Swapping Front Discs and Spindles; newer to Older Models
Old Nov 27, 2009 | 10:27 AM
Texas Jim's Avatar
Texas Jim
Question: Do the front hubs, or spindle set-ups, on newer models interchange w/ any of the front hubs, or spindle set-ups, on the older models? Are the front bearings, inner and outer, the same size/interchangeable on any of the different years? I continually see guys making that swap, drum to disc, using aftermarket items and was wondering if it could be done using factory items of newer years. Thanks in advance.
Old Nov 27, 2009 | 10:40 AM
gearheads78's Avatar
car guy
You can buy brackets from KORE3 that allow C5/C6 brakes to bolt right up. You do have to run at least 17" wheels to run this swap though.
Old Nov 30, 2009 | 06:06 AM
Texas Jim's Avatar
Texas Jim
I didn't even relate the "C" series reference, as my mind is far away from 'Vettes when I'm on this site.
I wasn't referring to aftermarket items. I meant, ie; '70 front disc brakes from a Olds 98 or Cutlass fitting ie; a '64 Olds (whatever model). I'm only using these years and models f/ an example.
My question was; Could you find a later model Olds w/ front discs that would fit an older model? Swapping a later model front brake assy. onto an older model. Are any of the Olds years interchangeable? Can the spindle assys. be swapped w/o modification, are the wheel bearings the same size on any two years, early and late models, etc. ?
Old Nov 30, 2009 | 07:05 AM
car guy
If you are talking A-body then yes any 64-72 drum brake cars will interchange with any A-body with disk brakes
Old Nov 30, 2009 | 07:37 PM
HolidayCoupe's Avatar
SWEET!! thats some good info how bout for B-Body's?
Old Nov 30, 2009 | 11:36 PM
oldsmohaulic's Avatar
My Delta would love some front disc brakes....I'm all ears.
Old Dec 1, 2009 | 01:39 AM
OldsMotion's Avatar
OldsMotion
As well as 68/69 F bodies, and 73 and 74 X bodies.
This is a topic that gets asked over and over again almost monthly on the majority of Olds sites. I'm not saying its a BAD question, because its not. its just the information is already out there.
Additionally what car are you looking to do the swap with? Do you WANT factory parts or will aftermarket do? Do you want to make modifications to your exsisting drum spindle that will allow a stock caliper bracket and backing plate?? That is another option.
As far as swaps from B body to A body, there are some that have been done with modifications. Do you want to put rear discs on an early 8.5 rear with GM parts from the junkyard? This can be done as well...
John
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
rogiestone
Oct 18, 2011 06:11 PM
Redog
Jun 1, 2011 08:12 PM
Wilson05
Oct 24, 2009 03:29 PM
Sixoh
18
Mar 30, 2008 10:24 AM
