70 455 Spun Bearing?
Old Mar 30, 2008 | 08:55 PM
Topless72's Avatar
I was running my 70 455 442 down the highway at about 3300 RPM when the oil pressure dropped to about 0 and rapping started. No overheating occurred. I had it towed home and started it. It rapped at start but stopped as pressure was back at 50 psi. After a bit I could hear it starting slightly again getting worse as time went on. Is a bearing spun? Can I replace them from under the car by removing the oil pan?
Old Mar 31, 2008 | 05:47 AM
Oldsguy's Avatar
Past Administrator
Do you have an oil pressure gauge? This would help you determine if a bearing has been damaged but it certainly does seem like it from your description.
Old Mar 31, 2008 | 06:29 AM
Rallye469's Avatar
That or a collapsed lifter?
Nah, it sounds like a bearing.
Get used to the idea of pulling your engine. You're only kidding yourself if you think you can get it done from underneath.
You might have to cut the crank a bit.
How many miles are on it?
Old Mar 31, 2008 | 09:59 AM
Topless72's Avatar
Pressure was running 3K psi and then dropped to 0 when rod rapped.
After total cooling and re-start, pressure was up to 50 psi and as car warmed up, I could here it starting again when revving the engine.
At idle, oil pressure is still at 30 - 50 psi
Old Mar 31, 2008 | 04:18 PM
Redog's Avatar
Does it sound like this?
When the 307 spun it's bearing
It's cure, a new engine, but it was a 307, not worth rebuliding
Old Mar 31, 2008 | 04:24 PM
Topless72's Avatar
Nowhere near as bad as that.......
Old Apr 1, 2008 | 04:23 PM
71 delta88guy's Avatar
2 things you can do to get some idea. first, pull the oil filter cut appart and look for metal fragments ,pieces of bearing. 2 drain oil and look for metalic swirl when oil goes into drainbucket. Sounds like an engine pull is only answer.
Old Apr 2, 2008 | 04:57 AM
Oldsguy's Avatar
Past Administrator
Wow, now you just ruined my morning! After listening to that I am going to feel sort of sick in my gut all morning long........
Old Apr 9, 2008 | 11:47 AM
70oldsW30's Avatar
Oh geez. This reminds me of when I let my oldest son drive my '70 SX while his car was in the shop being painted. It had only a few thousand miles on a new motor. He called me on his cell phone from his buddies house saying "Hey dad, your car is making this really weird noise. Listen!" I have no idea how long I futilely screamed "Shut it off!!" as he held his cell phone out towards the running, knocking car so I could hear it real good.
i9730lds
Jun 10, 2013 06:51 PM
raw442
Sep 16, 2012 07:37 PM
sicky olds
Feb 29, 2012 01:36 PM
olds455
Jul 22, 2010 06:16 AM
OLD SKL 69
Drivetrain/Differentials
Jan 24, 2008 08:36 AM
