I see. Ok, I have another idea. In the spring, drive somewhere open and get the noise to occur, then put it in neutral and kill the engine while rolling at speed. If it's an exhaust noise, it should not be there anymore. If it is a rolling gear noise, it still will be there. I am under the opinion, based on your latest comment, that it is exhaust related. Also, try, when cruising, and slowing down to turn off the road, drop it into second. The engine will rev up and you will engine brake. See if the sound it makes then is a louder version of your problem noise. If so, I think you just have an exhaust artifact in that specific condition.
The rubber on OEM control arms is fused to both the inner and outer sleeves. The inner sleeve is pinched between the frame mounting flanges, and as such it is held immobile. The rubber allows only a limited amount or rotation, which is why the bushings need to be torqued while at ride height. Aftermarket poly bushings are not fused to the sleeves, and as such they can move through a larger arc of rotation. They also can squeak due to the poly material, which is why silicone grease is used during installation and periodically through the Zerks.
Chris - As you recall my initial postulate (which I validated when asking you) related to a muffler noise during deceleration & you agreed (in general at any rate). Lots of good suggestions (including turning up the radio), but I wanted to address your last statement which you made also some time ago.
That notion/theory/idea is fine but difficult to evaluate because it's difficult to address the exact same road/driving/heat conditions by banging with your hand and/or rubber mallet on a muffler which is not running under pressure (or lack of) and most likely the same amount of heat on muffler(s) at driving speeds. All good thoughts/suggestions/ideas. Time for a trade-in?
I began to question that theory when I could not get either muffler to rattle at all by banging on it with my hand or rubber mallet.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
OEM rubber bushings do not need to be greased. Control arms with grease Zerks typically have polyurethane bushings and use silicone grease to prevent them from squeaking.
That notion/theory/idea is fine but difficult to evaluate because it's difficult to address the exact same road/driving/heat conditions by banging with your hand and/or rubber mallet on a muffler which is not running under pressure (or lack of) and most likely the same amount of heat on muffler(s) at driving speeds. All good thoughts/suggestions/ideas. Time for a trade-in?![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
Man, as I sit here at my desk, drowning under "paper"work, I envy you retired bastards (no offense intended, this is me being funny) that have time to crawl around under cars, do home maintenance, or whatever else you want (or need) to do. Unfortunately for me, I was not one of the $1M winners in MI for the latest lottery draw.
I think we signed over 100 wheels today, so not a bad day, considering the retriever was broke all day. I'll bet Brandon is beat. Some of the tires are bigger than he is.
Chris does it make the noise when you floor it and the back wheels are smoking and spinning? Better try that test a couple times.
So I need to move the Mercedes. That car hasn't been looked at in months. Of course it was dead. Tried jumper cables and nada. Is there a way to de-resistance jumper cables? They are older than I am. I think I'm going to donate that car. I knew better than to buy it and I did anyway. I think I've driven it a total of 4 times, bought new tires for it, and then decided I hated it and left it set. Not the brightest thing to do. But I'm over it and just want it gone. By the way, when painter's tape says to take it off before 30 days, believe it.
Hump Day tomorrow. Wouldn't mind it.
John - Gotcha, that makes sense. The part that is concerning to me is that the noise wasn't there before, and I'm hoping it isn't an initial sign of some significant part/system failing down the road. Other than the noise, the car still runs great, and like I've said the noise is not very noticeable and I could live with it as long as it isn't leading to some major failure down the road.
Thanks Greg, we are deeply saddened by the sudden loss of our Vet. She was a great Vet, and an even more wonderful person. I already had a discussion with Dawn about the luncheon for her brother. I carefully asked her to please never organize something like that for me if I ever get really sick and explained why. She said she never really thought about it that way, but understood how I, or possibly he, could feel that way. Yep, things certainly can get complicated!
Kenneth - I think I agree w/ you - it isn't the first time someone has informed me of the exact same thing. I'm unclear why their point has never sunk in w/ me.
Tee-time 8:16am. Mild winds 4pmh - 7mph, low 70°F.
Good morning everyone.
Slow morning. No one is in a hurry and it doesn't look like there is a dedicated tire fetcher. Apparently Brandon was pissed that he was the only one yesterday and stayed home today.
Was a beautiful day yesterday and is supposed to be again today. Rain tonight and tomorrow. I'm moving to the desert.
Hope everyone has a great day.
Yeah, I have my own set of clubs, but only have been on 3 courses, all within a weekend of a golf trip a few years ago. We have one of those Top Golf facilities just across the expressway here at work (Auburn Hills, MI). I did a league there a few years ago, with zero previous experience, and decided it was something I'd like to pick up.
Well traffic on the way to work this morning was terrible. I think it was due to that golf thing up in Scottsdale, and it's prolly gonna get worse as there's some sort of football thing with a lot of activities this week and weekend. I am sooooo glad I live on the opposite side of town from all of that.
Oh Man, I got my wheels painted- what a fiasco. Everything that could go bad did... That's enuff for me with auto painting. Trying a new hobby at 66 is too much ( auto body) , I am going to farm out painting from now on. I'm gonna put some pics on my thread under painting.
Slow all day. I left at noon to meet my trucker man. I don't remember if I mentioned an Imperial in Virginia a little while ago. I sent the guy the money and hired a trucking outfit to drag it down here. So it's here and I love it. I'll work on a picture.
Greg some years ago Sandy wanted to paint the wheels on her car. She took them to a body shop and agonized over which shade of green she needed. The car was painted previously with a non-Olds color that was still pretty close. I seem to remember the wheels came out a near match and she was rather happy. I'm usually happy with a rattle can.
Jeff, since you work in Auburn Hills, do you ever go past the Chrysler complex? Is the museum building still there? I know they did away with the museum cars and whatnot. What a shame, beautiful collection.
Mike - Glad it got there safely and that you love it! If you can, give us several pics, exterior, interior, engine bay, please?
Mike, i heard that they re opened the museum @ Chrysler. Maybe in a new location? Article from 2018:https://www.autoblog.com/2018/03/21/...RpGMc8Dk-1PXF9
Retriever still broke, everyone still slow. The lead is here today(he wasn't yesterday) but he has yet to squawk about it. That's okay, I got lots of internet looking to do.
[Bad attempt at posting a picture]
Jamesbo the Executive Director Imperial was only in 67. But this car does have the little foot cushions on the floor in the back seat. Like a Rolls Royce.
Dan I hadn't heard the museum was opening again. That's cool that it's in the Viper factory. If I'm ever up there again I'll check it out. I really liked the other museum.
Gotta take Mom to the doctor after work. Then clean house some more for the arrival of my sister and company. Fun times. Supposed to rain today but so far nada.
Have a good day everyone.
Mike - You could send me the image(s) & I can post it/them for you (if you like).
normg@normg.com
or
vintagechief@beaufort-by-the-sea.com
normg@normg.com
or
