kids helping with project
Okay I am starting to research cam kits any thoughts on this one ? It's a comp cam kit
Part: K42-208-4
Dual Energy™, 265DEH
Everyday Performance, Strong Mid-Range
keeping in mind this is a 71 455 with Ka heads and Edelbrock 2151 performer intake
Part: K42-208-4
Okay update
Started to work on drive train alittle a good friend has agreed to rebuild my th400 he has been a gm trans guy for 30 years . Best part is he is going to let me help !
Decided to wait on the cam tell I decide if I am going to go through the block . It is a running engine but I think it would be nice to put new bearings and higher compression pistons in while it's out ,and of corse the associated machine work needed
Okay I have a questions on the thorton manifolds ?
Should I go with the 65-68 or the 70- 72 does one flow better or is it just org factor I know that the 70-72 are a little cheaper. Okay after searching for a few hrs I think I might have answered the above question the later 70-72 wz. Manifold flow a bit better , but would still like to hear others opinion
Not much progress lately. It's been really cold and it seems my work space is shrinking . I did manage to sand plastics few parts this week
They should be painted by the end of the week if I can squeeze them in .
Also sent front eye brows and hood lip to be rechromed . I made a deal with them to squeeze them in when there slow and they would take 25% off the cost
Found something cool behind glove box
It has the dealer number and has the steal tags that they made I think to order the car has owner name address and vin plate too ?
Okay I had a interesting day. I found a ac compresser for a 72 delta 88 for free , but a hr away so I talked my self into going and getting it funny things is when I met up with the guy to get it . It was still attached to the 455 and th400 As I stumbled out what you looking to get out of the motor and trans ?? He said what you offering I said I have two hundred bucks that I been tucking away for a trip but , dout that will be enough. He said okay and loaded it into my truck was so happy I took the truck lol
Yes I was excited but it does have the Ga heads he swapped it out for a sbc to take to the durby
It even has the oe starter I believe. it's painted blue
Claimed it was running it turned over freely was stored in a shop .
My plans are to drop this in while I put the time and money into my 71 block
Okay , so I learned how to braze today ! there was a few cracks on the trim peice that go from fender / head light bezel . All sand blasted and ready for primer and prep for paint .
It was kind of fun working with a friend showing me a few body tricks
Okay finished up sand blasting wheel well tonight . I forgot the camera at work ,so can't upload the pics but should be painted quickly so excited !! decided to go charcoal with a flat clear on wheel well and fire wall as well as cor support
Now to pull the condenser and radiator from cor support so I can try and fix the bad repair from the past .
Looks good! Nice thing about metal liners is they're a lot easier to restore than plastic ones. More pics of the work you did the other day......with the brazing and wheel!!!
BTW, really nice score on that engine / tranny.
I will have to see if my painter primed yet. I did not take pics if the braze work but ,it was very small maybe two spots less then a inch on both spots
The wheel wells absolutely sucked to sand blast I think after two showers I still feel like I got stuck in a sand storm !
Before
Before
Started to test fit fenders today and ordered a lot of parts
Radiator and tubular control arms ouch !! That hurt also found a 70 12 bolt olds rear end non posi 3.23 made arrangements today to pick up next weekend (if he don't leave on biz if so three weeks out ) 5D887F21-B2C9-443F-8CFD-CED11D1927C0-4991-000005256F3E1A4D.jpg
Just a random pic
Just a random pic
Hey Allen these are sand blasted and where the grind marks are is where the repair were sorry not the best pics
You can see the brass in some of the pics
Hope you like them
Okay ordered some more parts today plan on hitting this very hard in a few months
Trunk pan from fusik with a few rubber parts for bumpers
So my plan is drive train
New control arms 455 and trans pluse rear end to be installed
Need brake kit to finish up but as soon as the parts are installed then body off frame and dis assemble frame for sand blasting and por 15
Install trunk pan and left rear quarter maybe as winter hits again
Okay so I just bought a brake kit off of eBay but it's a name brand
The right stuff detailing
New with cross drilled rotors and braided brake line and powder coated calipers
All for 644 shipped to me
J, POR15 is NOT frame paint. It is paint designed to cover rust. If you are going to sandblast the frame, it will be the perfect candidate for epoxy primer and single stage black top coat. There is also specific chassis paint that is used in the semi-truck and farm tractor markets. I'm not sure what it is called.
The Right Stuff has a very good reputation on the forums. Front disk brakes is the best thing I did for my car.
Keep up the good work! At the rate you're going, you'll be cruising by summer time.
This is what I wanted I like the idea of epoxy and paint but ,, every one has
Told me to POR 15 I think your right , as well and I will stick to my guns on this. I was thinking powder coat but , kind of out of my budget the wife has been awesome on this so best not to push my luck lol
Yes it is also must be a early year I had two shoved through the glove box they were sitting on the heater one with the plates one with out .
One with plates match the vin My car they added a sticker to the back but the one that didn't belong to my car they added a page that said the same thing
Sticker added
Sticker added
Okay grabbed trans parts today hopefully start rebuild next week we will see how my buddy's schedule is went stock converter for now .
Control arms showed up today can't wait to get home and check them out
Got the right wheel well from prime today looks pretty good just need to finish up a few parts and lay paint
Got all brake parts today can't wait to put them on to just take off lol .
Picking up rear end tomorrow three hrs away 😱
Hopefully it warms up soon so I can start assembley if drive train just to disassemble for frame work.
Thinking of boxing sections of frame
Well got rear end this weekend but, ended up not being so cheap after all lost my trans in my truck 50 miles from pick up location. Luckily an old friend happen to be intown for a rc event and let me store my truck at his dad summer home tell we can drive back up to get it 😞
The wife said it must be a sign to pull the rains back on the project alittle and she most likely right .I been alittle over board lately.
So I been collecting tires from work to do burnouts in
Not counting my shed I am going to have a blast ten sets all 50% or better lol
I am a front end tech for a import dealer. started out repairing wrecked cars but , we deal with all wheel drive cars and when you blow a tire and it's not with in 3/32 of each other they need a whole set .So I begain grabbing all the17 and 18 and making complete sets out of them getting kind of hard to move around garage. So I think it's time to burn through some lol
Utah . I bought it in magna off a young guy that claimed he got from his grandfather. it had not been driven since 08 but, the title was from 82 and it was licensed in Ogden Utah the last thirty years .
the protector plate shows the original owner lived in Ogden as well but, can't seem to link the dealer number to a dealer ship to find out if they where located there as well .
So I have to say interesting things keep happening ?
So my trans went out in my truck wife said" you need to cut back on the project so I have not bought or worked on anything for the project .
Okay I work for a local dealer started out as Pontiac and buck in 2010 we lost Pontiac so the owner sold the franchise and turned the location to a Subaru dealer ship .
To day my service wrighter takes in a 68 Pontiac that the wiper washer don't work the tech working on it , I tell him there is a gasket kit that he needs to rebuild the pump later the owner of said car tell him put this used part on .
I ask the owner if I may keep the old one and he says if you can tell me what motor I have you can . so I scrap off some goo and find yc xxxxxxx I go to my trusty computer and bingo he had a pontiac 400 he was very pleased
He asked why do you want it I said mine is broken and I been looking for one but really was not high on my list
So I come home with it and told the wife the story and she says I think the car gods are looking out for you lol
So the wife thought our sons ride should match dads just missing 455 lol
So got out today and modified a old truck rack to be my body cart while it's off the frame.
