Mufflers
Old Apr 16, 2013 | 02:45 PM
rcrac3r's Avatar
Mufflers
I'm looking to get the exhaust done after my motor is finished & will want to put on a good set of mufflers. I was wondering if ordering a set of mufflers for a 72' 442 from the local muffler shop would work for my 72' Cutlass S? Any suggestions? I've heard some comment about some mufflers will "drone" when driving but I don't really mind that to much.
Old Apr 16, 2013 | 03:39 PM
I like Walker Turbos. Mufflers are an aquired taste, since you have time, I always suggest go to some car shows and listen for what you like, then duplicate it.
Old Apr 16, 2013 | 04:48 PM
ziff396's Avatar
I agree. I have had 4 sets on mine and finally found 18" case Pypes race pro's to be to my liking. I also installed an H pipe with them. I also ran an x before but that came off real quick. I did not care for the ricey sound.
Everyones taste is different however.
Old Apr 16, 2013 | 05:31 PM
Olds442redberet's Avatar
I have a set of Flow Masters on one car and a set of Magna Flows on the other. I kind of like the Flow Masters better. Everything is equal except the Flow Masters also have an X-pipe where as the Magna Flows does not have a cross over of any kind. I am thinking about adding a pair of resonators to the system with the Magnaflows.
Old Apr 16, 2013 | 05:35 PM
Aron Nance's Avatar
We have Smithy Steel Paks on every Oldsmobile we own...........and they sound great............even Juju loves them on her '94 convertible..........
Old Apr 16, 2013 | 06:15 PM
pcard's Avatar
70 Cutlass SX
I have a set of no name muffler shop specials and they sound good - not too loud, no drone.
Old Apr 18, 2013 | 12:36 PM
rcrac3r's Avatar
Ok. I'm sticking with manifolds on this build (I can hear the header fans screaming now). Can you use 2 1/2" pipe with manifolds?
Old Apr 18, 2013 | 12:40 PM
coppercutlass's Avatar
Chevy budget Olds powered
yes if you use a reducer back wards. but i think pypes exhaust might sell 2.5 in. down pipes for manifolds.
Old Apr 18, 2013 | 12:59 PM
That's actually a great choice, headers are not for everyone! Make sure your heat riser is functional, and you will need a block off plate for the crossover.
Read this:
http://oldsjunction.classicoldsmobil...sfaq/ofexm.htm
Old Apr 18, 2013 | 01:03 PM
droptopron's Avatar
delete
I have stainless steel magnaflows & i am happy with them. Mellow @ idle and they open up nicely.
Old Apr 18, 2013 | 02:17 PM
chadman's Avatar
One more vote for the Walker/Dynomax Super Turbos. I have had Flowmasters and Pypes as well. Like the Turbos the best.
Old Apr 18, 2013 | 02:23 PM
Im going to the walkers and tail pipes. My neighboors finally complained and i now have to drive the car to the track 50 miles each way. if i plan on having my girl as co pilot it has to be quieter. chadman do you have a clip of what your car sounds like ?
Old Apr 19, 2013 | 04:25 AM
chadman's Avatar
No, but I can make one. Give me a few days.
Old Apr 19, 2013 | 06:34 AM
That would be awesome. I'm torn between the cheaper thrush mufflers or the super turbos . The thrush mufflers don't dount bad I put them on my dads car .
Old Apr 19, 2013 | 09:06 AM
John, check Gardner exhausts. They give as close to original sound as possible. A little pricey though.
Old Apr 19, 2013 | 09:38 AM
rcrac3r's Avatar
Read this:
Yeah I've done headers on Chevy's in the past & would rather not have to mess with them this go around. My manifolds dont have a heat riser in them. This car was originally a California car according to the PO so I'm guessing heat risers were not on those cars. I'm currently looking for the block off plate on Ebay.
Old Apr 19, 2013 | 09:46 AM
John,
Year One: Block Off Plate
Surprisingly enough they aren't as pricey as Parts Place.
Old Apr 19, 2013 | 10:13 AM
If you are going to have a muffler shop do your exhaust, they can fab one for it at that time.
Old Apr 19, 2013 | 11:44 AM
Eric, that's what I did. When I had the duals installed, Atlas cut a plug and welded it in place. Did a nice enough job it didn't need grinding. Plus it doesn't leak....
Old Apr 19, 2013 | 08:09 PM
rcrac3r's Avatar
I'm going to check out the local Fountain Tire here. They are supposed to be good at bending exhaust. I'll ask about making that plug.
Old Apr 19, 2013 | 08:25 PM
I have a guy here who is an exhaust artist, I can drop a car off in the morning tell him what I want and pick it up that afternoon. Find a place that does hotrods, talk to friends, get a referral.
Al Graaf
17
May 3, 2016 11:20 AM
67 Olds 442
Apr 12, 2012 06:54 PM
james455
Dec 20, 2009 05:20 AM
pophop
Nov 16, 2009 07:10 PM
67cutlass442
Jul 9, 2009 12:33 PM
