View Full Version : Parts For Sale
- Clock/Fuel gauge
- For Sale: 70 - 72 Convertible Power Top Switch (OEM)
- NOS Short Hood Spear 1964 1965 Olds F85 Cutlass 442 Vista-Cruiser
- 1970-72 SS1 wheels Set of 4 w/trim rings
- 1970 442 Posi 12 Bolt - 3:23 SF
- Sport Steering Wheel 1969 Cutlass 442 Hurst Olds
- 1970 Cutlass 442 Rear Back-Up (Reverse) 70 71 Lights License Lite GM 72 Hurst Olds
- NOS 1970 to 1972 Cutlass / 442 Door Guards in Paper Packaging
- 1970 w30 engine parts USED Valves Rocker Arm SET Rod Bolts misc
- 1970 OLDS v8 Oil Fill Tube 70 Oldsmobile 350 and 455
- 1969 OLDS v8 Oil Fill Tube 69 Oldsmobile 350 and 455
- 1970 Original OAI hood
- 1970 to 1972 Cutlass 442 VistaCruiser f85 Hood Latch with Rod and Pivot
- T44 T-44 Latching Hood Lock Latches (2) with (1) A Cable and Cover
- Black Steering Wheel 1964 1965 1966 Olds Cutlass 442 Vista-Cruiser
- 1971 SSI All Chrome 14 x 7 Super Stock I wheels
- Olds HORN BUTTON CENTER CAP 1978 1979 Sport Steering Wheel
- 350 Intake Mainfold
- 1968 Wood Grain Steering Wheel HUB Cutlass 442 Hurst Olds
- 68 cutlass 442 core support
- 69 442 shifter tabs replated
- NOS set of 4 headlight retaining rings 5954892
- 66/69 NOS idiot light gauge
- 1970 type O NOS axle bearing retention plates
- 215 Olds forged pistons
- 1969 1970 1971 Cutlass 442 12" Map Light Rearview Mirror-Real GM--Restored
- 1967 Cutlass Supreme 4dr Qtr Mldg RT
- 1969 Tick Tock Tack 69 tachometer and clock combination Tic Toc Tac
- Rear side marker bezels 400841 x 2 with gaskets $40 shipped to lower 48
- 1968 emblems and hood chrome boomerang 442 Cutlass
- For Sale: 69 70 OEM 8-Track Face Plate
- 1965 442 carburetor NOS 7025050
- L-R 70-442 NOS Front Grilles #404684, #404685
- 1972 Cutlass Grilles 72 Cutlass Supreme
- 1971 Cutlass Metal Grilles 71 Supreme "Pot Metal" Grilles
- 1968 Oldsmobile Cutlass 442 Radiator Top Plate--Real GM
- 1968 Olds UHV Distributor 1111290 442 with 4 speed
- 1108389 Starter 0A23 Date Code
- 1969 Cutlass 442 Rear Back-Up (Reverse) Lights Set --GM 69 Hurst Olds
- 1972 NOS C and D lock set w/Console- Nearly Complete (No Glovebox Lock).
- NOS 1966 Remote Controla Mirror F-85 Cutlass 442 Vista-Cruiser
- Wilwood 12.19" Front Disc Brake Kit (140-7675-D) - Drilled/Slotted - $875
- Set of 2 RED Inner Fender Wheel Well Liners 1970 and 1971 442 Wells
- G Body Cutlass Qtr Pnl in CT
- 442 emblems
- NOS GM Trunk Lid Closer 1980's 1990's
- 1970-72 Cutlass Supreme 2-door trunk lid
- 1970 Cutlass S and base 4-4-2 hood
- 399404-1 KF real GM 68-70 Cutlass 442 Water Pump Pulley
- 70 71 72 Cutlass 442 Backdrive Linkage for TH-350 and TH-400 Trans--Real GM
- 1970 Fuel Tank 70 Gas Tank from w30 442
- 71 - 72 19 1/2 Inch Heavy Duty Cooling Fan with Clutch
- Repro sport mirrors
- aluminum thermostat housing that was cleaned and painted
- Lots of rechromed 60s- 80s bumpers
- 1969 OLDS 442 Original standard Flat Top High Compression cast pistons on rodpistions
- $100 shipped set 30 OVER TRW pistons
- NOS Grill 1984 Hurst Olds
- 1968 "Y" Exhaust Manifold 442 Hurst Olds
- 1970 to 1972 Black Plastic Inner Fender Well Liners USED Original OEM
- 1968 heat riser tube 68 heat-riser to air cleaner adapter with rubber grommet gasket
- 1970 to 1972 Cutlass Auto On Floor Shifter
- 1969 REAR 442 Bumper Brackets with TABS 4 442 Trumpets Hangers
- 1966 Delta 88
- 1959 Dynamic 88
- 68-72 Cutlass 442 Convertible Rear Access Covers
- NEW in the sealed bag (s) 50 Foot Pack of 3/8 split corrugated plastic wire loom
- NOS 1362285 speedometer sleeve for 69-72 TH 350
- Q4 Quad 4 Cylinder Head From Oldsmobile Racing
- NOS 1969 to 1970 TH350 4BC Trans Modulator 3963812
- 1970 NOS F-85 / Cutlass S Tail Light Lens 5964137
- NOS 1970 to 72 F-85 / 442 Saginaw Tie Rod Sleeve 5668674
- NOS 330 and 350 V8 Timing Chain 401584
- 1968 69 70 71 72 Cutlass 442 Upper Rear Control Arms w/ New Bushing Set -Excellent GM
- NOS 1976 1977 Olds Omega Grill Emblem SX Hatchback
- 411 Ratio C Clip 12 Bolt "Chevelle" (Canadian 1969 Cutlass)
- A-Body Disc Brake Changeover
- 1969 Olds Cutlass 442 N34 steering wheel horn buttons harness Nos
- 401159 NOS 68-70 idle dashpot
- NOS White Oil Filter Made In USA 3 filters $35 shipped to lower 48
- Cutlass wheel bezels
- NOS 18 inch Trico Wiper Blades 1970's
- NOS Door Panel Escutcheon 1970 Olds Cutlass 442 Sport Mirrors
- NOS Dash Map Light 1968 Cutlass 442 Hurst Olds
- NOS Antenna Mast with Arrow Point 1960's
- 66 or 67 442 Chambered Exhaust System
- NOS 8 track player nose plate and door
- Show Car Display Classic Tires MACH SIXTY and MACH SEVENTY set 4
- GM a body power seat track
- AC Compressor and brackets
- 65/66 F-85 Standard Steering Wheel Horn Cap
- NOS #403589 69 only N34 sport wheel horn contact
- NOS 1970 to 1972 F-85 / 442 Windshield Wiper Control Escutcheon #404775
- NOS 1964 to 1971 F-85 / 442 Automatic Brake Pedal #3858199
- NOS 1975 TH350 Speedo Transmission Sleeve #1362285
- NOS 1970 to 1972 TH350 Trans Oil Pressure Control Spark #6462514
- NOS 1970 F-85 / 442 Ignition Replacement Lock Kit #3981938
- NOS Speedo Sleeve #25512340
- 68 69 70 71 72 Cutlass 442 Emergency Brake Pedal Assembly-- Nice GM
- Chevy 12 bolt (Utah)
- Custom Solid Roller used in 2009 Engine Masters 307
- Olds Visor Vanity Mirror w/THERMOMETER 40's 50's
- NOS Gas Cap 1970 Olds Cutlass 442
- 70 71 72 Oldsmobile Cutlass 442 Center Grill Support-- Nice GM
- 1972 350 Quadrajet 7042250
- front bumper 71-72 Cutlass
- Orig. Hurst Dual Gate Shift Knob with GROOVE
- Orig. Hurst Dual Gate Shift Knob 1970 1971 1972 Cutlass 442 Hurst Olds
- NOS Pedal + Pad 1969 1970 1971 1972 Cutlass 442 Hurst Olds
- NOS Console Trim Plate 1973 1974 1975 1976 1977 Cutlass 442 Hurst Olds
- 68/69 NOS Rally PAC gauge
- NOS never mounted SSII 14 x 7 rim
- 1970 455 Motor - Rebuilt
- Fiesta Spinner Hub Caps for sale
- 68-72 Cutlass 442 Complete Seatbelt Set- Restored GM
- 66 tri carb
- 66 cutlass parts
- 1970 Ohio License Plate - W-31
- NOS L.H. Headlight Bezel 1975 Cutlass 442 Hurst Olds
- 1971-1972 sport mirrors (pair)
- NOS R.H. Mirror 1966 Oldsmobile 88 98 Toronado
- NOS 1970 1971 1972 442 Cutlass F85 Vista Cruiser Remote Mirror Bezel Escutcheon
- NOS 1964-72 GM 399941 Harris 62538 Rear Control Arm Rubber Bushing
- 2-Q-70 Spark Plug Wires
- NOS 1969-1975 NOS F85 Cutlass 442 Accelerator Pedal GM 399431
- NOS 1970 F-85 / 442 Parking Turn Lamp Gasket #5960900
- new NOS Rear Anti-sway bar spacer shim gm
- NOS 1970 F-85 / 442 Rear Brake Hose 9753903
- NOS 1970 Cutlass / 442 Front Brake Hose 1230992
- 1967 Cutlass Hood
- GM Rear License Plate Frame 1964-1972 Cutlass 442 Hurst Olds
- 8 Track Tape Player Knobs 1968 1969 1970 1971 1972 Cutlass 442 Hurst Olds
- 1970 Oldsmobile exterior colors stripes dealer book
- 1968 1969 8 track parts Cutlass 442 Hurst Olds
- 1970 1971 1972 8 track parts Cutlass 442 Hurst Olds
- 1970 72 rear license plate bracket
- NOS oil fill cap FC-60
- Oldsmobile clip on vanity mirror
- NOS 1968-1970 W-Car Dashpot #401159
- 68-72 Cutlass 442 Heater Box with Blower Motor-- Ready to install
- 1969 70 71 72 Cutlass 442 Door and Window Crank Set--Excellent GM
- NOS Trim Beauty Rings 14x6 GM without boxes
- 8 TRACK FRONT PAD 1969 1970 1971 1972 Cutlass 442 Hurst Olds
- NOS Flarestat 1965 1966 Olds Cutlass 442 88 98 Toronado
- NOS AC Oil Filter 1968 1969 1970 Cutlass 442 Hurst Olds
- NOS AC Oil Filter 1971 1972 1973 Cutlass 442 Hurst Olds
- NOS Letter "E" GM Mark of Excellence Blank Key 1969 OLDS 69
- NOS Gas Cap 1971 1972 Oldsmobile Cutlass 442 Hurst Olds
- Automatic shifter 1973-1977 $200 shipped
- 442 4 speed shifter $300 shipped
- Repop 67 W30 scoops with ram air box, air cleaner and hoses
- 1965-70 big body posi unit
- 1973-75(?) exterior window trim pieces
- 1955 Power Steering Column Parts
- NOS Firestone Wide Oval G70x14 Tire - Perfect for Trunk
- small block exhaust manifolds last used on a 330 motor
- 69-72 buckets seats
- 408328 No Air NOT w30 water pump
- 1970 Aluminum Water Outlet Ther Mo Stat Housing #5 casting 404632
- 1970 Oldsmobile 8 track Faceplate Cutlass 442 V-C
- Int Reg Alternator New 100A Stator + Addt'l Parts
- 1969-72 Exhaust Shroud New Hardware
- 66 cutlass/442 bucket seats and automatic console other parts available
- 1963 F85 Engine & Transmission
- 1970 Heavy Duty Cooling 70 w30 OS clutch 19 Inch Rad Fan Blade to fit the NOS Shroud
- 15 in steel wheels, desert condition
- NOS Heater Control Valve 396927 1966 1967
- Vintage NOS Hurst Hatch T-Top Weatherstrip 1973 1974 1975 H/O Hurst Olds
- 70 71 72 Oldsmobile Cutlass Supreme or 442 Convertible Rear Fender Extensions -Nice G
- 1968 Cutlass 442 Door and Window Crank Set--Excellent GM -
- 68 69 442 Olds 400/455 Code KE Water Pump Pulley-- Real GM 399401
- 2 Groove KM and KJ Heavy Duty Cooling Pulleys Needing Repair
- 66-67 convertible chrome header ends new
- Olds 1971 dated harrison 3 core radiator tanks
- 1970 8track Burl Wood Face Plate 70 FacePlate For Cutlass 8-Track Deck
- 1966 1967 Olds Cutlass 442 Valve Cover Breathers
- 1970-72 Cutlass 442 am/fm and 8 track player front speaker patch cord Original equipm
- Rear Speaker 1968-1969-1970-1971-1972 Olds Cutlass Wagon, Vista-Cruiser
- Be Cool Electric Fan Wiring Harness Kit 75021
- 40 amps Be Cool Fan Relay Harness Kit 75017
- BOP 10 bolt 8.5 posi , 726
- Headers, fit 67 with sbo
- 4 sale : 1971 License Plates .. K35 442
- 1967 Olds Parts - Left Over Parts
- Olds Embossed Rocker covers
- NOS Hood Cable 1976 Olds Cutlass, 442, 88, 98, 1977 Cutlass 442
- NOS Rear Bumper Trim 1974 1975 Cutlass 442 Hurst Olds
- NOS Dash Applique 1975 Cutlass 442 Hurst Olds
- NOS CLOCK 1973 1974 1975 1976 Cutlass 442 Hurst Olds
- 77 Firebird 1977 Trans AM cooling fan NOT Clutch-Fan
- "NEW" Pair of Headers SBO 350 OLDS
- 66-67 cutlass/442 hardtop doors complete power windows
- Olds ssiii wheels
- 68-72 Cutlass 442 Rebuilt GM Delco-Remy Wiper Motor #4939300
- 1971 455 Engine wz exhaust G Heads 71 442 Carburetor 7041257
- 1970-72 Olds 442 Sport Steering Wheel. Exceptional
- Big car body parts 71-75
- 1970-442 W30 Rochester Carburetor #7040258 Auto Trans
- Radiator Core Support Cutlass/442 NEW $700
- OW Tank 1971 Heavy Duty Cooling Radiator ZK Tag Fresh Rebuilt 4 Core HD
- 1967 67 Olds 442 hood
- NOS 1961 1962 Outside Mirror F-85, Cutlass, Jetfire
- Rhoads lifters for the 350- 455 olds .842 diam
- Wanting to trade 8 track face plate!
- Cruise Control Servo Bracket - '70 - '7?
- 68-72 olds cutlass 442 manual transmission break pedal new old stock
- 1970-72 olds cutlass 442 Hurst Duel shifter with brackets
- 1970-72 olds cutlass 442 interior steel windshield piller covers
- 1970 Oldsmobile Cruise Control Parts Cutlass 442 Vista-Cruiser
- 1970 -72 Oldsmobile Hurst duel gate shifter for automatic
- 1970 Oldsmobile neutral safety switch for Hurst Duel Gate Shifter
- NOS 1963 1964 Olds Parking Brake Warning Light 88 98 Starfire
- Unused Cigarette Lighter 1970 1971 1972 Cutlass 442 Hurst Olds
- 1970 Oldsmobile Original Trunk Light Cutlass 442
- NOS Cruise Control Lever 1977 1978 1979 1980 Cutlass 442 Hurst Olds
- NOS Olds Washer Jar 1962 1963 1964 88 98 Starfire Cutlass
- 1970 Oldsmobile CUTLASS Alternator from 70 SX same as w31 NON AIR
- 68-72 Cutlass 442 F-41 NOS GM Rear Sway Bar & Boxed Lower Control Arms -Complete
- Sport Steering Wheel w/GRAIN 1970 1971 1972 Cutlass 442 Hurst Olds
- 70 Cutlass 442 Rear Bumper Brackets
- 70-72 Cutlass Supreme LH Rear Quarter Extension
- 69' Non A/C Water pump 400/455
- 1968 to 1972 Black OEM 442 Floor Mats
- 14x7 SSII bolt center cap rims
- 442/W30 TM Posi Rear
- 442/W30 3:23 SF Posi Rear
- Nos stewart warner 8,000 rpm tachometer
- ATI flexplate for the 425 crank
- G-Body Cutlass parts for sale updated list 1/17/2626
- 1954 1955 1956 Oldsmobile 88 98 2 door hard top door flipper
- 68-69 HO/442 C Heads
- 1970 442 Front Grill
- 1970 Dual Gate Console
- 1970 AM plus 8 Track Player
- 1970 442 Bumper Cores
- 70-72 Cutlass/442 Decklid
- 69-77 Oldsmobile Cutlass 442 4-spoke Steering Sport Wheel-- Real GM
- 1970 442 455 E Heads - CHEAP
- 1965 Olds 330 engine on Craigslist, cheap - SoCal
- W30 3:91 TO Posi Rear
- 1970 350 Harmonic Balancer
- 68-69 Hurst Olds Heads
- 350 blocks $50 ea & other 350 parts
- 1964 Olds 394/Slim Jim
- 1970 442 with console Neutral Safety Switch Bracket and mounting screw NICE
- NOS Delco Ignition Coil 1115238 1964-1972 Cutlass 442
- For Sale: NOS '64-'66 Oldsmobile V8 Head Gasket - 382549
