Spindle clean up/restoration
Old Jan 3, 2025 | 08:04 AM
dmitchell's Avatar
I am rebuilding the front suspension on a 72 Cutlass convertible with disc brakes. After cleaning the spindles I notice that all the mating surfaces appear to be bare metal. I plan to paint the spindles before putting it back together. Should I tape off the bare metal areas before painting? If the bare areas are painted will it cause problems in the future?
Thanks.
Don
Old Jan 3, 2025 | 08:17 AM
Will the thickness of the paint matter to fitment? Not really. When I had mine powder coated I masked those surfaces, but that's a lot thicker than paint.
Old Jan 3, 2025 | 09:44 AM
While paint probably won't harm anything, there is really no reason to paint those surfaces as they usually get a light film of grease on them preventing them from corroding.
Old Jan 3, 2025 | 10:32 AM
Sugar Bear's Avatar
It is easier to tape off the areas in question than remove paint later. At a minimum tape the threads to prevent mechanical damage such as a nicked thread.
Old Jan 3, 2025 | 03:09 PM
jmcghee's Avatar
Joe , do you think that paint on the part,ere the bearings ride, is ok ?
Old Jan 3, 2025 | 05:54 PM
You're just going to scrape the paint off and it will end up in the grease when you put the bearing on. There is a reason press fit is called that. Will a paint goober end up in a bearing? Maybe.
the72cutty
Mar 4, 2014 04:29 AM
oldsmansugar
Paint
Oct 24, 2013 12:19 PM
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
Doug in SD
Suspension & Handling
Jun 8, 2011 05:59 AM
Beltman
Oct 15, 2010 01:38 PM
