Front Coil Springs
Old November 28th, 2016, 10:45 AM
Ihatefiberglass's Avatar
Front Coil Springs
I have a 1956 olds 88. Is it possible to get the front coil springs out without a spring compressor?
Ihatefiberglass is offline
Old November 28th, 2016, 11:22 AM
Yes, if the engine is still in the car, you can use a floor jack to lower the lower control arm.
oldcutlass is online now
Old November 28th, 2016, 11:28 AM
Thanks! got em out : )
Old November 29th, 2016, 07:12 AM
paulbuiltbird's Avatar
That's how I did it through my teenage years before I even knew there was a tool.
paulbuiltbird is offline
Old January 5th, 2017, 04:18 AM
Aqua67's Avatar
Springs and shocks
If you look at the photos of my car as one members said the car looks lowered. I want to raise it to where it should be, will new Springs do the trick or do I need both shocks and springs? I'm thinking I might as well replace boat if I'm going to do one or the other. Any thoughts?
Aqua67 is offline
Old January 5th, 2017, 05:29 AM
Sorry to hi-jack the thread but to answer your question Aqua, if your car has original springs in it you can replace them and it should return the car to the original ride height. The problem will be running into too many MAWs while you are replacing the springs. It would be too easy to replace the shocks, control arm bushings, ball joints etc. while the springs are being changed.
Olds64 is offline
Old January 5th, 2017, 08:08 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Shocks will not raise he height of your car. Springs should if your old ones are worn out.
redoldsman is online now
Old January 20th, 2017, 02:55 PM
When should coil springs be replaced? Do these look reusable? Best I can tell, I don't see any cracks. They are off my 1956 olds.
Old January 20th, 2017, 04:00 PM
They should be replaced when the car height starts dropping lower than stock, lower than you want it, or when they break.
defiant1
March 18th, 2010 06:43 AM
john suder
November 2nd, 2009 01:21 PM
Flye
June 12th, 2009 01:21 PM
veltboy618
March 26th, 2009 08:27 PM
mcutlass1969
August 6th, 2006 03:47 AM
Quick Reply: Front Coil Springs
