View Full Version : Parts For Sale
- NOS 1970 Cutlass Fender Emblem
- 62 Starfire working clock
- 65 Cutlass misc items
- delco alternators 67 442, 70 delta and 65 442
- 14 X 7 Trim Rings
- set of 30 over 350 old pistons on rod balanced
- Oai 1970 1971 1972
- 1969 Cutlass/4-4-2 Front Bumper Bracket Set
- '66 Toro stuf
- 1968 442/Cutlass S RH Tail Light
- NOS 1965 Olds Cutlass 442 Tail Light Assembly
- 1962 Oldsmobile Starfire Wheel Cover Disk paint template
- NOS GM Delco Remy Alternator Pulley
- 1968 nos oldsmobile courtesy lamp
- 1982-89 Cutlass front dr outer seal strip NOS
- 1964 330 exhaust valves NOS
- 1987 Cutlass/Custom CruiserGM chassis service manual
- 1970 to 1972 Cutlass 442 Dual Gate Part
- NOS Cutlass 442 Distributor
- NOS Rochester parts
- NOS UHV Cap & Coil 1967-1968-1969 442 W-30 Hurst Olds
- NOS GM 350 Connecting Rod Bearings
- 70-72 442 OEM 455 4-Speed Intake Manifold #407567
- 425 Steel Crankshaft
- Oldsmobile 350 Forged Pistons Speed Pro L2320F +30 Flat Top
- 1963 F85 NOS front gravel shield
- 1969-72 NOS Cutlass RH 1/4 windowstrip
- NOS GM AC FC-60 Oil Cap
- C heads. Machined
- NOS GM DELCO Transmission Modulator
- Alternator fan #3 replated 1967-72
- NOS Complete Points Distributor Cutlass 442
- 68 69 442 Code "J” Intake Manifold-GM
- what should i sell now
- 1972 INTAKE 350-4bbl #14 casting
- NOS GM Alternator Fan U-1915 1967-80 BPOC
- 15x7 bolt on SSII olds rallye rims pair
- 85-88 4-speed console, shifter handle and armrest
- T-44 Hood Lock set
- 70 Turn Signal Cruise Handle
- NOS GM 1960's Alternator fan U-1912
- NOS GM Non cogged AC belt 1971 Olds + ???
- NOS GM 1953-56 Oldsmobile trunk light
- '58 Olds convert stuff
- For sale 1970 taillight assembly side markers.
- 70 Sport Mirrors
- Need Rear Window Trim Moldings for 72 Cutlass S (not a Supreme)
- "OLDSMOBILE" License plate Early 1970's
- 1964-67 A body NOS wiper reservoir & bracket
- 68 69 70 71 72 Real GM Black Interior Headliner Windlace Set
- 69 70 71 72 Real GM Convertible Interior Windlace Strips
- Set of 4 1972 real GM Inner taillight Lenses/Reflectors
- 68 69 70 71 72 Cutlass 442 H/T transmission Cross Member
- 67 68 69 Code "J" intake for 400 V-8 motors.
- NOS R.H. Mirror 1978-1990 Olds Custom Cruiser 88 98 cars
- rocket 350, trans, and extras 600$
- 1969 NOS Lighter
- 68 cutlass supreme radiator
- 69 hood. 68 doors
- 68-72 NEW sun visor brackets hardtop
- Bullet Cam
- Speed Pro L2320F+.030 with rods
- 71 442 SX distributor for sale
- 1979 Olds Delta 88 HOLIDAY COUPE parting out
- 68- only Cutlass and 442 Front Bumper Bracket Setup
- 68-69 Cutlass 442 Convertible Top Switch and more Convertible Parts
- 1968 Cutlass and Fenders 442Doors In CT
- 1968 442 TH-400 Short Tail Automatic Transmission—Code OG
- 1971 Cutlass Supreme Parts
- 70-75 STD WHEEL DISC/Hub caps Set of 4
- Parts Clean: tstat hsgs, lugs, alternator, starter, some FREE
- G body gray leather steering wheels
- For Sale 1969 442 HO Trunk Molding RARE!!!
- Cutlass W-31 Decal
- 1970 442 Cutlass W30 Decals
- Original tic-toc-tach from my 69 442.
- Hurst Dual Gate II
- T-44 Hood Lock Control Housing 1970-1972 Olds 442
- Master Cyl And Brake Booster
- NOS FLARESTAT 1965 1966 Cutlass 442 88 98 Starfire Toronado
- 68-72 B Pillar Trim
- For sale!!
- Nos Air shocks
- Original Heater Delete 442 W30 W31
- 1970 to 1972 Dash Housing Assembly
- OEM Rally pack 68/69
- 75 delta 88 conv. parts.
- 1971 Cutlass Supreme Grille
- Very nice Refurbished underhood light
- Front sway bar cutlass 1968-1972
- Chicago BOP Feb 21st Swap
- nice used tailight assembly for '64 fullsize Olds
- 1970 442 Steel Hood
- 1947 Olds 76 radio
- E head cores central MI [not mine] $-?
- Near NOS Mirror 1970-1971-1972 Olds F-85 Cutlass 442
- 7041251 quadrajet
- 70-72 B85 Belt Molding for Door
- Rally Gauges
- NOS Mirrors 1968-1969 Cutlass 442 1968 Hurst Olds
- 68 Lower Dash Plastic
- Original Aluminum Thermostat Housing
- Vista Glass - 68 to 72
- New OTC #6297 Ball Joint Seperator
- '68-69 L side fender "filler" panel (over headlight)
- Replated '70-2 Hood Lock and Latch - Great cond. and different "look"
- 70 to 72 Dash Delete Plate
- 1957 88 Dash Trim passenger side
- Hubcaps /dog dishes - 40's, early 50's, late '50's, fair condition.
- NOS P/W switch 1964-1970 Cutlass 442 Hurst Olds
- 70 to 72 442 Cutlass 4 Speed Console Parts
- NOS 68 to 72 442 Cutlass Fan Clutch
- 1971 1972 Head light Assembly
- 1970 cast iron letter L intake manifold
- 1970/71 Toronado 455 4 brl intake
- XT 14"x6" wheels set of 4, 11 / 18 1969 Dates
- Oldsmobile Starter
- Rally Pac 70-72
- 1970 442 Cutlass SX Fender Braces
- NOS Battery Cable 1972 Cutlass 442 Vista Cruiser 350 engine
- 1963 Harmonic Balancer , $90.00 OBO
- 1970 442 455 olds intake manifold
- 1970-72 Doors 442 cutlass hardtop
- Nos gm th350 th400 inspection cover
- Olds sunvisor
- 1950 fender skirts
- 1971 carb 7041251 core
- 68-72 Sill Plates with correct ribbing. Brand new.
- SSI center caps
- OEM 2 groove pulley set
- Oil Pan Milodon Stock Replacement
- Headliner bow wire set complete
- 70-72 sport steering wheel
- 1970 oai ram air hood
- Free '71 BOP TH350 Transmission & Converter
- New Door Strikers, Used Power Trunk Wire, Conv Top Header Pin, etc
- Rocket 350 500$ obo
- 72 Cutlass Fender Parts
- Toro oil pan
- 1972 dealer Post Cards
- 1970 Cutlass Supreme Hardtop Interior Parts—Dark Green
- 68 69 Cutlass S (Model 87) or 442 2-door Hardtop Rear 1/ 4 Windows
- 68-72 Cutlass Transmission Cross-members --Hardtop and Convertible --GM
- 69 70 71 72 442 Fender Emblems—Real GM
- Real GM Black Interior Parts for 68 and 69 Cutlass 442
- 69-72 Floor shift tilt column
- 1958 88 Fenders, Decklid, etc.
- '70-72 Convertible Sun Visors w/vanity mirror provision
- Trunk lamps - '69 (maybe earlier as well)
- 67 68 A body 4-piston disc brake setup
- 1970 442 Engine and trans
- 1969 12 Bolt 3.91 Rear End housing W30
- Fan and spacer
- 1978 Cutlass 2 DR tail lights
- o-axle Richmond ring and pinions
- 1974 delta 88 conv parts
- 1974, 75, 76 Delta 88 rear bumper
- gm 8.5 3.73 ring and pinion
- Two Crank Pulleys and a Waterpump Pulley
- 68-69 Convertible Door Wedges
- 1968-69 Driver's Side Fender
- 68-72 engine parts
- '68-'72 Cutlass/442 convertible inside header panels
- 70-72 Cutlass parts
- New GM Medium Loop spring 11ga - 60ft rolls - $50
- NEW '68-72 A-Body Convertible Top Cables and Relay Cover
- 1970 W25 442/W30 Hood
- New in bag vintage oldsmobile flag nylon 3.5 ft x 7 ft tall
- 66 442 Hood Lip Molding NICE!!!!
- Restored 68 revese light
- 1965 Olds 442 4 speed shifter
- 1970 Olds " W-31 " emblems F-85 Cutlass
- 69 Cutlass Trunk Molding - 7799208
- 70-72 Cutlass Floor Shifter - Complete
- 65 442 rear drums
- 67 442 LH chambered tail pipe
- '66 - '67 Choke stove housing assembly
- NOS 1969 Delta 88 tail light RS
- Parting out 66 Toro made Week One?
- 71-72 Stone Guard
- Not mine
- Olds F-Heads
- 1968 Cutlass and Fenders 442 Doors In CT
- Harland sharp s5003 and john kilgore racing gears (turbo 400)
- Bumper Jack
- 68 to 72 Rear Brake Cables
- 68 to 71 T-3 Head lights
- New 4 core rad top plate
- 71 to 72 Cutlass 442 Headlgith Asm with T-3
- 70 to 72 442 Cutlass Upper Fender Mldgs
- 1965 442 4 spd Frame (Back on the Market)
- 68-72 Cutlass 442 AC Hose
- 1955 88 4 door chassis/frame parts
- NOS wood steering wheel hub 1968 Cutlass 442 Hurst Olds
- 15" x 7" SS II wheels, complete with snap on caps, rings, & bezels.
- 1970-1977 Sport Steering Wheel Cutlass 442 Hurst Olds
- '70 Heater Hose Clamps
- 1968 Cutlass 442 Hurst Olds wood steering wheel assembly
- Thornton another big sale
- 324 3x2 engine, blocks trans, heads, cranks and other parts
- Stainless door edge guard
- Vacuum reserve
- 1961-63 215 engines, turbo jetfire parts
- Torker intake
- 1959 super 88 2door rolling shell
- ***'71/'72 Cutlass Parts for Sale***
- SSIII Wheel
- 70-72 Cutlass Map Lights
- Power Door Lock Harness 71/72 Cutlass
- 66 Cutlass/442 front of hood chrome.
- NOS 79 cutlass front panel
- Trico Wiper Blades
- 73 79 cutlass sport mirrors
- 68 Cutlass 442 front bumper bracket set
- 68-69 Cutlass 442 Convertible Top Switch and more Convertible parts
- 68 Bucket Seats Cutlass 442 in Connecticut
- Vintage Sun Specifications Tune Up Sheets Great Reference and Man Cave Office
- NOS 1970 Cutlass Emblems
- Rubber "OLDSMOBILE" trunk mat
- 72 Original Lower Dash Woodgrain Cruise/Convertible
- Olds dog dish set of 6 total $100 take all.
- 77 cutlass speedo & gague
- chrome alternator
- f/s 65-70 Big Car Disks Brakes central MI
- Holley Aluminum valve covers
- NOS 4spd Shifter Handle
- Th350 trans with new 2400 hughes converter, stock converter and shift kit.
- 1966 442 Sidewinder Tach
- NOS passenger side mirror 1971 1972 Olds 88 98 Toronado
- 1969 Custom Sport Steering Wheel N34 Olds Cutlass 442
- 1959 88 2door hardtop
- '59 OLDS NOS weather strip
- 68 69 Cutlass S or 442 Wheel Well Moldings
- 70 - 72 Cutlass Center AC Vent
- 70 - 72 Cutlass Side Markers - Rear
- 1971 Texas License Plates
- 1970 Cutlass F85 W31 Tail Lights
- 70 72 442 Cutlass Marker light set
- 70 to 72 Console light bracket Dual Gate
- 70 to 72 442 Cutlass 4 Speed Console parts
- 67 Cutlass 442 auto console for parts or restore 68 69
- 66 or 67 Toronado deck lid
- 65 cutlass trunk panel for sale
- 71 G heads
- 68 cutlass 442 gas tank
- 1967 425 for sale. 4 barrel setup. HO Block
- 78-80 aluminum wheel
- Running 403 Engine
- 200-4r Trans-Stock 32k
