Guys posting about their engines
Old Sep 9, 2022 | 06:01 AM
  #281
HighwayStar 442's Avatar
Originally Posted by rickw30
Looks awesome.
I like it !
On another note; when mine blows up I'll be back so you guys can say " I told you so "
Hi Rick, how many RPMs are you going to run her?
Old Sep 9, 2022 | 06:19 AM
  #282
rickw30's Avatar
I don't know John, unless I change that halo design, I better not press it over 5k. LolBTW, I love that engine of yours. Glad to see it's coming together. I'll be paying you a visit for a ride in that beast.
Old Sep 9, 2022 | 06:44 AM
  #283
You better hold-on to your ****. I can be a wild driver!
Old Sep 9, 2022 | 06:53 AM
  #284
thewman's Avatar
Real nice
Looking real nice fleming442. Like those rods. Looks like the same halo. Are your caps as thick as ricks or have you weakened them?
Old Sep 9, 2022 | 08:57 AM
  #285
fleming442's Avatar
I didn't build it. I was trying to zoom in, but couldn't see so good. Meh, it runs..... hard!
Old Sep 9, 2022 | 06:47 PM
  #286
Bernhard's Avatar
Sure looked like rick was getting beat up for something other that the accepted method. Nice to see rick did his homework
to show he was correct.
Get better vortec pro.
Look Rick has installed the Halo the way he thinks it will work best Dale uses another method that he feels is best. Dale had concerns over Ricks method and gave his opinion on what he thought was best practice based on his experience.
This forum is about exchanging methods and opinions on Oldsmobile performance engine building, opinions and methods will vary.
Old Sep 9, 2022 | 06:52 PM
  #287
Bernhard's Avatar
Looks like mine's flat?
Do you mind sharing the brand of your Halo?
Old Sep 9, 2022 | 07:46 PM
  #288
wr1970's Avatar
Another misconception clarified by ARP engineering is there is no minimum stud thread protrusion above the nut.
They said as long as the nut fully catches all threads it does not matter how many threads are showing above nut.
I would call that B's. I don't care what arp says.
Old Sep 9, 2022 | 07:58 PM
  #289
wr1970's Avatar
thats true
Yeah and yet I have had ARP bolts snap before reaching full torque. Yes I used a thread chaser first. So you go ahead and buy into that. I will continue to use 2 thread's no more than three.
Old Sep 10, 2022 | 02:24 AM
  #290
fleming442's Avatar
It's a J&S; I heard Jim's done and retired in Florida.
I've always heard that you need at least the diameter of the fastener engaged in the threads.
Old Sep 10, 2022 | 03:18 AM
  #291
rickw30's Avatar
[QUOTE=fleming442;1452120]It's a J&S; I heard Jim's done and retired in Florida.
Jim is retired and living in Florida now.
A gentleman name Taylor bought Jim's machinery and tooling for his Halo and is still making them.
$250 for the 5 main.
Old Sep 10, 2022 | 04:54 AM
  #292
CANADIANOLDS's Avatar
yeah and yet i have had arp bolts snap before reaching full torque. Yes i used a thread chaser first. So you go ahead and buy into that. I will continue to use 2 thread's no more than three.
Old Sep 10, 2022 | 05:01 AM
  #293
first day in the internet?
Old Sep 10, 2022 | 05:58 AM
  #294
You say that the larger contact area when cutting caps 1-4 even with 5 is more beneficial because of larger contact area. 🤔
Mocked up another 455 today.
Let's do the math !
Measurements of factory caps on this block.
Height of Caps 1-4 over stud = 2.8715.
Height of Caps 1-4 at center = 1.2740.
(Measurement from center of arch to top of cap).
Height of #5 over stud = 2.3780.
Height of #5 at center = .7810.
Width of Caps 1-4 at stud end = .8305.
Width of Caps 1-4 at center = .5050.
Measurements over stud:
1-4 cap height = 2.8715.
5 cap height = 2.3780.
Difference in height = .4935 (just shy of 1/2")
Measurements at center over arch:
1-4 cap height = 1.2740.
5 cap height = .7810.
Difference in height = .493 ​​​​​​(just shy of 1/2").
Let's mill caps 1-4 .50... (Just a round number close enough)​​​​​​
What are our measurements !
Height of Caps 1-4 over stud = 2.3715.
Height of Caps 1-4 at center = .7740.
Width of Caps 1-4 at stud end = .8585.
Width of Caps 1-4 at center = .5415.
So lets take a look at what was lost and gained by milling caps 1-4 .50 .
Height of Caps we Lost .50 (1/2 "). Leaving us with .7740 at center as opposed to 1.2740 and at the stud 2.3715 as opposed to 2.8715.
Width of Caps 1-4 at widest point at stud we Gained .028. That less than 1/32 ".
Width of Caps 1-4 at center we Gained .0365. That's just over 1/32 ".
lets do the math expressed as a % increase in contact area.
because they are a casting, they vary slightly but the increase in contact area at stud hole is usually 15% to 20% the cap in the picture I posted with the nickel on it is .832” at top and .882” 1/2” down which works out to 17.7% increased area.
across the area between the stud it’s 7.1% more
That’s not insignificant . Material removed from the height when adding a high grade steel in place of soft grey iron is also a plus.
im not saying yours won’t work for you…I’m pointing out why I do it this way.
how’s that for not beating up on the guy?🤣🤣🤣🤣
Old Sep 10, 2022 | 06:19 AM
  #295
One thread exposed is fine. Is the the only requirement in the Fire Sprinkler pipe hangers. And that is only for inspector to see the ferrule nut fully engaged. If you think the forces on an 8'' steel pipe full of water. Connected to a instant on 2,500 gpm Fire Pump at 150 psi. The piping starts rocking and rolling. I even seen 8'' pipe with fire pump kicked on, move so much on a long run. That it knock out a cement block wall.
The other thing going for Ricks set-up is the double nuts. Worked on a job were the mechanical contractor trapeze hanger a row of very large Schedule 80 steam pipe. Only supported the angle iron with one nut on the all thread. Strip the thread through the nut. Had to go back and add double nuts and rod couplings.
Old Sep 11, 2022 | 07:12 PM
  #296
wr1970's Avatar
I am using aircraft standards which is what they will buy 1 1/2 is minimum anything over three is rejected. I mostly go with two thread's.
Old Sep 11, 2022 | 07:21 PM
  #297
Do you think it is just for a inspector to see if nut is fully engaged? And the ARP bolt, were exactly did it break?.
Old Sep 13, 2022 | 06:45 PM
  #298
Aircraft standard? You better call ARP to correct them
Old Sep 13, 2022 | 07:31 PM
  #299
wr1970's Avatar
Who care's about your bs. You evidently don't know **** about aircraft! Stick to what you know not what you think you know. NAS type fasteners. For aero space and aircraft .There is also military standards bolts. You're so smart why am I even explaining to it to you.
Old Sep 13, 2022 | 07:36 PM
  #300
wr1970's Avatar
Shank snapped. No it isn't just for inspection it is a guide for the workmen to follow. Yes it's in writing the standards aircraft follows for bolt and nut installation. Inspection is not required for every bolt and install. They are on check by a percentage in commercial aircraft. In military it's can depending on how strict of a inspector up to 100% verification. They check washers, shear,nut engagement. They use feeler gauge to verify heads and nut. Most inspection will not accept one thread I think it's because speculation of is that one or not quite one! But at 1 1/2 to 2 they buy it. At three they are just like one you say three they say no you're over. I was never that way when I was a inspector at spirit aircraft but again that wasn't military.
Old Sep 14, 2022 | 03:30 PM
  #301
yep, and I don’t give two craps about aircraft standards when I’m not working on aircraft.
here’s a hint..the “A” in ARP stands for Automotive…not Aerospace…it’s Automotive Racing Products.
they are the best Automotive fasteners available. You sticking more threads out past the nut, then pretending like it’s some kind of special thing ,,is bs.
then going into the military bs…it’s not making you look special.
Old Sep 14, 2022 | 05:58 PM
  #302
wr1970's Avatar
You are a special kind of guy and I don't mean in a nice way . Stick to what you know .
Old Sep 14, 2022 | 06:30 PM
  #303
Bernhard's Avatar
How is the fastener negativity impacted by having extra threads exposed past the nut?
Old Sep 14, 2022 | 07:14 PM
  #304
rickw30's Avatar
I don't think it is. It's a matter of knowing the nut is fully engaged. For my application, I needed the clearance on 1 & 2 mains for my oil pan. So, the question was raised.
Old Sep 14, 2022 | 07:33 PM
  #305
I have designed fire sprinkler system. In many Army, Navel, and Air Force facilities. (UFC) code - Unified Facilities Criteria. They have some real **** requirements. Written by god know how many committees.
Aircraft can have a big problem will chafing wires. The rubbing of wires in the electrical system against other wires, fasteners or structural parts. Maybe nothaving extra threads is to help stop that problem?
If memory serves me, I think it was the F-16 were crashing. Cause by chafing wires.
Bottom line! In my car, one thread is fine. Or three. No sure why guys on here with all capital letters. Just attack anything they do not agree with. Or belittle others. .
And if those same guys do not understand what I am saying. Please PM we. So I can try to explain, in my own way..
  #306
wr1970's Avatar
Do you think aircraft engineering and aero space engineers is smarter than a ARP bolt salesman! Let that sink in.
Old Sep 14, 2022 | 08:45 PM
  #307
Bernhard's Avatar
That is not what is being debated, the question is why they spec so few threads above the bolt.
How is the fastener being negativity effected?
I can think of a few reasons other than strength for the reason that aircraft require exact length bolts and studs weight and safety come to mind.
Safety as in threads can be a hazard if they stick past the nut two far.
Old Sep 15, 2022 | 05:06 AM
  #308
like I said..you better call ARP to tell them they are WRONG,, or in your technical lingo, it’s bs
ill stick to building engines using ARP hardware. You can pretend to be building aircraft 😁
Old Sep 15, 2022 | 05:14 AM
  #309
it’s not the ARP salesman who design the fasteners.
Let that sink in
Old Sep 15, 2022 | 05:21 AM
  #310
fleming442's Avatar
I do know that a Milwaukee M18 Fuel impact gun will break a 7/16" Moser wheel stud, even with the bearing style installation tool.
The threads being exposed in aircraft construction are more than likely for visual inspection as well as the chafing issue mentioned. An inspector doesn't need to put a torque wrench on every fastener; if the if the correct one was used and torqued correctly, it will show the appropriate amount of thread. I assume that they get marked after tightening, also. Where's @propjoe when you need him?
Old Sep 15, 2022 | 10:04 AM
  #311
Duh's Avatar
Duh
How many threads need to protrude beyond the end of the nut... If the nut and bolt are properly designed ZERO.
Any specification on amounts of threads protruding past the nut is purely up to the governing body that wrote the specification for whatever reason they want.
THE END.
Old Sep 15, 2022 | 10:17 AM
  #312
SteveDB's Avatar
Stuck in the 80's
[QUOTE=rickw30;1452121]
FYI for the group, I have one on order from Tyler. Once I have it, I will give an update, probably in a new thread. Cheers,
Old Sep 15, 2022 | 11:55 AM
  #313
THE END.
Not wanting to fight anyone. But don't most bolts have a slight taper on the end. To help start the nut?
Old Sep 15, 2022 | 12:10 PM
  #314
fleming442's Avatar
Only self tappers
Old Sep 15, 2022 | 12:30 PM
  #315
No body here would have guessed you design fire sprinkler systems, not in a million years…because you’ve never mentioned it or bragged about that ..which has nothing to do with anything here anyway.
Old Sep 15, 2022 | 12:36 PM
  #316
THE END.
yep, zero.
Old Sep 15, 2022 | 12:39 PM
  #317
Army, Navel, and Air Force facilities. (UFC) code - Unified Facilities Criteria. They have some real **** requirements. Written by god know how many committees. Was the point!
Old Sep 15, 2022 | 01:09 PM
  #318
the only one you missed is NASA.
Oh, and your Navel,,is like a bellybutton . 🤣🤣
Old Sep 15, 2022 | 01:48 PM
  #319
space coast fire
Funny you would say that. Yes for Space Coast Fire in Merritt Island, Fl. Thanks for reminding me! That was long ago.
Never said I was a good speller, And to think my brother won the NYS spelling bee, as a kid.
Old Sep 15, 2022 | 02:04 PM
  #320
Firewalker's Avatar
I love my tiny Milwaukee M18 Fuel impact gun quarter inch. So powerful and small and goes from mild for using with screws and delicate work, to wild and snapping things. So a functioning brain is needed with them but that's always been handy to have with impacts. I have larger electric and air impacts but for most things they are not needed 99% of the time for me.
