82 -66 front spindles
Old Apr 13, 2010 | 07:30 AM
airlamb's Avatar
i want to put front disc brakes on my 1966 f-85 and i have a 82 cutlass ... wondering if anyone knows if the front spindles will work.?.?.
will the brake booster work too??? the 66 just has manual brakes... one line thing... hole in one line and all brakes are lost
the 82 is front disc and i am going to part it out/ derby it... and was hopeing to use some of the parts from the 82 on the 66
Old Apr 13, 2010 | 01:23 PM
Sorry, but your 82 spindles will not work on a 66. The ball joint stud taper is different. You need the correct spindles for your 66, or you need to machine your drum spindles to accept the caliper brackets for discs.
Old Apr 14, 2010 | 02:58 PM
lweinmunson's Avatar
Joe, just for clarification, would cutting the 3/4" off of the drum spindle mounting boss allow the use of the g-body caliper brackets? I've been contemplating disk brakes on my 70 and I have a 78 that I could rob for parts.
Old Apr 15, 2010 | 10:51 AM
Again, the later parts cannot be used. First, the caliper mounts are integral to the forged spindles, so there are no "brackets" for you to transfer. Second, the later "metric" calipers have smaller pistons, smaller pads, and a different bolt spacing, so you can't use those either.
You CAN machine the drum spindles and buy repro caliper brackets for the A-bodies. The machining dimension is more like 0.68", however.
http://www.pozziracing.com/brakes.ht..._brake_spindle
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
rogiestone
Oct 18, 2011 06:11 PM
Beltman
Oct 15, 2010 01:38 PM
Texas Jim
Dec 1, 2009 01:39 AM
68conv455
Nov 13, 2008 08:57 AM
