View Full Version : Parts For Sale
- Radiator top plate 1970-72 Cutlass Supreme
- 1970-1972 Automatic console insert
- 68-69 D heads
- pistons and rods 455
- 1970 OAI Hood Lock Plates
- Fuzz
- 71 Delta 88/98 NOS Grill Molding RH
- 1971 Olds Cutlass Frame for sale $700.00
- 1968-70 NOS GM DASHPOT 442 H/O W Cars
- 1970-1972 A body OEM speedometer and clock for sale
- NOS Ignition Coil Delco 1115238 1964-1974 Oldsmobile
- Nice Olds die cast original thermo housing
- 1971-72 New Repro Grille Mounting Brackets
- 1971-72 New Repro Park Light Lenses
- NOS GM Rally Wheel Center Caps 1975-1987 Olds 442
- 66 Cutlass hood, AC parts, rear bench seat
- Olds Hurst Dual-Gate Shift Knob Daka-Ware 1968-1975
- 1970-1972 A body brand new tic tock tach for sale
- 1970-1970 OEM A body speedometer, fuel. gauge and clock for sale
- 71-72 Coolant overflow tank, not complete #410008
- WANTED: Holley street dominator olds 455
- 403 sbo
- New Repro 1972 Tail Light Lenses
- Stock SBO cam, lifters, rockers, etc
- 403/ sbo harmonic balancer $35
- 1970 Cutlass/442 front bumper
- For sale 350 olds engine
- 1970-72 New Repro Quarter Panel Extensions
- New 1970-72 Chrome Remote Drivers Mirror
- 1970 open alt 1100880
- 70-72 NOS parts
- 69 253 service carb
- 68-69 ve1 impact strip
- Nos 69 antenna
- 15X7 Trim rings
- New 1972 Supreme Grilles
- 1947 Olds Engine Overhaul Parts & More
- FREE tissue dispenser
- '71 Supreme, parting, trims and small bits
- cruise control parts with dash switch / wood grain also 4 spoke sport steering wheel
- For Sale 70 to 72 Cutlass non dual gate shifter
- 455 Speed Pro pistons std bore and rings
- Hurst Dual-Gate top plates 1970, 71-72, 73-75 Cutlass 442 Hurst Olds
- 67 Delta 88 (Free+ Freight or pick up)
- For Sale 70 to 72 Accelerator cable and 4 bl carb bracket Very Nice!
- 1968 455 engine
- 1970 hockey sticks hood trim cutlass 442
- "F" Head with 51 Julian Date
- Olds rocket breather
- NOS GM Static Collectors
- NOS Barn Find 1970-1972 Sport Steering Wheel Olds Cutlass W-31 442 W-30
- Glass Windshield Washer Jar and Mounting Bracket
- 1968 Horn Cap
- 1969 Cutlass/442 Shift Indicator Lens New
- 1970 Sport Mirror Gaskets New
- 67-69 Cutlass/442 Auto Console Shift Seal New
- 68-72 8 track knobs and bezels
- 1970 Olds Rear End
- NOS Accessory Thermometer 1972 1973 1974 Cutlass 442 Hurst Olds
- NOS Accessory Thermometer Olds 455 GMC Motorhome 1973-1978
- NOS 1970 Sport Mirror Door Panel Escutcheon Cutlass W-31 442 W-30
- 1970 Oldsmobile NIGHT WATCH option Cutlass 442 Vista-Cruiser 88 98
- Water pump cores + parts
- #8 heads under 2k mi. Since rebuild $500 obo
- 1969 442/Cutlass Ash Tray Door Assembly
- 74 350 4bbl factory intake manifold $50
- New 1968-72 Front License Plate Bracket
- 66-67 442 Parts including 67 442 hood
- 64-67 68-72 Heater Cores
- 1968-72 Heater Hoses New
- Switch pitch / kickdown switch
- Early 70's NOS Nite-Watch Switch - Not Mine
- 65 cutlass/442 two tone moldings
- Edelbrock Performer 455 intake and 750 Demon
- 1975-85 Delta 88 and 98, 1977-90 Custom Cruiser Gauges
- FS '79 Delta 88 98 Tilt & Tele column
- FS Olds B Body 2Dr & 4Dr "Vent Shades"
- FS '88-'90 Custom Cruiser Pass Power Seat Track
- 1967 F85 Steering Wheel
- Wiper Motor
- 1970-1972 OEM gauges for sale
- Brand new Tic Tock Tach for sale
- Oldsmobile/Chevy Valve Cover Spacers Cutlass 442 Hurst Olds
- 1967 442 Rochester 7027156
- OLDSMOBILE Trunk Mat
- NOS 14" Trim Ring for 75-76 Starfire
- Transmissions - TH350 & TH400
- 1973 Rally Pac Guage + Floor Shift Speedometer Cutlass 442 Hurst Olds
- '70 - '72 Assorted Trims
- '70 - '72 quarter panel inner backing pieces
- 69-70 parts
- 1965 Tail Lights
- 1969 Head Rests
- 70-72 glove box doors
- 70-72 dash lower vents
- 70 442 grills
- 1968 cutlass 8 track player
- 1970 Post car side door trims
- Electric Trunk Release
- '70 - '72 lower dash vents w/ 8 track option
- 1965-67? A-body steering column for 3 on the tree
- 8 Track 8-Track 8track Player with housing
- Rally wheel hub
- 70-72 power trunk option
- 70-72 8-track housing
- 68-72 GM A-Body door hinges
- 1970 442/Cutlass AM/FM radio
- 70 442/Cutlass front turn signal housing
- 70-72 cutlass supreme rear quarter extensions
- 7040253 service replacement carb
- olds 455 block - local pick up only
- 68-69 floor console
- Late Seventies B car spare tire hold down
- Rear Brace + Ground Strap 1970-1972 8 track Cutlass 442 Hurst Olds
- '70 - '72 Floor shifter and related
- LH Exhaust Manifold 1965 1966 1967 1968 442 W-30 Hurst Olds
- 1970 Safety Sentinel Speedometer Cutlass 442 Vista-Cruiser
- Power door lock parts bundle
- For Sale NOS Nose Rocket for a 1972 Cutlass S
- 404847 x water pump date code 32
- 68-72 a/c mount bracket #2
- 68-72 battery tube and bracket
- 70-72 dash switches and ash tray
- 1969 Cutlass 442 reverse light housings #2 - no wiring
- 8J23 Dated alternator 1100777 55A
- 1968 Cutlass floor shift column .. steering wheel..and misc
- 7040258 for sale What T...
- For Sale 70 to 72 power trunk solenoid tested works great
- For Sale One pair of new repo W-31 emblems
- For Sale- One pair of NOS 1970 Cutlass Fender emblems
- 1969 Cutlass/442 Rear Door Panels
- NOS 1970 oldsmobile hood script
- Rear Bumper 1969 442
- Horn Button 1978 1979 Sport Steering Wheel Cutlass Delta 88 Hurst Olds
- Misc 455 engine parts, block, pistons
- 1970 442 Used Rough Rear Bumper Core
- New 1971-77 Turn Signal Lever
- "1964 Oldsmobile 14" Wheel Covers / Hubcaps - NOS" - For Sale...
- Manual Steering Box
- 1968 Cutlass Supreme Hub Caps Set of 4
- NOS Oldsmobile Distributor #2
- 5 Olds engines for sale
- 73 & 74 Toronado rear bumpers
- 442 Grilles
- 64 65 66 Cutlass/442 Steering Wheel
- 1970 Cutlass Front fender
- Edelbrock Performer RPM
- Toro windage trays - stud - nuts
- Temp/oil senders
- Sunvisor holders
- 60-70 blue seat belt
- 69-70 seat belt
- 69-70 blue seat belt
- 70 blue interior parts
- 72 bucket seats
- NOS 1976 Oldsmobile Cutlass Supreme Grills
- NOS 1977 Oldsmobile Cutlass Supreme Grills
- 90 degree Speedometer adapter
- 1970 "4" fender emblem
- 1970 headlight bezels cutlass 442
- 1970 olds cutlass parts
- 1970 442 GRILLS ! NOS ? NO but GM
- NOS 442 w30 Air cleaner Decal
- NOS 1970 442 w30 Decal
- NOS Cutlass/ 442 Accessory fuse kit
- For sale 1970 Oldsmobile new car kit and folder
- NOS speedometer reducer for a automatic
- NOS speedometer reducer for a 4 speed
- Original 1968 to 1972 442 W-30 molded heater hose 400888
- 1970 Cutlass W31 Carburetor vacuum break.
- Rare 1970 442 W-30 NOS Alternator Parts
- NOS Cutlass 442 455 Oil Dipstick Tube
- 1969-1972 Cutlass 4 row radiator top plate
- Brake Booster Delco Moraine, 1967-72 A Body Cutlass
- 1978-1988 RWD Cutlass ash tray.
- Stock main cap bolts
- Let my junk become your junk
- Th400 long tail
- NOS R.H. Mirror 1971 1972 1973 1974 Olds 88 98 Toronado
- NOS Remote Control Mirror 1971 1972 Olds 88 98 Toronado
- NOS Mirror 1963 F-85 Jetfire 1964 1965 Olds Cutlass 442
- 350 Nodular Crankshaft, DSS Pistons, Rings, Rods, : Balanced Assembly $350. NE TN
- 1965 Cutlass/442 patch panels
- "OLDSMOBILE" accessory License Plate 1970 and up
- NOS Antenna Mast 1967 1968 1969 Cutlass 442 Hurst Olds
- 1967 Vista Cruiser 3:08 posi rearend
- Free Miscellaneous Olds 350 Parts
- Berejik Oldsmobile dealer items Needham Mass.
- NOS Cruise Control T/S Lever 1971 1972 1973 1974 Cutlass 442 Hurst Olds
- NOS Cruise Control T/S Lever 1977 1978 1979 1980 Cutlass 442 88 98
- NOS 1967 Underhood Lamp Cutlass 442 Vista Cruiser 88 98 Toronado
- 70-72 chrome mirrors NEW
- Console Liners Part number: 404806 & 404807
- 1968 1969 Olds Toronado Headlamp/Grill Valve
- For Sale 70-72 Cutlass Driver's door and green tint glass
- Lakewood bellhousing and other parts
- OY OIL pressure sender
- Olds Headers
- 1970-72 Cutlass/442 Front Bumper Mounting Brackets
- 1970-72 Convertible/Supreme Quarter Extensions
- Olds Sport Steering Wheels 1978-1979 Blue Tan
- Nos 1962 1963 oldsmobile delco voltage regulator
- NOS Ignition Wires - 1968
- N.O.S. 74-75 Delta 88 conv quarters.
- 1967 Rally Pac with Speed Minder
- 371 Engine with transmission
- 1966 88/98 front fender antenna original,good condition
- 1970 Cutlass Type O R2 Standard Rear End
- 1970-1972 442 Ignition coil 216-BR
- Original 1976 alternator core
- 64 65 66 442 CUTLASS F85 Cutlass Black Steering Wheel 2 Spoke
- 66-67 Cutlass Seat Foam New
- For Sale NOS shifter cable for 70 t0 72 Cutlass (non dual gate)
- For sale NOS 71-72 Cutlass fender emblems Nice!
- For Sale 455 Exhaust manifold heat shroud New reproduction
- NOS 1970-1972 Cutlass/ 442 Hood Cable
- NOS 68/72 Cutlass/ 442 4 speed brake pedal
- NOS Cutlass / 442 Oil Dipstick Tube /Guide
- NOS Cruise Control Servo 1968 1970 1971 Olds Cutlass 442 Vista-Cruiser
- 1968 8 track tape player housing Cutlass 442 Hurst Olds
- 1968 1969-1972 8 Track Front Pad Cutlass 442 Hurst Olds
- MSD 8529 new ready to run distributor billet see ad
- 1972 Dark Saddle dash
- Sport Mirrors 1971 1972 Cutlass
- wiper motor
- Under Dash 8 Track Knobs 1968-1972 Oldsmobile
- 1968 455 short block
- Rocket
- NOS new in GM box inside door handle
- 15x7 Rally wheels with bolt on center caps
- For Sale 71 and 72 Cutlass Sport mirrors Nice!
- New in the GM box NOS 15 inch trim ring 419269
- DSS Pistons, Rings, Rods, 350 Nodular Crankshaft: Balanced Assembly $350. NE TN
- Cometic 5809-.040 head gaskets...sale or trade
- For Sale Complete Dash wiring harness from a 1970 cutlass Nice!
- For Sale 1970-1 AC/Heater and defroster faceplate Extremely Nice!
- For sale 1970 Power lock switches Nice!
- 1964 custom steering wheel FS
- For Sale 1970 Console Wiring Harness
- OEM GM Fenders & Quarters for A Body
- For Sale 70 to 72 Cutlass Rear Window Defogger and harness
- Various parts 70-72...
- 68-72 convertible rear seat core
- 70-72 drivers side mirror
- 70-72 console
- Mickey Thompson aluminum valve covers
- 65 oldsmobile cutlass air cleaner
- 70-72 GM cutlass 442 fenders
- Exhaust manifolds, 1980’s
