Introduction and quick question
Old May 1, 2017 | 10:49 PM
Dannyd's Avatar
Thumbs down Introduction and quick question
Hi guys I'm dan, I'm a 442 enthusiast who has frequented this forum from afar for some years now and now I have a question I can't find the answer too so I figured it was time to sign up. I'm finishing up a frame off on my 1971 442 convertible. it's a real 442 and I am doing it up like a w30. It's a conv/4-speed/A/C car which I think is pretty cool (literally). My question is about the aftermarket red inner fender wells. I bought a pair from Brothers Automotive back in 2012-13. They are just now being installed and I'm not a guy that's always complaining. I understand everything's not gonna bolt right on but these things are rediculous!!! Does anyone know if they've came out with a new version/different manufacture since then that might fit better? Or maybe some installation trick to get them to fit. We were trying to install them with the fenders on. Do you think it would make any difference if we took the fenders off first? They really don't even fit like they are made for my car. I have goodmark aftermarket fenders on the car. Thanks in advance for any suggestions. I'll throw in the most recent pic of the car but don't have pics of wheel well fit.
File Type: png
File Type: png
Old May 2, 2017 | 04:31 AM
deadeyejedi's Avatar
i believe my front inner wells were from the parts place and i had the same issue .the fender well fit better to my original passenger side fender than the one on the drivers side ,which had a repop fender,both while fenders were on the car.i cranked the heat up in the garage to make them more pliable and actually used a heat gun to remold part of the drivers side lower section.all the bolt holes did line up.i might suggest leaving them in the sun for a while to soften them up.imo most of the aftermarket parts need massaging.btw (1972 cutlass supreme conv. )
Old May 2, 2017 | 04:33 AM
Dave26's Avatar
Dan, nice looking paint job. To the inner fenders, most aftermarket inners require a good amount of "messaging" you may even need to drill new holes. I start in the back.....then do the front.....finish with the lip clips
Old May 2, 2017 | 05:05 AM
Looks like a cool project! I hope you're able to adjust the wheel wells.
Old May 2, 2017 | 06:12 AM
Nearly all of the repro inner fenders that I've seen suck. The molded features like the wiring troughs and the bosses for the cruise control unit are amorphous blobs instead of having well defined, crisp edges. Fortunately, this makes it easy to spot a fake W-30.
Old May 2, 2017 | 07:36 AM
It seems a lot of aftermarket parts have issues, not just Olds. I guess its better than not having any to start with.
Old May 2, 2017 | 10:06 AM
CRUZN 66's Avatar
Olds Fever
Welcome to the site... Have you compared the new parts to your your old ones to see if any major areas standout which will cause concern for mounting? Addressing these may help the install...
Daniel G
Jan 31, 2016 04:40 AM
Wandrews
Jun 4, 2014 01:19 PM
Wedgewood Rod Shop
Nov 30, 2013 08:41 PM
orsogrigio
Jun 11, 2010 12:34 PM
gearheads78
Apr 3, 2008 01:51 PM
