbrock 1411 Carburetor (750 CFM Electric Choke)
- 1968 Rear Side Marker Lights 68 Side Marker Light Pair with Bezels and Gaskets
- Pair of 1969 Cutlass 442 Cutlass Taillights 69 Tail Lights
- NOS Horn Button 1968 Wood Grain Steering Wheel Cutlass 442
- 4 core radiator 69 - 72
- 70 to 72 cutlass doors
- 1964-65 4 speed shifter
- GM oil pressure sender sending unit for gauge USED Condition
- Charcoal canister and mounting bracket
- 1968 400
- 68 & 69 442 Air Cleaner Housings in CT
- 1970 OG Turbo 400
- For Sale: NOS 68 - 72 Gauge Lens and Retainer
- 1965 Starfire bumpers
- 1971 OLDS 455 Cutlass 442 Engine for Restore 71 w30 OLDSMOBILE - $800 (Maplegrove)
- Gm jack dec 1973
- 1970 442 carb - 7040257
- More Transmissions For Sale
- 1971 1972 TVS Switch Cutlass 442 Hurst Olds
- 64 cutlass parts. Throwing out Monday
- 71 Cutlass Tail Lights
- Dx block + 424” rotating assembly
- Pair of 15x7 ssIII rally whells with center caps , bezels and beauty trim rings
- Hurst Dual Gate Shifter 1968 1969 H/O type.
- DSS Forged Pistons K2 .030
- Transmissions
- NOS UHV Ignition Coil 1115248 1967 1968 442 W-30 Hurst Olds
- 2 new American Racing VN515 Torq Thrust rims 17x8
- (SOLD) 1958-60 Fuel Pump 4727AX NOS? $20 plus shipping (SOLD)
- 70 Cutlass 442 Headlight Housing Used OEM LH
- NOS Headlight Switch 1964 1965 1966 1967 Olds Cutlass 442 V-C
- NOS Tilt-Tele Turn Signal Switch 1969-1974 Oldsmobile
- 1970 OEM Cutlass 442 Taillight lenses, 6 total
- Nos 1970 Oldsmobile hood script 399094
- 1966 1967 DASH BEZEL Cutlass 442 Power Antenna
- 1966 1967 Rear Defogger Switch Olds Cutlass 442
- 1966 1967 Convertible Top Switch & Bezel Olds Cutlass 442
- Various Parts for Sale at Homecoming
- 1969 under bumper ram air scoop NOS W30 & W31
- Harland Sharp Olds Rockers for Sale in Florida
- 1970-1977 cutlass 442 vista rally 4 spoke sport steering wheel bare
- 455 engine out of a 98 $500
- OEM 1972 Hurst/Olds tail light lenses
- 1969 W-Z manifolds
- 4 speed 90 degree speedo adapters
- NOS RH 68-72 convertible pinchweld molding
- 1966 Olds 442 LOUVERED Valve Cover Breather
- NOS Oldsmobile Front Floor Mats 88 98 Starfire 1958 1959 1960 1961 1962 1963
- MOROSO 4108 NOS Trans. Tailshaft Plug 1 7/8" O.D. Vintage Wood and Steel Construction
- NOS Ignition Coil 1964-1974 Olds Cutlass 442 88 98 Toronado
- NOS 1970 Oldsmobile Cutlass "S" front fender emblems
- Take out 330
- Hurst Dual Gate Shifter 1978-1987 Olds Cutlass 442
- 1969 cutlass double hump hood
- FS 1977-1990 RWD Oldsmobile Cornering Lamp Assemblies and harness
- FS Olds Delta 88 98 RWD Gauges
- FS GM '69 -'72 AQ2 Electric Seat Back Release, Strato Bucket Seat, Strato Bench Seat
- 403 Motor in Ohio 44131 zipcode
- Working Dash Clock 1970-1972 Cutlass 442 Vista-Cruiser Hurst Olds
- NOS 1963 Remote Control Mirror Olds 88, 98, Starfire
- FS Olds grille 22528769
- FS 1978 Olds 88 98 Twilight Sentinel package
- FS Olds Sport Wheel - Blue
- FS Olds Sport Wheel - Camel
- NOS 1964 Windshield Washer Pkg. Olds Jetstar 88 98 Starfire
- Left Side Rally Pac Guage from a 1970 cutlass 442 with plug harness pig tail
- 1968/1969 post car non AC dash pad
- 1969 & 1970 8 Track Face Plates Cutlass 442 Hurst Olds
- 412287 X dual exhaust manifold and heat shield
- 1966/67 8 track player
- NOS Tachometer Drive Cable MOROSO part number 5536
- 68 69 70 71 72 Cutlass 442 Convertible Rear Access Covers--
- 215 parts
- 1963 Jetfire sway bar and steering box
- NOS Distributor Vacuum Advance 1970 Olds 442 W-30
- 1970-72 cutlass/442 original jack assembly
- 1971 OLDS 442 Valve Covers Rocker Arm Cover Pair Notched corners for 455 in A-Body
- NOS 1964 Olds Vista-Cruiser Tail Light Lens RH
- 1969 Oldsmobile 88 AM/FM Delco Wonder Bar Radio
- 1969 Hurst/Olds 442 HO 1111989 Factory Distributor
- NOS Fuel Filler Door 1974 1975 Cutlass 442 Hurst Olds
- 1968 1969 NOS GM Oldsmobile Tornado Front Fender Manual Antenna
- VINTAGE 50's SUN Distributor Test Machine 60's POINTS Dwell Re-Curve D - $1,000
- 1966 1967 Speed Alert Speedometer Olds Cutlass 442 Vista-Cruiser
- 75 Hurst Olds Sail Panels for sale
- 1970-72 Cutlass/442 Side Marker Lights
- NOS Delta 88 "Royale" Ornament 1986 1987 1988 1989 1990 1991
- 1970 455 notched original valve covers
- NOS??? 1968 1969 Rally-Pac Gauge F-85 Cutlass W-31 442 W-30 Hurst Olds
- 1968 A Body Black 8 track player...complete
- 1968-69 Cutlass/442 Automatic Center Console & Shifter
- 1969 Trunk Lid Chrome Molding for Cutlass and W Cars
- BBO and SBO intake manifolds and carb sale
- 71 Cutlass tail lights
- 68 cutlass/442 Air Cleaner (breather)
- Delco AM-FM Stereo Radio 1970 1971 1972 Cutlass 442 Hurst Olds
- 70 71 72 OLds Cutlass 442 Rear Bumper Backup Light Set-- Restored GM
- 70 71 72 Olds Cutlass 442 Rear Side Marker Light Set-- Restored GM
- 1970 71 72 Cutlass 442 Dash Controls, Switches-- etc.
- 1969 N34 3 spoke sport wheel horn contact NOS
- 1968 AC curved oil fill tube
- 68-72 rear end reinforcement bars
- NOS 70-72 Cutlass. Fender pair
- 70 442 steel hood
- 68-72 ABody Convert Top Windshield Stainless - Original GM/Very nice
- 68-72 convert top boot slide rail - original GM
- NOS 400377 68 map light
- Original Package Tray 1970 w30 Holiday Coupe "MESH" with 1, a Single Rear Speaker
- Pushbutton Power Trunk Switch 1971 1972 Cutlass 442 Hurst Olds
- Power Trunk Solenoid 1970 1971 1972 Cutlass 442 Hurst Olds
- BE master cylinder core
- 1970 8 track face plate Olds Cutlass 442
- Column lgnition Cylinder With Key
- 69-70 big car am-fm
- 1950's Olds Power Steering ON-OFF SWITCH
- NOS Oldsmobile vacuum trunk opener parts 1960's
- NOS 1969 1970 Bi-Phonic Radio Rear Speaker Parts
- Buick Allloy Turbine Wheels 15x7 5x5
- NOS 69 dash maplight
- NOS 70-72 7312963 fader
- 1969 3 and 4 speed console shift patterns with LOCK
- NOS Power Trunk Solenoid 1970 1971 1972 Cutlass 442 Hurst Olds
- 4 speed neutral safety switch #1983493
- 1970 Power Trunk Switch Olds Cutlass 442
- GOLD 8 track tape player front pad 1969 1970 Olds Cutlass 442
- 1970 Delta 88 disc brake backing plate / dust shield
- 1971 1972 8 track tape player case Cutlass 442 Hurst Olds
- NOS 1976 Oldsmobile Cutlass Supreme GRILLS
- 4speed shifter tabs 66, 67, 68???
- NOS 406653 dual gate knob
- NOS Rear Finish Panel 1974 1975 Cutlass S 442 Hurst Olds
- Olds Parts
- Lower A/C vents with 8-track 1970 1971 1972 Cutlass 442 Hurst Olds
- Louvered valve cover BREATHER 1966 Olds 442
- Valve Cover BREATHER 1967 Olds 442 with 4 speed
- NOS Mirror LH or RH 1966 Olds 88 98 Toronado
- 68-72 package tray plastic corners
- NOS R.H. Headlight Bezel 1973-1974 Cutlass S 442 Hurst Olds
- NOS Thermometer 1972 1973 1974 1975 Cutlass 442 Hurst Olds
- 8 Track Tape Player Faceplate 1969 1970 Cutlass 442 Hurst Olds
- NOS Antenna Mast 1964 1965 1966 Cutlass 442 Vista-Cruiser
- NOS Antenna Mast 1967 1968 1969 Cutlass 442 Hurst Olds
- 1970 TM code 3:42 posi rearend
- Nos 14 inch Beautie Trim Rings set of 4 #9796919
- 1965 Starfire Convertible 1 of 12 Four Speed Manual
- NOS Courtesy Light Switch MB 1970 Olds Cutlass 442
- NOS Brake Booster Check Valve 1966 1967 Olds Cutlass 442 Vista-Cruiser
- Parts at Carlisle this week
- Ultra bell
- 90 degree stewart Warner Speedometer Reducer #778 Ratio .6667
- Speedometer Reducer .82410 #666 stewart Warner Reducer
- 1967 Oldsmobile 442 Hood and Deck Lid
- Bucket Seat Pair - 69-72 Abody GM
- Details Condition New These came from PARTS PALACE repro to install 4 speed or Manual
- Parting out 1967 Delta 88 town sedan in south texas
- 68-72 Cutlass 442 Heater Box with Blower Motor-- Ready to install
- 70 71 72 Cutlass 442 Sunvisors-- Nice GM
- 1970 Oldsmobile Cutlass 442 Center Grill Support-- Nice GM
- 1971-1978 Toronado wheels
- CHAMPION NOS Spark Plugs 7 SEVEN in Factory Pack
- 1973 - 1975 Oldsmobile Omega Rear Quarter Panel Graphics Decals
- Various hubcaps and 2bl intake/carb
- 1966-72 Oldsmobile cutlass 442 parts, Grab bag...
- Olds cutlass 442 parts Turbo 400 yolk !! ( NEW )
- 1968-77 oldsmobile 442/88/98 pulleys, 350 - 455 2 Groove. ( NEW )
- NOS RH and LH sport mirror glass
- 64-69 4speed console light housing
- 64-69 4speed console glovebox reinforcement NOS?
- 1968 to 1970 with air conditioning A/C 3 v belt groove pulley pair KFKC KF and KC
- 68 cutlass S, 442 hood
- KH Two V Belt Groove Power Steering Pulley
- 1970-74 Muncie side cover 3952648
- NOS 67-69 auto shifter cable #407409
- Nos 67-69 automatic floor shift wooden ball
- 68/69 nos in box tissue dispenser
- 68/69 Muncie M20
- 1968 Rebuilt Muncie M20 and 4 speed parts
- 66?-69 non console 4 speed boot and retainer
- 69 4 Speed reverse/lockout lever and tab
- 69 442 3 speed shifter and rods & emblem
- Power seat belt cover
- Sport Wheel Horn Button and Contact OEM Original
- 1975-later Oldsmobile V8 valve covers
- 1964-1972 Olds V8 rocker covers
- NOS? 5679142 Saginaw Manual Steering gear box
- 1983 98 aluminum hood and hinges
- Manual Steering Only LOW Driver Side Alternator Mount KIT for Delco Alternator Circa
- NOS 4916258 wiper motor case 68-72
- 1970 1971 1972 Power Trunk Solenoid Cutlass 442 Hurst Olds
- 1937 F37 2 door coupe
- NOS 1970 442 Oldsmobile hood script
- Pair of engine compartment cross rods
- NOS cutlass door edge guards.
- 70/72 NOS Curlass/442 outside chrome mirrors
- NOS 70-72 Cutlass Fenders
- For Sale: NOS 70 - 72 RH Quarter Panel Extension Molding
- New pair Gen 3 Edelbrock RPM Heads 61029
- 1969 Dash Map Light Cutlass 442 Vista Hurst Olds
- NOS 5910593 AC POA valve
- 9748669 NOS set of 6 70-77 sport wheel screws
- 9751046 NOS 68, 70-77 horn contact
- LH 68-72 vista cruiser C pillar cover
- NOS 383152 S Rivet Premium gas cap
- For Sale: NOS 70 - 72 Deck Lid Emblem - "4"
- Olds 442 Chrome Dome Air Cleaner with Base
- 70-72 Cutlass S 442 Left Quarter Repro
- 1968 speedminder speed sentinel floorshift speedo
- 73/74 Cutlass Rally Pac
- Oldsmobile OEM Stamped Valve Cover
- Power seat A-body 4 way
- 1968 Chevelle 12 BOLT POSI Axle 3.42 Ratio EATON Carrier Fresh Rebuild with Drums
- 1970 Cutlass S 310 Horse Power DASHPOT and Bracket
- Olds v8 Engine Oil Fill Cap Oldsmobile 350 and 455
