Front Coil Springs
Springs and shocks
If you look at the photos of my car as one members said the car looks lowered. I want to raise it to where it should be, will new Springs do the trick or do I need both shocks and springs? I'm thinking I might as well replace boat if I'm going to do one or the other. Any thoughts?
Sorry to hi-jack the thread but to answer your question Aqua, if your car has original springs in it you can replace them and it should return the car to the original ride height. The problem will be running into too many MAWs while you are replacing the springs. It would be too easy to replace the shocks, control arm bushings, ball joints etc. while the springs are being changed.
