408328 No Air NOT w30 water pump
This was cleaned as is pictured.. has casting number "1" 1971 and 1972 without A/C and 342 gears Standard Cooling Waterpump with cast iron impeller $165 shipped to lower 48 states Consider to be CORE for rebuild
https://classicoldsmobile.com/forums...g-over-191894/
I don't know why my 5.6" water pump is positioning the fan so deep into the shroud. Water pump pulley incorrect?
Here's my dilemma in this thread:
The original cast iron impeller works better than the "tin star" commonly found on rebuilt and replacement pumps
a replacement fan clutch may be Longer than the original , fan further from pump..
5,6 water pump is 1/2 inch different than original non air , fan further from pump...
When I run racing fuel in my 1972 110 octane in my 1972 gauge reads 20degrees cooler... than pump gas
