View Full Version : Parts For Sale
- 70- 72 Cutlass 442 Speedometer Floor Shift
- NOS 70- 72 Cutlass 442 Dash AC vents
- 1959 Olds 98 Rear Bumper Pieces
- Console mounted factory tach
- 1968-69 dash maplight
- 1970-72 dash maplight
- 1968-72 thermal vacuum switches
- USED '69 Cutlass S black front Bench Seat
- USED mid-80's Cutlass T-TOP BAGS
- used Pass Side black inner fender 70-72
- Olds 307-350-330 blocks - engines
- 70 - 72 NOS fenders
- 1966 442 disk brake conversion package
- 1966 442 4 speed pedal throttle actuator & tri power bell crank
- G body aluminum bumper supports
- crank shafts
- 1970 DeLuxe Steering Wheel Olds Cutlass "S" W-31 442 W-30 Vista-Cruiser
- Blocks and heads
- 1970-72 center console/shifter
- NOS 1951 LH Quarter Panel Shield Molding 4586940
- w31 shifter
- 69 Cutlass and 442 convertible black seat belts
- Poverty hub caps
- Retirement sale , Phase one . Olds parts
- F code intake tri carb tri power TRIPOWER
- 1971-72 O.A.I complete aircleaner
- 1969 442 . 14 inch rims and tires
- Relay Really Relays times 9
- Inside rear view mirrors lighted
- 12 bolt AXLE
- Dash glove box light assembly
- 68 Cutlass Manual Steering Box & arm & joint
- W27 rear differential cover
- 1970 442/cutlass clutch fan assembly
- Big Valve C Heads
- 70 442 rear bumper
- Oldsmobile engine parts
- Nice used hardware for mounting 1972 cutlass heater/ac box
- 73 Olds 98 88 Parts Car Not Mine
- 1981 thru 1988 Cutlass Regal doors
- 68 Cutlass Parking Light Set
- Dualgate top plate I.D.
- Cutlass parts near New Haven CT, mostly 68
- n o s clutch pedal pad
- Used factory 4 speed console handle and a hurst shifter
- trunk lights 1964 - 1969
- 70-72 lap AC plastic valance
- 1976 Olds 455 Engine
- factory Hurst 4 speed shifter FS
- early 50s dog dish hub caps FS
- comp cams xe284 hyd cam
- 68-72 flowmaster 2.5" exhaust
- clutch pedal set
- Head Light Bezels 1970
- FS - 1959-60 Oldsmobile parts, Quebec, Canada
- 1966 442 Front Bumper
- 1967 442 Parting Out
- 1967 Cutlass Parting Out
- 70 to 72 NOS Dual Gate Shifter, Nos cable , nos bezel
- NOS Rocker arm set with pivots 442 W30 Cutlass W31
- NOS 442 w30 Cutlass W31 Valve springs 404729
- 67 NOS 442 Valve cover decal
- 66 to 69 Ralley pack oil sender
- 68 to 72 442 W30 Cutlass W31 Rally pack oil sender elbow
- 70 to 72 442 Cutlass ralley pack oil sender
- Edelcrock 0L4B Intake Olds 350
- front inner fender extensions 70 71 72
- 1965-1976 Oldsmobile Big Block Headers
- 1964-67 hood hinges with springs
- 1965 Cutlass 442 Conv't Interior (RED)
- 1971/1976 88&98 pass-side mirror Gettysburg
- 1971 Delta Royale side "gill" louvers trim
- 1970 Cutlass Supreme door panels
- Parts at Nationals
- Late 60s Alternator/power steering brackets
- 1972 442 3 speed shifter
- GM olds flywheel
- Magna fuel prostar 300 fuel pump
- 830 Quick-fuel
- drop base factory air cleaner for use with OAI
- NOS 1970 Cutlass SX,Supreme side marker lights
- G Body
- Thornton OAI lid assembly
- 1970 NOS 442 Tail light lenses
- NOS 1970 442 Tail light lenses
- 70-72 98 & 88 front nose pc & fender
- Oem chrome valve covers
- 2 piece 455 front timing cover
- 3138 shifter Olds 442 stick
- Bumper car Guards
- 1969 442 W-30 Hurst Olds N34 Center Cap Sport Steering Wheel
- toronado oil filter housing
- 1974 455 toronado exhaust manifolds
- 72 Cutlass Radiator Support
- OAI setup
- Delta 88 Interior Parts
- oil filter housing
- light show
- Cutlass/ Regal doors 1981/88 @ Gettysburg
- 1972 A body core support / cross member @ Gettysburg
- 1970 W-30 Intake For Sale
- 69 Cutlass 442 Quarters, Core Support, Door, Frame for Parts
- W & Z exhaust manifolds
- 1965/70 B&C body parts, delivered to Gettysburg
- Lakewood blow proof bell
- 69 to 72 NOS Ralley pack Oil Sender 6462137
- Offenhauser 5165 intake manifold
- MSD Pro Billet distributer 8566
- 1965 14" deluxe wheel cover
- 1969 Oldsmobile Cutlass Supreme Booster
- parting 1970 Cutlass/442
- 1949-1950 ? Oldsmobile Turtle Back Air Cleaner
- Olds 455 headers
- Olds SFI Flexplate
- Comp cam camshaft and lifters
- Vacuum pump
- Toronado transaxle
- 1971 Wiper motor
- floor shift speedo 1970-72 cutlass/442
- Rear defogger switch and harness 1968-69
- Original power window setup
- W30 starter 1108389
- 1970-72 AC dash side vents
- 1970-77 sport wheel
- Used Edelbrock Torker intake Manifold
- BOP NOS P/Drum brake kit
- Parting 1972 4 door Cutlass Sedan
- 1108348 starter 1968 442
- 1969 4BBL air cleaner assembly
- Standard horn pad 1970-71 cutlass/442
- 1970 HT trunk floor clip
- Boxed arms with rear sway bar
- 1970-72 lower AC valance
- 1971-72 original ram air hood
- GMPP Oldsmobile valve covers
- ARP head hardware
- AC vacuum unit cutlass/442
- 1968-72 cutlass/442 ac kick panels
- 70-72 Cutlass Supreme Roof
- Set of 14x7 SSI Wheels
- 1973-77 Hurst dual gate shifter
- Engine Block 350 Olds
- 1971/72 NOS Stone Shield
- 68 442 12 bolt O type posi SB 2.78 for sale
- Dashboard
- 64-67 Rear Inforcement Braces
- '70 tail light housings & lenses
- NOS temp switch 6402383
- FAST EFI 2.0 For Sale
- 1971 Sienna Glove box door
- 70-72 ashtray doors
- Various qjets
- Moroso 7 qt oil pan
- 1968 cutlass 4 door parting
- Metal hood gills 1971 1972 442
- electric power trunk release x2
- 71 72 sport mirrors
- 1970 DELUXE seat belts with shiny buckles
- seat belts 1972
- seat belts 1969 1970 1972
- 1970-72 gate shifter and console
- 1970 date coded OAI
- 73-77 AC compressor mounting brackets
- clutch switch
- 4 rows of top plate
- Two Starfire Steering Wheels for sale
- Heads, blocks, cranks and engines
- Floor shift steering column
- Front air dams, 1968-1972 Olds Cutlass 442
- Comp Cams dual valve springs and retainers
- Snap into a Slim Jim!!
- 1970 455 heads
- 1968 and up 350 455 flywheel
- HURST shifter handle 4 speed trans
- C heads
- 1970 442 W30 Alternator
- 1966 Toronado exhaust tips
- 442 W30 Cutlass W31 Rallye pack oil senders
- 69-72 Floor shifters
- 1971-1972 Cutlass S hood with louvers
- 1968 Cutlass Black dash pad non ac
- edelbrock torker
- Kook's headers for 64-67 A-body $50
- instruments dash guages 70 71 72
- 7041257
- 1111932 distributor
- olds distributor 1111289
- 1111042 442 points distributor
- Mondello iron heads and Torker intake $300
- 1963 starfire dash pad
- 1957 Oldsmobile Parts
- 71/72 Stone Shield & Headlamp Bezels
- open face alternotor
- dual inlet air breather
- Dash plastic No Pad
- Oldsmobile 15 X 7 Trim Rings 1970's Cutlass 442
- 68-72 vista cruiser tailgate - $250 (Not Mine)
- 64 330 one year only water pump
- Hood hinges
- 7.5 ring and pnion GM gears 3.73 3.08 3.42
- NOS 1970 442 W30 Cutlass W31 Console chrome insert wood grain
- console parts reverse lock outs wiring and more $200
- bucket seat parts
- quantity of 1970 tail light lenses
- 4 speed four on the floor
- black powder coated gas tank straps and 1 fender brace
- Offenhauser 360 BB Intake Manifold FS
- NOS Cutlass 442 Oil filler tube and cap Chrome
- 1970 Cutlass Alternator Rallye 350
- 1970 442 Carburetor 7040257
- 1968 442 parts clutch and brake pedal assembly and 1 exhaust manifold
- B85 WIDE Belt line trim 70 71 72 holiday coupe 442 hard top cutlass s
- OEM OAI ram air air cleaner base
- Rim Blow 1970 steering wheel
- Neutral safety switch 1970 automat console shift parts
- Dallas Craigslist/ FB marketplace Olds 455 rebuilt $650
- BRAND NEW PORTED/NEVER RAN EFI BIG BLOCK OLDS RPM dual Plane with Fuel rails and reg.
- OLD Mondello 455 Rods, degreed balancer, Engle Hyd Roller Cam, TCI BREAKAWAY TORQUE
- 461 CID BBO short block (disassembled) $500
- 1969 Oldsmobile Cutlass S/442 Tail light assemblies
- 1968 442 body
- 1963-64 NOS LH dual exhaust manifold
- 1972 Oldsmobile 350 with 7A Heads Part Out
- 10 bolt 8.5 gears used original GM
- Parting out 1963 Starfire
- 1970-1972 sport wheel assembly
- 455 FA block pistons w/ Rod's
- Front clear turn signal lenses 71-72 Cutlass
- NOS RH Sport Mirror 1970 442 W-30 Cutlass W-31
- 64-67 A-body headliner welting
- Powermaster 9510 Mini Starter
- NOS front stabilizer bushings
- NOS manifold choke stove
- NOS accelerator pedal 1968-77 cutlass/442
- NOS radiator hose top clip
- USED side marker with retainers nuts hardware
- NOS 1970 Right Rear maker light Cutlass SX
- NOS RH outside chrome mirror
- NOS dash bead 1970-72 442
- NOS 1970-72 front side markers
- NOS 1970 hood tongue 442 numbers
- 1970-72 dash center vent no ac
- NOS 1971-72 RH fender filler
- A-1 Cardone rebuilt wiper motor
- 1968-72 Olds Rear Window Defogger, Blower Type
- 66 l-69 tri carb bellcranks
- 62 63 horn button
