Guys posting about their engines
Old Sep 7, 2022 | 08:11 AM
  #201
CANADIANOLDS's Avatar
Originally Posted by RW Tech
Stock Eliminator is a general class,, with specific classes under it.. And yes I did give specifics of the truck combination and my part in it.
In an indirect way you are agreeing that the effects of using a halo girdle are not quantified, so back to you with "welcome to reality".
No, it’s called stock eliminator.
you didn’t give any specifics on what your role was in the engine…just tap dancing around and a poster with a thank you on it.
refresh my memory on your contribution…I can check it either way…so let’s hear it.
Old Sep 7, 2022 | 08:15 AM
  #202
RW Tech's Avatar
Originally Posted by New2oldsw30
Ya that's about what were doing Hp wise with 11.5 comp, 246 hyd roller and OEM intakes. BUT that was 7 yrs ago and since we have our own head casting for LS in either NA or forced induction, as well as SBc, Now working with the Gen III hemi guys.
https://www.youtube.com/watch?v=6xKSfANwc84&t=21s
https://www.youtube.com/watch?v=TJtHwejf_Ko
https://www.youtube.com/watch?v=GvbqzKwN5xg
All I'm seeing are cars on a rolling road dyno. Not sure about yours but around here it winds up being 70-ish HP from an engine dyno to a rolling road with same engine.
Have you actually ran any of those engines on an engine dyno?
Old Sep 7, 2022 | 08:22 AM
  #203
RW Tech's Avatar
Content definition, 3rd party sourcing, machining specifications, custom part drawings, complete engine assembly, engine dyno/calibration support, rapid deceleration testing, teardown analysis, rebuilds.
You good now?
Old Sep 7, 2022 | 09:22 AM
  #204
that is not a Halo girdle. Again, please try to keep up.
No kidding Einstein…my point was these were never designed using FEA. So what do we do? Try to keep up
Old Sep 7, 2022 | 09:40 AM
  #205
New2oldsw30's Avatar
YES we have, and usually were with 10Hp see as MUSTANG didn't even offer this dyno till Velocity help design it. I believe it is still the only one in North America. It built to Velocitys design and specs. Handle 3500WHP and runs over 250MPH. As software to give WHP and ENGINE Hp, drivetrain loss and even drag race ET. and is usually pretty accurate. vehicles in the world. Our dyno has the capability to dyno test rear wheel drive, front wheel drive and all wheel drive and can handle ANY vehicle that can be driven onto it.
Old Sep 7, 2022 | 09:47 AM
  #206
Now we are starting to agree. It may help, it may hurt, nobody knows for sure either way.
I know this doesn’t qualify as testing in your mind ,, but actually running these engines in a car at the strip where the engine mounts are being stressed under real world conditions while showing no fretting or signs of cap movement while keeping #4 main bearing looking like new…the Dyno, like your testing, can’t simulate stock motor mount location stresses…releasing trans brake or dumping the clutch is real world.
so I’ll scrap all that testing because you, want an FEA to prove its helping 🤣🤣🤣🤣🤣🤣
Old Sep 7, 2022 | 09:54 AM
  #207
I wonder if RW will bless us with one of his engines in this?,, since this is about engine builds.
I’ll bet every piece on it was thoroughly tested, with hundreds of hours at WOT throttle on the Dyno. FEA, NVH, and every other acronym.
Umm your RIGHT Dale! What block, rotating assembly that MUST use 8 CW, heads, intake, cam, lifters, spring, locks, retainer, pushrods and even SPARK PLUG have this all this 600 hrs destructive testing and full analytical report, to make a pump gas 455 OLD break 600Hp?????????
Make no mistake, RW is a smart guy and can build stuff by the looks of it. We as humble peasants need to be enlighten to this knowledge to make a mild 455 pump gas street strip engine a much much better piece.
Old Sep 7, 2022 | 09:58 AM
  #208
FEA
Dale, I was following along, and agreeing with some posts. BUT not really sure what FEA would really offer? Family Enterprise Advisor wouldn't know much about OLDS engine I fear:
https://familyenterprise.ca/fea-desi...IaAig9EALw_wcB
Old Sep 7, 2022 | 10:00 AM
  #209
And yes, I have been involved with FINITE element analysing when I was machining US nuclear sub reactor turbines.
Old Sep 7, 2022 | 11:10 AM
  #210
A light overview in this article:
https://www.off-road.com/trucks-4x4/...roject106.html
3.700" bore x 4.160" stroke, 8,000 peak RPM, 2,000 mile Baja 2000 winner in Trophy Truck class. Stock truck crank, Carillo rods, Cosworth pistons, "rubbed core" block, 1045 steel caps, stock bolts re-heat treated to 55 Kn, raised-port 32-valve heads, titanium valves, stock hewd bolts, knife-edged combustion sealing rings (same as BMW F1 4-cyl 1500 hp/98 cid) 5-stage dry sump, billet chain tensioner arms, polished chains, and something else for you to argue about and not believe even though it's true: Glacier-Vandervell bearings, clearances set to .0015" mains, .0009" rods.
thats some real special stuff right there,, going through the trouble of re heat treating stock main cap bolts down to 55kn 🤣🤣🤣
how long did it take you to “polish the chain” ? 🙄
were you working for Ford at the time you built this engine for the Truck?
Old Sep 7, 2022 | 11:12 AM
  #211
it may help him with getting his bullshit straight 😁
this guy is a piece of work. His name, Robin Wright does not come up anywhere in a Google search about this truck, or engine…or anything to do with it. Lots of other names, not his though.
a simple Google search shows Ford Motorsports built this truck engine in house. That’s why I asked if he worked for Ford back then and forgot.
just reading the specs he posted about the engine, you can tell he’s an internet blow hard..holy crap, take a read of that gem …polished chains? re heat treated factory bolts to 55kn? 😁
that’s what’s great about the internet, you can claim to be anyone you want..even superman.
Old Sep 7, 2022 | 11:26 AM
  #212
You're right about that, but it does help to have engineering expertise to determine whether the strength you are adding to one part of the structure is at the detriment of the other. That's my point.
if it was all as simple as you are saying it is then nobody would bother wasting their time on FDA and iterations of designs for those things on the OEM level. They do what they do because they found out that some designs actually make things worse.
yep, and when you are working on a 60’s cast block that has never been, or will ever be run through any FEA , you can’t begin to know where it needs or doesn’t need help.
it’s back too, where did it break, where did the damage occur, what do the bearing look like and why?
the you go from there and use simple logic. This started out as is there any benefit of a halo on top of stock caps. That’s a given considering the soft iron caps have a very small contact area top and bottom. Simple straps and ARP studs/washers help a bunch up top to prevent the cap from crushing of time and losing the clamping force.
stock cranks do move around quite a bit which puts lateral loading at the top of the main cap for and aft…that’s where bracing all the tops together with a halo has a benefit.
the argument has always been it’s a stupid idea because it offers little or no additional clamping load directly through stud to the main saddle..which is true in a sense. But that’s not it’s intended purpose, so that argument isn’t valid.
for what John is doing..ARP studs/washers and the halo will provide additional support and give the bearings longer life
Old Sep 7, 2022 | 12:09 PM
  #213
Thanks Dale. THAT WAS THE POINT. For what WE are doing, and most here, the studs/washer PLUS Halo should help on these dinosaurs that MIGHT see 6000RPM's? And for how long does a street stipe deal that shifts @ 6000 or even say 6300 really in the range where **** moves.
As you can see, I'm trying to learn these OLDS deals. Got a good handle on other stuff and IF just IF I can get 75% of the reliability the other stuff has, I will be a happy camper.
Old Sep 7, 2022 | 12:27 PM
  #214
RW Tech's Avatar
🙄 I've seen fretting go away when stock main bolts are put back in instead of aftermarket stuff, and countless numbers of times I've heard "exactly the same as before except for one change" when bunches of changes were actually made.
Old Sep 7, 2022 | 12:38 PM
  #215
RW Tech's Avatar
You're a mongoloid. I worked in experimental engine at Ford for 7 years...and worked with Jeff Lyjak & George Frame (both tech specialists) on this project. If you happen to deal with Stef's you can tell Joe that you were talking to an online bullshitter named Robin Wright who said he worked on this thing & let him tell you whether I'm full of **** or not.
You may also want to Google "Rob Wright", and don't be surprised if you get hits from 2011-2015 about a racing-related project at a different place than Ford.
Old Sep 7, 2022 | 12:41 PM
  #216
Countless times? keep digging….I don’t know how you’ll ever get out of the hole you’re in now.
wanna explain the reduction to 55kn of the factory bolts? My wood fence here has higher rated bolts than that
The chain polishing is the other neat trick…😁 I’m sure you did back to back tests to prove the gains were worth it.
and why would Ford Motorsports farm out all the engine building to you when they actually built the whole thing in house?
Old Sep 7, 2022 | 12:45 PM
  #217
RW Tech's Avatar
Man you are incredibly stupid. Cap bolt re-heat treat moved them UP to 55 Kn strength, not down.
Considering the primary chain tensioners having nylon surfaces that chains slide against, and considering the race was 2,000 continuous miles, with engine peaking at about 8-grand, why do you suppose we had the outside surfaces of the chains polished?
Old Sep 7, 2022 | 12:47 PM
  #218
rickw30's Avatar
I just can't see how this doesn't help !
Old Sep 7, 2022 | 12:48 PM
  #219
RW, did you work with or around "FAST" Eddie lyons?? Head of Ford SVO department? We raced against him in S/E and Pro Dragsters with his 600 inch nitrous Hemi Ford.
  #220
whats 55kn convert too?
Old Sep 7, 2022 | 12:51 PM
  #221
RW Tech's Avatar
Again, you're incredibly stupid. This wasn't "Ford Motorsports" as a knuckle-dragger like you would know it, this was Ford Truck Motorsports, and the engine was done in-house.
Honestly, the way you act makes me believe that you see what I'm saying about cranks/dampers/girdles as a threat to one of your revenue streams. Is that what is actually going on here?
Old Sep 7, 2022 | 12:53 PM
  #222
im not googling anything more. You do it, post it here, maybe I’ll change my mind.
Post it up, I’m interested
  #223
RW Tech's Avatar
12,364 lbs of force.
Old Sep 7, 2022 | 01:01 PM
  #224
RW Tech's Avatar
Hopefully your reading comprehension is strong enough to get you through this:
https://hotrodenginetech.com/holley-...-copo-camaros/
  #225
Post it up, words are cheep. Ah ok, Ford “truck” Motorsports…not Ford Motorsports. Ya got me there.
so now you’re here, hanging around an Olds forum telling us we don’t know **** because an FE analysis hasn’t been done on anything we use.
screw that..because you can’t for the reasons I mentioned which you cant deny. Keep ranting about it anyway.
Old Sep 7, 2022 | 01:04 PM
  #226
RW Tech's Avatar
That group had nothing to do with this, since it was not "Ford Motorsports" who commissioned it. This was Ford Powertrain Engineering, working with Ford Truck Motorsports. Different groups.
Old Sep 7, 2022 | 01:10 PM
  #227
ill read if you tell me what I’m suppose to read,,there’s a whole pile of articles in that link..which one?
Old Sep 7, 2022 | 01:17 PM
  #228
RW Tech's Avatar
Yep, you really are that dumb..I didn't tell anyone they didn't know ***** you did.
What I did say, before you went on your emotional thinking blitz, is that halo girdles may or may not work, and in some cases they can make things worse.
I also said that a properly designed & processed 8-cwt crank can make problems like broken blocks go away.
Since then you've picked & poked & jabbed so it really does make me think that my saying what I am saying, and you reacting the way that you have, is threatening one of your revenue streams. Is that what's really going on here?
Old Sep 7, 2022 | 01:18 PM
  #229
I'm not just talking about the distant past, and valvetrain tech is not relevant to the subject at hand.
If you want to go down the road of current technology, a PROPERLY DESIGNED 8-counterweight crankshaft WITH PROPER METALLURGY, PROCESSING, AND HEAT TREATMENT will do far-far more to add life to a flimsy block than any halo girdle ever could. By proper, I do not mean guess-work designs or imports.
this is probably the most out of touch and dumbest thing said this year on here.
the guy is staying with his factory crank and caps. He’s adding some insurance to his bottom end.
You are a complete jackass.
Old Sep 7, 2022 | 01:21 PM
  #230
RW Tech's Avatar
https://www.holley.com/blog/post/hol...3_copo_camaro/
Old Sep 7, 2022 | 01:22 PM
  #231
perfect, second dumbest remark this year. no on the crank because you have no clue what this guy wants. You just can’t get over how how a halo does have some plus’s..you have never refuted anything I’ve said other than , it’s never been tested. That’s as weak as it gets
no revenue stream for me..I don’t sell any parts.
  #232
RW Tech's Avatar
Lol!! Are you the one who is selling him the girdle? Sure seems like it.
Old Sep 7, 2022 | 01:25 PM
  #233
RW Tech's Avatar
Then why the big knot in your *** over my saying you don't know for sure if it helps or hurts? Low on meds?
Old Sep 7, 2022 | 01:26 PM
  #234
keep guessing,, the opposite actually.
im turning away work because I’m booked solid till middle of next year.
John is smart enough to make his own decisions. I dont sell halos.
Old Sep 7, 2022 | 01:28 PM
  #235
because you’re a bullshitter. And you can’t pick apart anything I’ve said about what a halo does when used on the Olds.
saying it’s never been FE analyzed is just full on crap,, because of the reasons you can’t refute
ive built enough of them to see the difference..did you miss that part on purpose, or just playing dumb?
Old Sep 7, 2022 | 01:29 PM
  #236
RW Tech's Avatar
If you're not worried about what John does and you feel that he can decide things for himself, what is your reason for acting like a colossal ******* when someone days "it may not help.....a good crank will"?
Old Sep 7, 2022 | 01:31 PM
  #237
RW Tech's Avatar
OK, so when a person tells the truth then in your mind that makes them a bullshitter.
You ever consider seeing a shrink?
Old Sep 7, 2022 | 01:32 PM
  #238
tru-blue 442's Avatar
Old School Olds
Old Sep 7, 2022 | 01:38 PM
  #239
holy f’n Christ. John’s NOT replacing his crank, he’s sticking with the same bottom end. Understand?
that means NO aftermarket crank…get it?
like I said ten times already, nobody in their right mind is going to choose between an aftermarket crank or a halo. That’s two different worlds ..being the engine guru you say you are, why is that so hard to understand?
this stock parts and helping them survive.
You opened your big yap before you understood what was being talked about… maybe think before you talk.
Old Sep 7, 2022 | 01:39 PM
  #240
your truth🤣
