James - Hilarious, do you wear that cap daily, or is it only for special occasions.
I wear ball caps all the time, and have way too many, but here are a couple of my favorites right now.
My 442 plate
My 442 driving cap
My favorite "everyday" kickin around cap
My 442 plate
My 442 driving cap
Good morning guys,
Generally just nasty out right now at 36 degrees and rain at 0700. Periods of showers are forecast throughout the day and it's only supposed to get up to around 44. Another beautiful day!
Hey, have any of you guys ever used one of the valve type oil drain plugs (pic). Thinking about possibly getting one for my 442. You never know how much wear and tear there might be on the old oil pan threads, and I was thinking getting one of these might alleviate those worries. Like Ron Popeille said, "Just set it, and forget it", unless of course the valves are prone to leakage, and then you're pissed off at throwing $26 out the window.
Hope everyone has a great day and that at least some of you are enjoying prettier weather than we are!
Hi everyone.
Interesting day at work. About 730 most of the lights went out. With no windows it was fairly dark in the shop. They were out for 3 hours. I kept working, as I had a hand held spotlight at my machine, but the inspector said no, need background light. He looked up the light requirements and it said flashlights, hand held lights, etc, were secondary. So I stopped. The PITA lead came over and asked why we stopped working. Can't inspect in the dark. He tried to bully us into working with flashlights but the inspector showed him the reference. Lead brought over an LED spot and said can you make this work? We taped it to the beam overhead and then used the spotlight, and the inspector said that was okay. We were at a severely reduced output, and besides that the tire retriever didn't have power and the assemblies couldn't be built. The power to the retriever came on with our lights but the front was building wheels in the dark. Not a good idea, but I have a feeling the bad lead pushed our lead into doing it. The almighty number is more important than safety.
So after work Tiger and I went to get the battery for the Saturn. I'll put it in tomorrow. It was about half what it would have been at the auto parts store. A friend of mine turned me onto this place years ago.
Chris, haven't you changed oil in your car yet? There isn't any part more lubricated on a car than the oil plug threads. Maybe the oil pump. If the plug runs in and out smoothly I'd leave it. It would make a good day bad if that valve ever started leaking and the engine started knocking before you realized. My two cents.
I'll probably hit the sack early, just because. Hump Day tomorrow. While driving this afternoon I honestly couldn't remember if I'd worked one day or two. My brain is fried.
Okay have a good evening everyone.
Hi everyone.
Maybe you misunderstood the scenario I wrote about above? I fixed the oil drain issue I was having on our daily driver. I am suggesting the possibility of putting one of those valves on my 53-year old 442. I agree the oil drain threads and the plug are well lubed, but if the car has the original pan on it, which I believe it has, the threads in the pan have to be worn and could fail even if the plug isn't torqued all the way down to specification. I agree you could also have an issue if the valve fails or leaks, but that's what I'm asking is if anyone has any real world experience using one, and how reliable it might be over time? Thanks for your opinion of what you'd do!
Yes Chris, the threads can and do go bad in oil pans. I understand your point. I've never had a problem with the Olds or really any of the vehicles I've owned except for the '85 Ford 300 that's in my 56 F100. It did strip out the oil pan. Oversize plugs are available, but once you do that you cant go back of course. I would be worried about that valve you show, I'd be worried of it opening or getting hit since it would be lower.
Norm I don't know what they have but the entire place wasn't out, just most of TOC 3. About every fourth light worked so we weren't in darkness, but it was too dark to work safely. Apparently something in a junction box let loose last night and they fixed it, but not good enough, as it either went bad again or made something else go bad. Fourth or fifth information by the time it got to me. The original hangar was built in 1960. The big second one was built in the 60s/70s, and the third one, where I work, was built in the 80s. Maybe alternative power/generators hadn't been invented yet.
Chris I did get what you were saying. I was just giving you my opinion. I have valves similar to that on my big truck that supply the glad hands, and I'm forever trying to get them to close completely. Sometimes I'll start it up and get the low air warning because the glad hands have let all the air out of the tank. Air is one thing, motor oil is another...
Okay its close enough to 8 I'm turning in. I forgot I had to put this mousse stuff on Tiger's bad skin. It was part of the shampoo package. It was not as easy as one might think. Trying to get Tiger to do something he doesn't want to is like working with a toddler. He'll squirm and twist every way except where you want him to.
Okay good night everyone.
Thanks Kenneth, I really appreciate you guys' thoughts and opinions. You've all convinced me the valve option is not the way to go. I'll just have to be careful not to over torque a standard plug and hope for the best.
Well I've been leaving the pic comments to myself till now.... Oh my goodness- that one is perfect or too perfect in my book. I wonder if that is photo shopped?? Ok, back to looking at cars....
Good friend of mine fell the day before yesterday and got mucked up. He is always such a helpful guy and is always doing something for his friends, He went up on a ladder with a big leaf blower on his back (Big one). I think he was blowing leaves and pine needles off neighbors roof. I can't imagine he would go all the way on the roof but I don't know for sure, I never thought of him as being careless or a dare devil type,,,, Anyway he fell off the ladder and broke 6 ribs- 2 in 2 places, broke his pelvis and punctured a lung. He was alone but luckily didn't pass out and he called the neighbor who came right over and called 911. He was in the hospital all day yesterday and this morning they are supposed to cut him open and put pins in the ribs and attend to the punctured lung. WOW!! Be careful guys! We aren't as young as we used to be. I am sure he will survive this fall but I'm not sure he will be the same again. He is 68-69 years old.
[QUOTE=Greg Rogers;1289570]Good friend of mine fell the day before yesterday and got mucked up.
Greg - Sorry to hear about your friend's accident, it sounds horrible and painful! We'll say a prayer for him. You're right, we're not get any younger and it sucks!
Greg, I hate ta brake it to ya but ladies what pose fer pics like this expect comments
I was once at a mall and saw a girl wearing a t-shirt that said "Guess:" so I said "Implants" and she slapped me. My long awaited point is, I don't think photochopshop but I do think boob job
Hi everyone.
Work was good today. The lights stayed on, the bad lead kept to himself. We finished before 11. I took an extended lunch but then we stayed until 215. That's because my lead wasn't there.
Greg hope your friend is gonna be okay. I saw one of those meme pictures on facebook that said the number one reason for old men to get hurt was because they still think they are young men. It was meant to be funny but boy is it the truth. I still get up on the house to clean the gutters and do roof maintenance. I probably shouldn't.
Jamesbo how is the boat house? Is your lake private for the people who live on it or is it owned by the state?
Rain this morning, but it cleared up and lots of rain this evening. Hope it's quiet rain, but we're supposed to have wind as well. That isn't quiet. We'll see. I don't know when it's supposed to start. Probably right as I'm going to bed.
Okay have a good evening everyone. Two more to go.
Mike, the lake is owned and controlled by Georgia Power It's not private but they [somewhat] limit access by not allowing any boat with a head or a galley.
So there's no overnite boats or island camping
My main man's wife had some emergency surgery, so the boat house is painted but still waiting for facial, soffits, and batting
Good morning guys,
Our dogs got me up at 0430 this morning to go outside. Momma probably did not make them go out before bed because of heavy thunderstorms. I couldn't go back to sleep so one of the dogs and I are just reclining on the couch. We're in our 4th straight day of showers and thunderstorms forecast throughout the day. We're starting to see localized flooding and one of the two ways out of our subdivision to the closest main road is under water at one point. Luckily the other route rarely ever floods. This wet pattern is finally supposed to break tomorrow and we're supposed to get a good stretch of sunny, nice fall weather through next week, although one night it's supposed to dip into the high 20's.
No big plans for today, mainly due to this crappy weather. Starting to get a little stir crazy being stuck inside, but that should end tomorrow. Hope everyone has a great day!
Dan, we're supposed to have clear skies all day/night Saturday & I'm hopeful for a nice moon rise. I'm anticipating a low Trick Or Treat bugger turnout nation wide this year w/ the pandemic I suspect. We never get any because of our location - too much traffic directly in front of the house.
Hi everyone.
Did 100 wheels like nothing today, saw my lead headed out the door and he said, if you want to go home now I'm good with it. So I split and was home by a quarter to 12. Ate my lunch with Tiger.
Got quite a bit of rain last night, and probably wind though I didn't hear it. The streets were covered in pine needles and branches. My yard looks okay, I'm gonna go to the shop a little later and see what's going on over there. Nice out now, a little bit of sun and blue sky.
Well I'm gonna take advantage of a couple extra hours. Catch up with everyone later.
James - Glad to hear you're ok! Sorry to hear about the loss of your trees. I'm glad all your buildings were spared. Must have been some hellacious winds! Have you seen or heard of other substantial damage in your immediate area, and do you have power?
Lost power for about 4 hours, then it turned into a bluebird day Only alot of roads were blocked with downed trees/power lines
I have some friends far away in other areas of the city 1[ had a tree wipe out 3/4 of her house and 2] another [ in the city[ neighbors house got flattened by an oak
Turned into a right nice day. Gonna be nice but a little chilly this weekend. I need to clean out the gutters, again, I did it not too long ago but they are full of needles and leaves after last night.
I would love to have a tornado room in my house, but it isn't really set up for something like that, with the walk out basement. Without digging a giant hole in the yard some part of it would be sticking out of the ground. So here's a question for anyone who would know, if I got a prefabbed something(like a shipping container or fiberglass "bomb shelter" or built a block room and attached it to my basement, how much of it could protrude above ground and still be safe from a tornado/wind event? Would a tornado pull it out of the ground? Not sure a 20ft shipping container would be picked up and thrown around like Dorothy's house but it might tumble a couple times, they are about 9ft tall.
Coyotes in the area. People are saying watch out for your cats and small dogs. Boy I wouldn't want a coyote to come around with my big dog. That wouldn't end well for either one of them. On the one hand I have trouble with people putting out poison and shooting them, they are critters that just want to eat. But on the other hand if they are threatening my dog or my home, or me, then they must go. So much construction around their homes are done away with and they don't know what to do. Not their fault. I guess that's progress.
We get coyotes in my neighborhood all the time. They cruise through looking for stuff to eat such as house cats that are left out at night. I have found numerous cat carcasses when walking the dogs. One was a declawed cat. I just can't imagine letting a declawed cat roam the neighborhood, especially at night, as it would be unable to climb a tree to get away from danger. Anyway, I'd post pictures but that may make some people uneasy and others start sending me hate mail
