Spindle clean up/restoration
I am rebuilding the front suspension on a 72 Cutlass convertible with disc brakes. After cleaning the spindles I notice that all the mating surfaces appear to be bare metal. I plan to paint the spindles before putting it back together. Should I tape off the bare metal areas before painting? If the bare areas are painted will it cause problems in the future?
Thanks.
Don
Thanks.
Don
You're just going to scrape the paint off and it will end up in the grease when you put the bearing on. There is a reason press fit is called that. Will a paint goober end up in a bearing? Maybe.
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
