1965 442 build
Old Sep 18, 2012 | 06:49 PM
  #121
real57vetteguy's Avatar
Another 12 hours in the garage...... Is anyone running a pertronix distributor, I've had the new one in and out about 5 times, it does not fit near as snug as the factory dist. I am a bit concerned.
Old Sep 19, 2012 | 06:01 AM
  #122
therobski's Avatar
That's weird, never heard that, but I'm running a GM HEI.
Old Sep 19, 2012 | 07:24 AM
  #123
oldsguybry's Avatar
NOVICE car nut
Great progress ! Love the Vette too
Old Sep 19, 2012 | 08:06 AM
  #124
Eddie Hansen's Avatar
I have no help to offer on the petronix but had to pop on and say the vette is friggin awesome.. and the oldsmobile is over the top well done on both accounts
Old Sep 19, 2012 | 08:31 AM
  #125
Thank you very much, The Vette was a LONG 5 year project, and hopefully the last restoration I tackle. I am really liking the resto-mod world much better! I'm starting to see the light at the end of the tunnel on the Olds.
Old Jan 15, 2013 | 10:27 AM
  #126
Just updating some pics, I have about 400 miles on it so far and loving it!
Old Jan 15, 2013 | 01:15 PM
  #127
gearheads78's Avatar
car guy
Looking great man!!
Old Jan 16, 2013 | 04:57 AM
  #128
Thank you, Thank you Sir
Old Jan 16, 2013 | 06:38 AM
  #129
oldsguybry's Avatar
NOVICE car nut
The car looks great !
Old Jan 16, 2013 | 07:06 AM
  #130
Thank you very much, I am pleased with the turnout seeing that we done it all in my garage!
Old Jan 26, 2013 | 08:29 PM
  #131
bartmobile's Avatar
Hi I have a 1965 cutlass I am about to take the body off. Wondering if you could tell me how you rigged up the engine host the way you did to lift it off.I love what you did I can only hope I can have the same success. Thanks
Old Jan 26, 2013 | 08:41 PM
  #132
oldstata's Avatar
Justin
[QUOTE=real57vetteguy;497437]Just updating some pics, I have about 400 miles on it so far and loving it!
Wow I would be scared to pull in my garage doing 80 while taking a pic lol j k
Great build loved it
Old Oct 1, 2013 | 11:56 AM
  #133
Welp.....537 miles and lost the 200R4.... But Art Carr was such a stand up guy about it he built another one and it is now in transit, he said to take my time, get the swap done and call him and he will send a truck to pick up the old one, no fee's at all. I am going to pull the engine also and do a little something here and there to it as well!
Old Oct 2, 2013 | 09:33 PM
  #134
72cuttys's Avatar
What type of wirelooms are they? I love the routing of your wires. Also, where are those valve covers found?
Old Oct 3, 2013 | 10:16 AM
  #135
The wire looms are from summit. I may sell the valve covers, I'm looking for a shorter set that will clear roller rockers.
Old Oct 4, 2013 | 09:32 AM
  #136
1arunem's Avatar
SICK build. Love it. Nothing wrong with building it the way YOU want it!
Old Oct 4, 2013 | 07:04 PM
  #137
OLD SKL 69's Avatar
GM Enthusiast
Looks really nice!
Old Oct 15, 2013 | 03:13 AM
  #138
shellvrolet's Avatar
radiator
where did you get your radiator, and what brand?
Old Oct 15, 2013 | 09:31 AM
  #139
Its a Champion radiator. I spoke with Rick there at Champion who assured me that the radiator would cool a 750 HP Olds big block, so far I am not so sure about that. The quality of the radiator is pretty good, but they sent me 2 12" elec fans with my radiator and come to find out they only provide 1200 CFM each, its my understanding I need more like 2000 CFM each, I am going to try to run better fans and a high flow water pump and see what happens
Old Oct 15, 2013 | 03:10 PM
  #140
67tpcruiser's Avatar
beautiful car man, excellent work you and your friends. and i'm trying really hard to like the dash
Old Dec 8, 2013 | 06:44 PM
  #141
ohhh yea
Welp.... Winter is here, heaters going, TIME TO GET READY, the hot rod power tour is coming up!
Old Dec 8, 2013 | 07:11 PM
  #142
69ishHoliday's Avatar
Hi Mark,
I just read through the build thread. You did an amazing amount of work and I like every aspect of the car. I got to see some good pictures of the exhaust system I bought from you. Thanks again and good luck with the new 200R. - Steven
Old Dec 8, 2013 | 07:15 PM
  #143
Originally Posted by 69ishHoliday
Hi Mark,
Thanks Pal. I think you will be happy!
Old Dec 9, 2013 | 06:30 AM
  #144
therobski's Avatar
Mark got the wiring harness in thanks a bunch. I will be very interested the numbers are the motor when it's finished. Do you have or plan on making a torque strap?
Old Dec 9, 2013 | 07:34 AM
  #145
re
Robert,
I actually have 2 polished stainless turnbuckles I was going to mount to the block/heads on each side then to the frame, but I am worried about vibration, hopefully someone can chime in!
Old Dec 9, 2013 | 08:14 AM
  #146
therobski's Avatar
I don't have one on mine, don't really need it with street tires. As far as I know you only need one for the drivers-side, that's the torque side. My Grand National buddy Jack, he builds GN's uses old seat belt material-he says it gives just a little.
Old Dec 9, 2013 | 08:37 AM
  #147
My issue with needing two is that when I put it in reverse the header bangs the @#!t out of the steering arm. the turnbuckle style like I ordered will stop movement in either direction using just one, and I may use just one, I may look at building some type of bolt up L bracket for the frame and have some type of rubber between the bracket and the frame to dampen it a bit.
Even on street tires at 531 miles one side of my mounts was starting to tear.
Old Dec 9, 2013 | 11:26 AM
  #148
therobski's Avatar
Sounds like you were having fun!!!!
Old Jan 7, 2014 | 01:16 PM
  #149
Re
Just a little update....
The cam is here adv dur 301/311, 242/250 @ .050 lift is .602/.592 112+2 LS
roller lifters here
new harm balancer is here
New Performer RPM & Edelbrock heads are now in the possession of Smitty @ M & J for some CNC port work
American Racing headers 2" primary 3.5 collector are being built
getting ready to order the Mondello bracket kit with pulleys and polished PS pump
a LOAD of parts are at the powdercoating shop
all engine bolts including head bolts are ARP polished stainless
will be stripping the engine bay AGAIN to shoot base/clear gloss black
still debating exhaust but leaning towards Ram Air Restorations 3.5 oval X pipe into Spintech's with 3" round outlets for tail pipes to the rear tire!
JUST WHEN I THOUGHT I WAS FINISHED!
Old Jan 7, 2014 | 02:32 PM
  #150
therobski's Avatar
Mark I am running Ram Air Restorations 3 inch to the spin techs and 2.5 tailpipes on the 67. Good quality stuff, the only downside to me is that when you stand on it it sounds more like a new vette, Camaro, Challenger RT than a 60's 70's muscle car. I have a new pair of Flowmaster Super 44's but I am going to save those for the 64. But your AM headers may make a sound difference too I am running 1 3/4 inch Hookers. At speed on the freeway little sound in the back seat of the car.
Old Jan 7, 2014 | 04:43 PM
  #151
cv5800's Avatar
The car look's great! The one car I owned and have always regretted selling.
Dave
Old Jan 9, 2014 | 10:50 AM
  #152
Dave
Thank you very much..... we haven't even started on the body/paint/chrome
Old Jan 9, 2014 | 03:46 PM
  #153
therobski's Avatar
Mark here is an idea for a torque strap...
Old Jan 9, 2014 | 04:07 PM
  #154
I've seen many a Mopar run that style torque strap with no issues. You might consider making some solid motor mounts.
Old Jan 10, 2014 | 06:10 AM
  #155
therobski's Avatar
I may have saw this on ROP or here that somebody took the motor mount and drilled a hole through it and bolted it together-matting the rubber to the steel???? Done.
Old Jan 10, 2014 | 07:46 AM
  #156
Chadman has done that I do believe... I actually have two of those torque straps shown in the picture Robert!
Old May 18, 2014 | 11:56 AM
  #157
Round ii
Welp,
After a lot of thought and consideration, I sold the Art Carr 200R4 setup and opted for........that's right.......for......uhhhh huh for..................
480LE hughes performance with a Twist machine convertor, twist machine paddle shift on the column..... etc...
So far since after the last dyno session Mark (cutlassEFI) has ground up a new roller Cam for the 468, Smitty (M&J Proformance) has gotten the bastard file out on my Edelbrock heads literally, that was a huge mistake...... headers being changed from 1-3/4 hooker to 2" ARH, Exhaust being changed from 2-1/2 Magnaflow to 3.5 Oval Ram Air restorations into spintechs into 3" round tail pipes....Still considering what rear end to run!
More to come!
Old May 27, 2014 | 10:25 AM
  #158
mighty mouse's Avatar
I love this build, you have done an amazing job.
Old Jun 21, 2014 | 10:16 AM
  #159
lunaboy's Avatar
The Rocket Astronomer
Originally Posted by real57vetteguy
Gene,
I installed hooker competition headers last night, they clear great, I didnt have to tweak or bend the brake lines at all. I do however appreciate your keen eye, I thought the same, maybe luck or good manufacturers but it turned out great, ironically I always hear the horror of headers also, and mine fit perfect, no banging beating etc, I actually installed the headers myself, and had them installed complete in less than 20 minutes, I was prepared for a 4 hour battle
A friend is trying to install headers in his 65 with the 455. Could you please give use some tips. what hooker header p/n and did you use big block motor mounts to raise the motor or the standard 65 motor mount and cradle.?
Old Jun 21, 2014 | 11:37 AM
  #160
I've learned a lot and changed a lot since that post. In no way shape or form would I run the hookers. They ended up hitting the frame in multiple places and the steering shaft. On top of that they restricted the flow of my Edelbrock heads. I am having a set of ARH headers built.
