Mufflers
Mufflers
I'm looking to get the exhaust done after my motor is finished & will want to put on a good set of mufflers. I was wondering if ordering a set of mufflers for a 72' 442 from the local muffler shop would work for my 72' Cutlass S? Any suggestions? I've heard some comment about some mufflers will "drone" when driving but I don't really mind that to much.
Everyones taste is different however.
I have a set of Flow Masters on one car and a set of Magna Flows on the other. I kind of like the Flow Masters better. Everything is equal except the Flow Masters also have an X-pipe where as the Magna Flows does not have a cross over of any kind. I am thinking about adding a pair of resonators to the system with the Magnaflows.
That's actually a great choice, headers are not for everyone! Make sure your heat riser is functional, and you will need a block off plate for the crossover.
Read this:
http://oldsjunction.classicoldsmobil...sfaq/ofexm.htm
Read this:
Im going to the walkers and tail pipes. My neighboors finally complained and i now have to drive the car to the track 50 miles each way. if i plan on having my girl as co pilot it has to be quieter. chadman do you have a clip of what your car sounds like ?
No, but I can make one. Give me a few days.
Read this:
Read this:
Eric, that's what I did. When I had the duals installed, Atlas cut a plug and welded it in place. Did a nice enough job it didn't need grinding. Plus it doesn't leak....
I have a guy here who is an exhaust artist, I can drop a car off in the morning tell him what I want and pick it up that afternoon. Find a place that does hotrods, talk to friends, get a referral.
67 Olds 442
April 12th, 2012 06:54 PM
