72 Front Spindles Wanted
Old Oct 12, 2010 | 12:04 PM
Beltman's Avatar
I'm looking to convert my drum brakes to disks in the front of my 72 cutlass convertable. Is anyone selling spindles near Oklahoma?
Old Oct 12, 2010 | 03:19 PM
filbily's Avatar
u dont need different spindles
Old Oct 12, 2010 | 03:28 PM
midnightauto's Avatar
Question disc brakes
I have what you need call me 570-459-0745 and you do need to change the spindles.
6inarow's Avatar
I have heard of people machining the upper mounting boss so that it is the same as the lower one on drum brake spindles so that you can mount disc brakes. I would be interested in hearing if anyone has anymore details on this type of conversion.
Old Oct 15, 2010 | 01:38 PM
OldsMotion's Avatar
OldsMotion
No you do not need to change them, HOWEVER you would need to drill and tap another hole in the drum units to accomodate the caliper bracket.
All else is available aftermarket to include the dust shield and bracket. HOWEVER, it would still end up being cheaper in the long run to find a set of used units.
Make sure you get the correct differential valve, and hose/frame clips for the conversion, as well as the correct power master cylinder if your car doesn't have one. (not needed but just in case)
John
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
rogiestone
Oct 18, 2011 06:11 PM
airlamb
Apr 15, 2010 10:51 AM
Texas Jim
Dec 1, 2009 01:39 AM
68conv455
Nov 13, 2008 08:57 AM
