Pulling the motor
Old November 30th, 2013, 02:21 PM
  #481
So your assembled height will be just slightly lower than the original height, ie: maybe a few thousandths (the amount that would give you 0.1 point of extra compression - on your '71 the difference between 8.5:1 and 8.6:1, or less than the probable production variation between cylinders).
No big deal. The hydraulic lifters will compensate for that.
As far as different lifter lengths for your cam, no reason you should need them.
The new cam may be more aggressive than the old, but it shouldn't be that aggressive that it would affect rocker operation angles. The types of cams in questions are the ones that you have to use different rockers and heavy springs for.
Don't worry about it, you're fine.
(All of that being said, a search of your thread does not reveal the specifications of your new cam. To be able to assure you that you did not need to change anything, we would need to now those, especially the lift.)
MDchanic is offline
Old November 30th, 2013, 03:02 PM
  #482
Macadoo's Avatar
I'll dig out the papers....
Macadoo is offline
Old November 30th, 2013, 03:04 PM
  #483
Chevy budget Olds powered
coppercutlass's Avatar
I smell a possible jingle for felpro. lol
coppercutlass is offline
Old November 30th, 2013, 03:47 PM
  #484
Macadoo's Avatar
Lobe separation 110+4
Overlap 60.00
Intake Opens 34.00
Intake Closes 66.00
Exhaust Opens 74.00
Exhaust Closes 26.00
Valve Lift 0.448
Duration 280
I can't find the specs for the original cam in the manual but I can tell you that the cam that came out had visibly worn lobes. I'll try to get pics of that put up. This grind doesn't have as much valve lift as the Edel performer but I don't know enough about the subject to know if that's good or bad. I'm trusting Mark on this one.
Macadoo is offline
Old November 30th, 2013, 03:48 PM
  #485
Macadoo's Avatar
I suppose they still have jingle writers. Maybe I've found a new career?
Macadoo is offline
Old November 30th, 2013, 04:30 PM
  #486
Originally Posted by Macadoo
Valve Lift 0.448
Your original should be an -084 cam, which has about 0.0400" lift on both intake and exhaust, so the new one is only 0.048" larger, which should not affect your pushrod length, at least as far as I know.
I'd be interested in seeing those pictures, because these cams were not known for wiping lobes, the way that, for instance, the Chebbies from the late '70s were.
MDchanic is offline
Old November 30th, 2013, 06:58 PM
  #487
Macadoo's Avatar
Difficult to capture in just a couple of photos, considering the lobe angles. But these look pretty worn to me. And of course I've seen so many used cams (this is my first).
[IMG][/IMG]
[IMG][/IMG]
Macadoo is offline
Old November 30th, 2013, 07:01 PM
  #488
Sorry, don't mean to bust on you, but that looks like minimal normal wear to me - a nice looking cam.
MDchanic is offline
Old November 30th, 2013, 07:20 PM
  #489
Macadoo's Avatar
Oh hell Eric, I know enough to know I don't know nothin'. Bust away
Macadoo is offline
Old December 2nd, 2013, 03:30 PM
  #490
Macadoo's Avatar
Exclamation
This morning I called the machinist that worked on my heads. He said that he "definitely took less that ten thousandths" when he milled the heads. I'm assuming he meant less than .010". I asked if it was a little less or a lot less (trying to narrow it down a little) but he couldn't say. That's not very specific. Live and learn
Macadoo is offline
Old December 2nd, 2013, 03:52 PM
  #491
That's not the sort of thing you want to hear a machinist say.
You want him to say that he's sorry it seems to be half a thousandth higher on one side than on the other, or that he had to take off an extra thousandth to correct that.
If you want to keep your compression the same, you will need to use thinner head gaskets or have the heads decked a little bit more.
I'd consider having it done more anyway, as you just don't know what this guy did to your gasket surfaces.
MDchanic is offline
Old December 2nd, 2013, 04:47 PM
  #492
Macadoo's Avatar
Angry
Okay, so....this work cost me $400, more than I had expected it to cost. They decked the heads but we don't know how much, they degreased them (the water jackets still look pretty crummy) instead of hot tanking, they ground the valve seats but not enough to take the hardening out (his words), they replaced one guide, all the seals, replaced all the exhaust valves, and installed the springs. Did I get taken?
If I take them somewhere else, will they be able to tell me how much was taken off the heads? And how much can I have taken off without having to deck the intake manifold too?
Macadoo is offline
Old December 2nd, 2013, 05:00 PM
  #493
Macadoo's Avatar
I realize you can't tell much from the pics but what the heck....
I duuno' man, when I took the gaskets in he said he wouldn't lower my compression, and that if anything I'd gain a minute amount. In his words, "maybe a point." Which I assumed meant 0.1
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Macadoo is offline
Old December 2nd, 2013, 05:20 PM
  #494
Yeah, I can't really say anything about the pictures. I can't say anything about the price either.
... will they be able to tell me how much was taken off the heads?
In answer to the first question, the specification for head thickness, from the rocker pivot mounting surfaces (which should be the same as the height of the valve cover gasket surface) to the head gasket surface, should be between 2.200" and 2.220", which is a tolerance of 0.020" right from the factory.
(Unfortunately, I don't recall the source of that spec., but I did check it at the time, and it was correct).
If you measure the head thickness and it's between 2.200" and 2.220", then it wasn't cut much.
Following along those lines, if you're planning to use a head gasket that is 0.023" thicker, the head should be 2.177" to 2.197".
[edit: also, I just found some measurements I made in the past, and one set of #7 heads I have measured 2.157", while a set of B heads measured 2.156". I have no idea whether either was ever cut.]
Regarding how much you can take off before making other modifications, remember that if you use 0.039" head gaskets, you are raising the heads 0.023" from where they were designed to be, so if you remove 0.023", you are simply putting the heads back down where they started.
MDchanic is offline
Old December 2nd, 2013, 05:54 PM
  #495
Justin
oldstata's Avatar
On price just talked to my machine shop again to recheck price on my BBO heads he said cleaned, mag checked and resurfaced would run me 100.00 if they needed a total rebuild 450.00 including parts as OE spec not performance valves that would be extra .
He did tell me clean and check my block to tell me were I sit would be 75.00 hope this helps
oldstata is offline
Old December 2nd, 2013, 06:09 PM
  #496
Macadoo's Avatar
"Regarding how much you can take off before making other modifications, remember that if you use 0.046" head gaskets, you are raising the heads 0.030" from where they were designed to be, so if you remove 0.030", you are simply putting the heads back down where they started."
Oh right right right. So the Felpro (blue) 8171 PT-1 has a compressed height of 0.046? I looked around others have said they are .035 or .039. Felpro.com has no iinfo and Advance doesn't say.
Macadoo is offline
Old December 2nd, 2013, 06:11 PM
  #497
Macadoo's Avatar
Would that be with all new guides? Or did that not come up?
Good info though, thanks tata
Macadoo is offline
Old December 2nd, 2013, 06:22 PM
  #498
Justin
oldstata's Avatar
He stated total rebuild so I assumed it was , but very good question to ask my next go around.
oldstata is offline
Old December 2nd, 2013, 06:28 PM
  #499
Those heads only got degreased they look what mine looked like . I'll post pics of difrent cleaning methods in bit
Old December 2nd, 2013, 06:35 PM
  #500
This is what completely new valves and bare metal that's been de rusted look like as far as the heads go.
Old December 2nd, 2013, 06:46 PM
  #501
I just checked. They're spec'd at 0.039". I'm not sure why the other number was in my head, but it looks like it's the wrong one.
I'll go back and change it.
MDchanic is offline
Old December 2nd, 2013, 06:58 PM
  #502
Here is what just degreased looks like. I could not de rust them as the de rusting tank chemicals would have eaten up the bronze guides. We dipped them for 30 minutes , power washed em then I dipped em in a oil bath that dries to a pretty much bone dry coating.
Old December 3rd, 2013, 07:28 AM
  #503
Lars's Avatar
by looking at your first pic Mac, the heads weren't shaved that much. on the center of the head theres a recess, (bottom of the picture center of the head). "ususally" that dark spot is gone when mill 10+ off. shops usually only take off what they need to, to make them flat. your getting to the point where your learning too much to be dangerous. go to a feed store and get a graduated seringe and cc your heads. I'm shure you will be fine bolting them on with the felpro's, and the stock rockers. on the next build you'll be that much ahead.
Lars is offline
Old December 3rd, 2013, 07:53 AM
  #504
Remember, the FelPros are spec'd to add 9cc to the CC.
MDchanic is offline
Old December 3rd, 2013, 08:31 AM
  #505
Lars's Avatar
Lars is offline
Old December 3rd, 2013, 12:27 PM
  #506
Macadoo's Avatar
No worries dude.
CCing the chamber is a good idea. I have a few graduated syringes for ink jet printer refilling. What kind of numbers am I looking for? And I'm assuming I should use plain old motor oil?
Unfortunately, I'm running into finals so the next week is going to be brutal. No time in the shop
Macadoo is offline
Old December 3rd, 2013, 12:46 PM
  #507
Professur's Avatar
Motor oil is too viscous. Too much surface tension and too large a meniscus unless you're using a dedicated system with a pipette thin vertical.
Professur is offline
Old December 3rd, 2013, 12:59 PM
  #508
Use windsheild washer fluid.
Old December 3rd, 2013, 01:17 PM
  #509
Lars's Avatar
64 to 68cc's, youl need a piece of plexiglass. drill a hole in it, cover the chamber, set level, fill with fluid, get a number. you'll be able to figure out true comp ratio with numbers.
Lars is offline
Old December 3rd, 2013, 04:48 PM
  #510
Macadoo's Avatar
Sounds good guys. I'll post up the numbers when I have them. Maybe this weekend.
Macadoo is offline
Old December 4th, 2013, 05:42 PM
  #511
Macadoo's Avatar
When I installed the cam I ran out of the Joe Gibbs they gave me in the packet so I bought the Permatex red Ultra Slick Engine Assembly Lube. Thing is it looks like it dripped off over the last few days. Do I need to use something else and can I apply it over the red or do I need to clean it off the cam first. I'm not sure the permatex is meant to be used if there will be time before it's fired. The Gibbs is like a thick grease and is still globbed on but the permatex is more of a thin layer of gloss.
I'd rather not have to pull off the water pump, front cover, and timing set if I don't have to but I will.
Macadoo is offline
Old December 4th, 2013, 06:25 PM
  #512
I used it and had the short block sit for 6 months.
Old December 5th, 2013, 06:11 AM
  #513
Lars's Avatar
you'll be fine as-is keep going...
Lars is offline
Old December 5th, 2013, 12:56 PM
  #514
Macadoo's Avatar
Excellent. Thanks guys.
Macadoo is offline
Old December 5th, 2013, 04:50 PM
  #515
Macadoo's Avatar
So, for CCing the chambers; with our without the spark plug? I'm inclined to say with. But won't it leak the liquid before I can get an accurate measurement? Teflon tape on the threads maybe?
On second thought, if the plug can create an airtight chamber then watertight shouldn't be a problem. No worries, I'm not using actual water.
Macadoo is offline
Old December 5th, 2013, 05:01 PM
  #516
Hi Mac. I wrote you an entire essay on how to cc the heads, then lost it to the deadly "Expired Token."
My PM box is full, but you can e-mail me by selecting "Send E-mai" from the pull down when you click on my name.
MDchanic is offline
Old December 5th, 2013, 05:08 PM
  #517
A quick revisit of my advice for cc'ing the heads:
You want the liquid with the smallest meniscus, so you want a nonpolar liquid, so you want an organic solvent, so you want gasoline, diesel, kerosene, mineral spirits, or wood alcohol (washer fluid, as mentioned earlier, contains wood alcohol, but I'm not sure how much of a meniscus it makes).
Organic solvents tend to be volatile, so you want the least volatile one, as otherwise, some of it will evaporate while you get the volume right.
You want a piece of decently thick plexiglass, so that it doesn't bow inward and affect your results.
You want to smear a very thin layer of Vaseline on the head gasket surface, and then smush the plexi down on it nice and hard, to prevent the solvent from wicking into the otherwise-empty space.
The purpose of the plexi is so that you can tell when it is actually full. It is amazingly difficult to tell this with the naked eye.
You definitely need the valves and the spark plug in place and not leaking.
MDchanic is offline
Old December 5th, 2013, 06:27 PM
  #518
Macadoo's Avatar
Thanks for the almost write-up Eric. I do appreciate it. I actually used vaseline, great minds. But just the thinnest smear. I didn't want to raise the plexi. 1/8" was the thickest I had around but I used my small machinist's square and it looked pretty flat. And I used the lead shot to hold it in place and it stayed flat. I did have a little capillary action between the plexi and the head so I'm calling it somewhere between 65.5 and 66 CCs. I gotta' say, this method is pretty slick. The bubble appeared after the reading and probably accounts for the liquid that seeped.
[IMG][/IMG]
Macadoo is offline
Old December 5th, 2013, 06:29 PM
  #519
Looks nice.
Now you can calculate the CR. For that cylinder, anyway.
MDchanic is offline
Old December 5th, 2013, 06:57 PM
  #520
Macadoo's Avatar
Oh right...sure....umm...how do I do that exactly? You mentioned the Felpros adding 9 CCs for a total of 75 CCs. Sounds like a lot....?
Macadoo is offline
Quick Reply: Pulling the motor
