Spun bearing
Old Mar 21, 2017 | 06:31 AM
Amarion58's Avatar
Spun bearing
I spun a bearing in my 350 and the crank is toast can I just put a crank kit in it and it will work?&
Old Mar 21, 2017 | 06:44 AM
Did it spin a main bearing or a rod bearing? If a rod bearing, the rod needs to be checked / reconditioned or the new bearing will spin due to the out of round rod.
Old Mar 21, 2017 | 06:51 AM
Amarion58's Avatar
the number 8 rod bearing. I was being crazy pushing my dad's truck home and I guess my engine didn't like it and started knocking crazy.
Old Mar 21, 2017 | 06:56 AM
edzolz's Avatar
I would do the crank kit with reconditioned rods. Is it manual trans or automatic?
Old Mar 21, 2017 | 07:14 AM
Amarion58's Avatar
automatic. I'm a little short on cash for a complete rebuild and I think that's a cheaper way out for me. Is there anything I can do about the bearing material that might be flowing in the system w/o going to the machine shop.
Old Mar 21, 2017 | 08:09 AM
You could always disassemble the engine and replace the rod with one from a used engine. Of course, that's @$$uming you could find a used Olds 350 in a salvage yard. Plus, the crank might be damaged in addition to the rod. With bottom end damage there really isn't a convenient, durable and cheap way to fix it, you just have to do it the right way or expect to open the engine again soon.
Old Mar 21, 2017 | 12:57 PM
brownbomber77's Avatar
Where are you located? I have a diesel you can toss the heads, intake, timing chain, cam, and timing chain cover onto and have a motor you can pull anything with...ha.
raw442
Sep 16, 2012 07:37 PM
sicky olds
Feb 29, 2012 01:36 PM
olds455
Jul 22, 2010 06:16 AM
Topless72
Apr 9, 2008 11:47 AM
OLD SKL 69
Drivetrain/Differentials
Jan 24, 2008 08:36 AM
