kids helping with project
Old Nov 9, 2013 | 08:36 AM
  #161
oldstata's Avatar
Justin
We are using it current shape to shape the new metal and we have a tool that beds a 1/4 so we lap it around edges only not the whole section if I understand what you mean
Edit on the trunk pan we did over lap about a 1/2 inch there was a indent in the new pan that it lined up to and sat flush so we figured that's how it was to be done.
My buddy has 30 years in collision repair this has been a learning experience for the both of us
Old Nov 9, 2013 | 03:49 PM
  #162
oldstata's Avatar
Justin
Thanks 2blu442 for this pic this is the rear quarter trim
This is the same gap I had after fitting left patch looks to be a factory gap maybe for draining
Old Nov 9, 2013 | 08:16 PM
  #163
MX442's Avatar
Originally Posted by oldstata
Quarter patch almost done
I thought this looked like it was going to be a lap weld across the QP vs. a butt weld.
Old Nov 9, 2013 | 08:35 PM
  #164
oldstata's Avatar
Justin
Your right it was to make the shape we needed orig was smashed in so we got close looking on the other quarter
Edit: thought I would add this was made from a door skin from a lower section of a four door from a 64 .I did not weld this section.I glued it with the body glue . It holds better than a weld from the studies as it has anti rust stuff so in theory it shouldn't rust
Old Nov 11, 2013 | 07:43 AM
  #165
oldstata's Avatar
Justin
More pics
Old Nov 13, 2013 | 07:04 AM
  #166
oldstata's Avatar
Justin
Man I looked like a smurf after sanding the first coat of paint off yesterday
Old Nov 14, 2013 | 06:00 PM
  #167
oldstata's Avatar
Justin
Here is a pic of the inside the patch you can see the fold to set the patch flush
Left quarter done block sanding just need my buddy to do a once over to check my work
Started the door today
Old Nov 15, 2013 | 05:36 PM
  #168
oldstata's Avatar
Justin
So right rear quarter we are using a front fender to make the lip area this is kinda cool wish I would of started with this side it drops down just a inch or so would if been cool to add my touch
Any ways we cut it off
We had to cut it pull the lower section up to make it tight
Old Nov 15, 2013 | 05:50 PM
  #169
One word... wow!
Old Nov 15, 2013 | 07:42 PM
  #170
oldstata's Avatar
Justin
Thanks !! The owner of the dealer ship saw it stopped him cold in his tracks !! His son witch is the general manager started saying dad don't ask questions that's your Xmas present . The owner didn't look to happy, but when they said no it's a employee and he bit off more than he could chew so a few of the body guys are helping him out.
All I have to say is.
I work for a great company and my co workers really have made this a smooth process and the brownies and soda left in tool boxes will never be enough
Old Nov 16, 2013 | 11:04 AM
  #171
oldstata's Avatar
Justin
A few pits just need to hit it with sand and braze fill any holes
Old Nov 16, 2013 | 12:36 PM
  #172
oldsguybry's Avatar
NOVICE car nut
Wow , you really have your work cut out for you ..... When are you going to start on my car ?
What your doing is a great idea for the sheet metal replacement . I thought I would have to get a donor car to get some of these areas replaced on my car , but shaping the new metal over the existing metal is a good idea . I never thought of doing that . Correct me if I'm wrong because I'm a noob with all this .
Old Nov 16, 2013 | 02:00 PM
  #173
oldstata's Avatar
Justin
This is exactly what we are doing we used old car metal for the most part.
We used a section of the front fender, but I think it might be a toss up of just using a section of flat and cutting a arch shape and adjusting from there.
I have been lucky learning from a great collision body guy.
Some would say how we glued the sections in is cutting corners, this I am tossed I would of rather welded, but with what I have learned about fusion glue, I think it will last longer
At times we have had half the shop watching and learning .
I shaped my first part yesterday . I adjusted that thing for a half hr before I was happy, my friend on the other hand tap here and there and done every hr he puts in it is like ten of mine lol
I try and take as many pics as possible I just wish I had better writing skills
Old Nov 16, 2013 | 02:40 PM
  #174
Your writing skills are fine. I worked at dealerships for a great many years and the guys in the shop had always been helpful. You have just have to help them out every now and then.
Old Nov 18, 2013 | 05:02 PM
  #175
oldstata's Avatar
Justin
Okay really near finishing up the shell . So I started to work the wife over rebuilding the 455 so, I need some advise I have two 455 one is said to be good running condition oil still in the pan dirty but looks good the other is locked up.
So the plan was stuff the good one in and take my time rebuilding the locked up one. Now that I am getting ready to switch to drive train I am wondering if I should just build it once and be done ?? It does run currently with the 330
Old Nov 19, 2013 | 05:46 PM
  #176
oldstata's Avatar
Justin
So here is what we got
Just need to get straight edge lines and cut out old
Old Nov 20, 2013 | 05:51 PM
  #177
oldstata's Avatar
Justin
So sanded most of the right quarter and wow people are lazy !! Four or five dents hiding with bondo. I swear they spend more time filling and sanding then what it would of taken to just hit them out from the trunk side.
Old Nov 21, 2013 | 06:43 PM
  #178
oldstata's Avatar
Justin
Old Nov 21, 2013 | 07:02 PM
  #179
I am so glad I live in the south, we hardly ever get anything that bad. On the 455, it's a tough call on what to do. Me personally I would rather swap engines once.
Old Nov 21, 2013 | 07:55 PM
  #180
oldstata's Avatar
Justin
This is a good one lol and I live in a said desert state just not far enough south lol
Yes, one day some one is going to be posting" look at this crappy patch work " most metal has been from the left&right front fender and some scrap doors the outter wheel well was rusted out didn't plan on that so I took the upper section of the fender to do a patch won't be pretty, but at least there won't be rust
Old Nov 22, 2013 | 06:31 PM
  #181
oldstata's Avatar
Justin
Okay so the goal is one week to get the shell ready for primer
Here is the outter wheel well patch
Old Nov 26, 2013 | 05:00 PM
  #182
oldstata's Avatar
Justin
Okay the metal master at work heating and pushing the metal for in wheel well patch
Here we welded the patch into one part
Right front fender replaced
Old Nov 27, 2013 | 04:53 PM
  #183
oldstata's Avatar
Justin
Welded in the wheel well patch today just need to double check the quarter patch and hopefully glue and a skin of filler and DA and a bit of block work to get some primer on tell spring time over the winter I will be installing the disk conversion maybe a posi and depending on funds trans and drive line
Old Dec 2, 2013 | 05:04 PM
  #184
oldstata's Avatar
Justin
Inside wheel well patch
Old Dec 4, 2013 | 11:17 AM
  #185
oldstata's Avatar
Justin
Old Dec 4, 2013 | 04:22 PM
  #186
oldstata's Avatar
Justin
Fun begins block work
Old Dec 4, 2013 | 05:12 PM
  #187
Sampson's Avatar
Somewhere above Eric said it all!
Double Wow!
It had been a while since I had seen your project. Nice work! You have come a long way.
Old Dec 4, 2013 | 08:49 PM
  #188
oldstata's Avatar
Justin
Double Wow!
Thank you !!!
As Eric has stated. I have some real talent helping me we work on this about four hrs a week some times more if he is waiting on parts or slow .
Old Dec 8, 2013 | 09:00 AM
  #189
oldstata's Avatar
Justin
Well it's winter here, just shy of a foot of snow out side hopefully the roads dry out so I can tow (Betty )) home for her winter sleep
Old Dec 10, 2013 | 08:24 AM
  #190
oldstata's Avatar
Justin
Old Dec 11, 2013 | 04:51 PM
  #191
oldstata's Avatar
Justin
Old Dec 12, 2013 | 08:18 AM
  #192
oldstata's Avatar
Justin
Well very excited!!! this car has came so far in a short time
Old Dec 12, 2013 | 08:37 AM
  #193
I still only have one word, your metal guy is an artist. Car came out great!
Old Dec 12, 2013 | 06:34 PM
  #194
oldstata's Avatar
Justin
So we had to push the old girl to the paint booth and man were those roots planted on that frame rack, my little gal of gas disappeared over the last two months.
Got some fresh gas two pumps and a jumper box she fired right up so I will be bringing it home sat.
My wife said I was like a little kid on Xmas eve waiting to open the night before present even tho it's just PJs lol
It kinda makes me sad to think of pulling that 330 it runs great a good reseal and it could go for ever
Old Dec 14, 2013 | 11:02 AM
  #195
oldstata's Avatar
Justin
Old Dec 14, 2013 | 03:27 PM
  #196
Sampson's Avatar
Very nice work! Looks very good.
Old Dec 14, 2013 | 06:37 PM
  #197
oldstata's Avatar
Justin
So, I been toying with the idea of shaving the antenna. on the fender and trying to find a after market window mount one what do you guys think ?
Old Dec 20, 2013 | 08:27 AM
  #198
gear head's Avatar
You've been a busy boy, the car looks good. Will it have color on it for spring?
Old Dec 20, 2013 | 08:49 AM
  #199
oldstata's Avatar
Justin
So this is a good question . I think it will depend on how much I can pull off on my motor build over the winter I am going to tear into one block and see what is needed and do a bench compression and leak down in my other block
So in the spring it will be paint or drive train not sure yet
Old Dec 20, 2013 | 11:14 AM
  #200
oldstata's Avatar
Justin
Trans pics th400
