Spun bearing
Old March 21st, 2017, 06:31 AM
Amarion58's Avatar
Spun bearing
I spun a bearing in my 350 and the crank is toast can I just put a crank kit in it and it will work?&
Amarion58 is offline
Old March 21st, 2017, 06:44 AM
Did it spin a main bearing or a rod bearing? If a rod bearing, the rod needs to be checked / reconditioned or the new bearing will spin due to the out of round rod.
Fun71 is online now
Old March 21st, 2017, 06:51 AM
Amarion58's Avatar
the number 8 rod bearing. I was being crazy pushing my dad's truck home and I guess my engine didn't like it and started knocking crazy.
Old March 21st, 2017, 06:56 AM
edzolz's Avatar
I would do the crank kit with reconditioned rods. Is it manual trans or automatic?
edzolz is offline
Old March 21st, 2017, 07:14 AM
Amarion58's Avatar
automatic. I'm a little short on cash for a complete rebuild and I think that's a cheaper way out for me. Is there anything I can do about the bearing material that might be flowing in the system w/o going to the machine shop.
Old March 21st, 2017, 08:09 AM
You could always disassemble the engine and replace the rod with one from a used engine. Of course, that's @$$uming you could find a used Olds 350 in a salvage yard. Plus, the crank might be damaged in addition to the rod. With bottom end damage there really isn't a convenient, durable and cheap way to fix it, you just have to do it the right way or expect to open the engine again soon.
Olds64 is offline
Old March 21st, 2017, 12:57 PM
brownbomber77's Avatar
Where are you located? I have a diesel you can toss the heads, intake, timing chain, cam, and timing chain cover onto and have a motor you can pull anything with...ha.
brownbomber77 is offline
raw442
September 16th, 2012 07:37 PM
sicky olds
February 29th, 2012 01:36 PM
olds455
July 22nd, 2010 06:16 AM
Topless72
April 9th, 2008 11:47 AM
OLD SKL 69
Drivetrain/Differentials
January 24th, 2008 08:36 AM
Quick Reply: Spun bearing
