kids helping with project
So my boys and girls are going to do there first compression test this week if I can get the motor set up lol
Garage is kinda Tight these days but hopefully I can have some fun with the kids next week
Lol they don't want the zoo they had a year pass and my wife took them once a week for a year . Well almost every week
I am planning to let each kid do 1 cylinder and push the starter button while checking it should be fun !!!
This is the motor that came with my trans and my buddy that rebuilt my trans said "it was in very good condition" only thing he found bad was a age crack in the 2 1 band but it had plenty of material left.
So I am very excited that the motor should be in the same condition.
Well I pulled the motor and installed a starter but dang my luck starter must be bad just smokes at the battery when I jump the power to the a terminal
Thank you for the offer very kind of you
The four kids helping pulling the intake I need to go and grab kid safety glasses mine kept falling off the so no air tools tonight lol
Any ways looks okay some of the valves look rusted shut so hopefully when I pull the heads maybe it will turn over this is the one that was locked up but claimed running when pulled
Well the boys and I pulled the heads off tonight.
Man I think this locked up block had low miles on it no real lip at the top of the cylinder in the block but water got into three cylinders at some point
Seems like a bit of slugs too hard oil deposit
Well I am going to soak the cylinders for a few day maybe mix it up from oil to pb blaster
If it ends up being a no go what's the best way to pull crank and pistons ? I don't care about them just the block
Oh yeah this block had never been into it I would think. It had no manifold gaskets and the bolt locker thing in them
And every bolt broke loose fairly easily
Thinking of letting the kids pull a set by them selfs seems easy enough good project for tonight with the little ones I think
Okay guys ran into a snag I can't rotate and I can only get to a few of the rod caps so how do I remove crank and pistons ?
Also what dies the big N stand for on the crank
Okay got crank out and all but two pistons. I can move the two down ,but not up and out should I leave them for the shop or just beat them out because I buying new pistons any ways ?
The two pistons are rusted in the two cylinders had water in them . This looks to be a very low mileage motor to me there was no lip at the top of the cylinder the 6 pistons I tapped out very easily
The two locked pistons cylinders looks like the rust isn't deep at all maybe I might not need to bore after all
He is the one that told me to tear it down and mark it it will save you some $$$ I know some shops gate this do I was shocked to hear him suggest it
My little helper helping me put together the new hoist most likely the only time in its life that it will be in the living room lol
Okay dropped block crank and my ka heads off today.
talked with the owner he did a quick check and the cylinders only had .002 of wear, he said "he could clean up the rusted cylinders with .010 bore " my crank was standard on rods and main he looked shocked with the numbers but still needs to clean and check properly for final numbers
Just linking a engine build to my project build hope to get more attention on the engine as I think my build doesn't catch slot if the engine builders
https://classicoldsmobile.com/forums...086#post647086
Stripped and worked out most of that dent on the front there
Learned how to file the metal work used a flat file to slap out the dent then after used a file to find low spots
Need to weld up the f85 badge holes and metal work a bit more for prime
Alright moving this along, I sealed the deal on painting this puppy should be around May. Work approved to let me use the paint booth and made a deal with the paint vender and one of our painters. So excited just a ton of block and prep work to be done!
Also should be gathering some parts for the 455 in the next few weeks, I should have all the parts to build a nice street monster just have to work the machine work in between the lines lol
Filled in the antenna hole today hope to prime by next week and start the left fender next .
looking good.. love the kids helping... i am starting a build with my daughter on a car just like the one i brought her home from the hospital in (64 f85 wagon).. my girl is a bit older but still my baby and i will be happy with spending the time with her like you are with yours.. i will subscribe to this thread and keep a eye on ya..
I really like when they help it has been hit and miss when they do , but they love it for about a hr ( 3&4year old ) then they get inpatient. My older kids (16&14yearold) like the idea of it but hate the work part lol . And my two middle(7&8year old ) kids just eat it up.
But I do have to say the co worker that has been helping me with the body work has been great almost like a dad teaching. I ve learned a lot from him.
I will try and keep a eye out for your build. I love wagons and being a 64 is just great
Got all the surface rust from inside the fender today primer tomorrow than blocking.
Metal worked the whole fender no filler at all using a good filling primer and starting the left soon
Sanded the fender with 120 with the D.A and primed today !!
Nice to start the left
I didn't know how to turn on the booth lights do I will get a better pic tomorrow
Left fender started
Stripped and working on dents
File slapping
This fender will need some heat to shrink the metal down
File slapping
