Spindle Question
Old Jun 6, 2011 | 07:38 PM
Doug in SD's Avatar
Spindle Question
70 Cutlass Supreme Question.... Is the front spindle the same between a drum and a disc brake setup?
Thanks in advance
Doug
Old Jun 6, 2011 | 09:02 PM
2blu442's Avatar
The factory spindles are different. But the drum spindle can be modified to work for the disc brakes. Joe P. has a couple good writeups on this and the parts needed for the changeover. Try the search option for drum to disc converstion and see if you can find them. John
Old Jun 7, 2011 | 06:39 AM
http://www.pozziracing.com/brakes.ht..._brake_spindle
Old Jun 8, 2011 | 05:59 AM
Doug in SD's Avatar
Thanks for the info, I am going to convert to disc brakes on the front and this is one less (small) expense I won't have to worry about.
Doug
kaptmikey
Brakes/Hydraulic Systems
Feb 8, 2017 07:01 AM
therobski
Mar 26, 2014 10:55 AM
Doug in SD
Nov 25, 2011 11:53 PM
CrazedCountryRebel
May 4, 2011 09:54 AM
perro
Sep 3, 2007 01:30 PM
